Author Topic: OSHW pic18f4550 based arduino  (Read 6142 times)
Offline SixDTopic starter
    • SixDev
« on: December 15, 2013, 06:19:14 pm »
I was planning to do pic18f4550 based arduino. i have tested pinguino but i don't get it to work.
Online westfw
Re: OSHW pic18f4550 based arduino
« Reply #1 on: December 15, 2013, 11:58:59 pm »
See "USB Bit Whacker"
But it might be easier to figure out what went wrong with your pinguino...
    • SixDev
« Reply #2 on: December 16, 2013, 06:44:01 pm »
I checked it out but it was for pic18f2550. The pic18f4550 has more I/O.
Offline adam1213
« Reply #3 on: December 16, 2013, 10:15:28 pm »
What doesn't work? e.g.
  • You can't install the software
  • The software does not compile
  • After programming the bootloader on to the device you can't program the device
  • You can compile programs and program the device through the bootloader however the programs do not run as expected
The pic18f2550 and pic18f4550 share the same datasheet and are BOTH supported by pinguino. e.g. http://wiki.pinguino.cc/index.php/PIC18F4550_Pinguino
« Last Edit: December 16, 2013, 10:17:54 pm by adam1213 »
    • SixDev
« Reply #4 on: December 16, 2013, 11:15:19 pm »
The problem with pinguino is that I can't upload software to the board via pinguino ide.
Offline adam1213
« Reply #5 on: December 16, 2013, 11:21:11 pm »
Have you programmed the pic18f4550 with the pinguino bootloader?
    • SixDev
« Reply #6 on: December 16, 2013, 11:36:53 pm »
Yes, I did program the bootloader.
Online westfw
« Reply #7 on: December 17, 2013, 06:33:23 am »
but [usb bit whacker] was for pic18f2550
It apparently also works for the 4550, although the DIP board didn't get to production:
http://www.schmalzhaus.com/UBW/Images/UBW40DIPv1.jpg
Offline poorchava
  • Troll Cave Electronics!
« Reply #8 on: December 17, 2013, 07:20:37 am »
Don't create another -duino. There's enough of them.
Offline filip_cro
  • Country: hr
« Reply #9 on: December 17, 2013, 03:36:06 pm »
Just put empty PIC and another uC to act as SPI programer. Much easier to do and you wont use more memory than is needed.
Offline u271D
  • Country: ua
« Reply #10 on: December 23, 2013, 04:01:06 pm »
I built a Chipino, it doesn't have USB though.
http://www.chipino.com/
