Author Topic: I2C NavKey - Open source project  (Read 3224 times)
Offline Atika
« on: April 11, 2019, 01:29:31 pm »
Hello,
Our open source project I2C NavKey is finally online!
https://hackaday.io/project/164886/gallery#ea535b172d46f1798d66d19a6269e293
An article is just published by hackaday today, check it out:
https://hackaday.com/2019/04/11/a-bolt-on-i2c-navigation-key-for-your-next-project/
The source code and design files are fully available on GitHub:
https://github.com/Fattoresaimon/I2CNavKey
« Last Edit: April 12, 2019, 09:06:47 am by Atika »
Offline ebastler
Re: I2C NavKey - Open source project
« Reply #1 on: April 13, 2019, 07:28:18 am »
Neat! I am curious about durability however:
- What kind of contacts/switches do you use?
- Is the wheel read optically or contact-based?
- Is there a specification on durability (how many switch and wheel operations)?
Thanks!
Offline Atika
« Reply #2 on: April 14, 2019, 04:21:33 pm »
Thank you!
The joypad is the following: https://www.ckswitches.com/media/1346/tsw.pdf
All the contact is mechanical  and from the datasheet all the contact have 1M cycle rotation life for each direction.
BR,
The following users thanked this post: ebastler
Offline blubillcanada
« Reply #3 on: May 17, 2020, 03:56:41 pm »
It's too bad that the series of navigation switches are discontinued.
Offline Atika
« Reply #4 on: May 18, 2020, 11:07:17 am »
Yes C&K has retired that product.
But there is another company called Zippy that have the exactly same components, both white and black.  ;D
I don't know if there is some relationship between the two company.
Anyway the product is still alive and available!
https://www.tindie.com/products/saimon/i2c-navkey-7-functions-joypad-on-the-i2c-bus
