Author Topic: µSupply in SMD  (Read 7612 times)
Offline Dileptor
µSupply in SMD
« on: September 21, 2012, 05:13:26 pm »
this is my first post and I'm fairly new to the site so just let me say that the EEVblog is brilliant! The world needs more people like Dave.
Now, I was wondering if the µSupply project could be converted to a SMD version. The reason I want to do that is that I have to design a
PCB for a school project (Czech Technical University). It can be anything I like only the size must be 5cm*10cm at most. And by the looks of
it the TH version looks larger. So what do you think? Could it be done? Or should I not waste my time trying ?
Martin
Offline shebu18
Re: µSupply in SMD
« Reply #1 on: September 21, 2012, 05:25:29 pm »
The ySupply is now a smd version. It would be hard to fit in into a 5x10cm board.
Offline Dileptor
Re: µSupply in SMD
« Reply #2 on: September 21, 2012, 05:57:08 pm »
Really? As far as I know there are about 12 videos about the power supply project and it's all through hole design.
Where did you find that it's smd ?
Thanks
Offline firewalker
  • Country: gr
Re: µSupply in SMD
« Reply #3 on: September 21, 2012, 05:58:53 pm »
Dave mentioned it a couple of times. Don;t if it was on a video or on a thread.
Alexander.
Offline PedroDiogo
  • Country: pt
  • EE Student
Re: µSupply in SMD
« Reply #4 on: September 21, 2012, 06:33:55 pm »
Today Dave posted a video clearly showing the new µSupply is using SMD.
Offline Psi
Re: µSupply in SMD
« Reply #5 on: September 21, 2012, 11:37:51 pm »
You maybe confused between the "power supply" project and the "usb power supply" project, they're not the same.
I think Dave put the 'power supply' project on hold indefinitely while he works on the 'usb power supply' project.
The 'usb powersupply' project was designed to be really small, so it can be thrown into a laptop bag, SMD is a must to get the size down to that level.
Where as the 'power supply' project was intended to sit on your electronics desk.
But i seem to remember he did plan to use one or two SMT ICs due to them not being available in DIP. The rest was through-hole though. With rotary encoders, RGB LCD etc...
« Last Edit: September 21, 2012, 11:41:54 pm by Psi »
Offline EEVblog
Re: µSupply in SMD
« Reply #6 on: September 22, 2012, 12:52:32 am »
Yes, both the USB and bench versions of the uSupply are SMD.
Yes, I'm focussing on the USB version first, and it has combined some features of the bench version, like battery power and PC connection.
Dave.
Offline Dileptor
Re: µSupply in SMD
« Reply #7 on: September 22, 2012, 11:48:57 am »
Thanks for clearing that up. Looks like 5x10cm si too small even for SMD (the bench power supply). I'm gonna have to choose something else.
Offline mcotis
Re: µSupply in SMD
« Reply #8 on: March 12, 2013, 04:55:24 pm »
Dave,
  Any news in regard to the USB Supply or the bench version?
[Edit]
I saw this post https://www.eevblog.com/forum/blog/usupply/
I think confusing me was the Projects list on your blog.  The uSupply page is missing a few recent YouTube videos - e.g. Part 7 and others.
« Last Edit: March 12, 2013, 05:01:59 pm by mcotis »
Offline scarrier
Re: µSupply in SMD
« Reply #9 on: March 16, 2013, 06:34:28 pm »
Can't wait a video update of that usb power supply.
