Author Topic: Electronic Modules  (Read 26995 times)
Offline AliRezaJoodiTopic starter
4~20mA Analog Input With A Relay Switch For Disable InputPicture:
« Reply #25 on: June 01, 2023, 06:18:44 pm »
Picture:
Schematic:
Open-source link: GitHub.com/AliRezaJoodi/Electronics_Modules
==> AnalogInput_CurrentSource_DisableInputWithRelay
If we turn off a board power supply while a ADC input connect to 4~20mA external source, The microcontroller does not turn off completely.
So, after turn on the board power supply, the micro will behave unreliably.
It was my experience about control board that use a ATmega2560 for induction furnace. I had to use a switch before ADC for disconnect the external source.
I tested it for many times and worked great.
Please follow and star me:
GitHub Account: GitHub.com/AliRezaJoodi
LinkedIn Account: LinkedIn.com/in/AliRezaJoodi
Thanks
Protected 4~20mA Analog Input
« Reply #26 on: June 03, 2023, 07:59:12 am »
Simulate:
==> AnalogInput_CurrentSource_ProtectedInput
A circuit that design by Jefferson Pehls for Protection a 4~20mA Current Input.
I just tried to understand it in Proteus.
Thanks
Source Link (Jeferson Pehls): https://www.linkedin.com/feed/update/urn:li:activity:7042709425547001856/
Re: Electronic Modules
« Reply #27 on: June 04, 2023, 09:27:23 am »
Isolated High Power Full-Bridge Inverter with MOSFET Switches
Schematic:
==> Inverter_FullBridge_MOSFET
Please follow and star me on the GitHub
Thanks
IR Sender and Receiver
« Reply #28 on: June 12, 2023, 09:38:59 am »
Electronic Modules
==> IR_Sender
==> IR_Receiver
Thanks
« Last Edit: June 25, 2023, 06:33:49 am by AliRezaJoodi »
Offline floobydust
« Reply #29 on: June 13, 2023, 02:43:02 am »
Schematic:
Why are you pulse stretching with C4, C5? You don't want overlap in a full bridge or it goes boom. What PWM frequencies is this bridge good for at 300VDC?
The following users thanked this post: AliRezaJoodi
Offline f4eru
    • Chargehanger
« Reply #30 on: June 14, 2023, 10:22:32 pm »
Seems intended to do stretching the OFF state of the MOS.
But really poor bridge design. A really good example of all things what not do do at 300V.
- slow optos
- too Hi-Z gate drive make it even slower.
- no good handling of transients during startup of the charge pumps
- Bipolar PWM means really crappy efficiency
- no mention of output filters, load type, nor bootstrap supply
- generation of VDD2 probably compromised at startup by the huge bootstraps charging without real current limits
- discharged C4, C5 generate a short circuit transient to the MOS gates at power up of the 5V -> funny one.
- no UVLOs on gate drivers
- no rail filtering
- no protection, current limit
- LEDs of optos directly in paralell.
If it is found to work, it would be a pure luck kind of situation depending on environment.
Each one of those points is easily capable to generate an EMS event (Explosive Magic Smoke).
Please learn all those topics, and I strongly advise to use real half-bridge driver ICs
« Last Edit: June 14, 2023, 10:40:39 pm by f4eru »
« Reply #31 on: June 15, 2023, 06:33:43 pm »
It was my old archive for UPS.
The C4 and C5 is stretching the ON state of the MOS
SPWM frequency was under 20KHz (I'm not sure now. I didn't write it)
« Last Edit: June 15, 2023, 06:45:21 pm by AliRezaJoodi »
« Reply #32 on: June 15, 2023, 06:51:37 pm »
- slow optos
- no rail filtering
Thank you for feedback  :-+
I'll study about it
Online ArdWar
  • Country: sc
« Reply #33 on: June 18, 2023, 03:45:47 pm »
"stretching the ON state" on both leg is probably the last thing you want to do on a bridge, let alone at 300V
How it didn't end up in a ball of plasma? You're lucky if it "only" ends up in smoke.
External WatchDog for AVR Microcontrollers
« Reply #34 on: June 25, 2023, 06:41:27 am »
Picture:
Schematic:
==> MCU_WatchDog
Thanks
Dialing on the Phone Line
« Reply #35 on: July 18, 2023, 12:17:19 pm »
==> PhoneLine_Dialing
Picture:
Schematic:
Thanks
