Author Topic: Finding replacement part for a Zener diode  (Read 10788 times)
Offline Svenski-79Topic starter
  • Country: in
« on: January 28, 2024, 05:23:45 pm »
In the OpenBCI Cyton board , the BOM contains a 3V zener diode (CZRQR52C3-HF), unfortunately the product has reached its end of life as per Mouser Electronics. can someone please point out a replacement I can use, it would be much appreciated , there is a lot of challenging stuff for me as a newbie regarding the programming side so any tips regarding the OpenBCI board would also be much appreciated.
Thank you
Offline Clear as mud
    • Pax Electronics
Re: Finding replacement part for a Zener diode
« Reply #1 on: January 29, 2024, 02:25:44 am »
I'm not familiar with this application, but for most applications, you could substitute any zener diode with the same physical size and voltage rating.  I see yours is a 0402 size, though, and I don't find any 3 volt 0402 zener diodes on Mouser.   However, Digikey still has over 400 in stock of your part number.
Offline cosmicray
« Reply #2 on: March 21, 2024, 10:18:10 pm »
Obtaining a zener in a conventional 0402, 0603, footprint appears to be a hard item to locate. A more common diode footprint, like SOD-323 seems to greatly improve your choices. One possibility is LM3Z3V3T1G, which is observed at LCSC at a very low price point.
it's only funny until someone gets hurt, then it's hilarious - R. Rabbit
