Author Topic: Open source GPS-disciplined frequency generator.  (Read 10223 times)
Online rclsTopic starter
« on: December 08, 2025, 06:37:57 pm »
I made an open hardware & open source GPS disciplined frequency generator with output frequencies from 1Hz to 1.6GHz.  https://github.com/rcls/gpsfreak
The device outputs four separately programmable frequencies (from 2 PLLs) onto SMA connectors, with GPS used as the source for a reference time base.
The clock generator is a TI LMK05318b bulk-acoustic wave oscillator.  This device is pretty flexible and has very low phase noise, in the same ball-park as a decent crystal oscillator (I don't have equipment capable of measuring it).
Short term frequency accuracy is determined by GPS and should be under 1ppb.  It can be built with either a U-Blox MAX-M10S (low cost) or MAX-F10S (dual
frequency) GPS module.
There is firmware, plus python scripts for controlling the device from a PC. (Configurations can be saved to flash for disconnected operation).
Manufacturing with JLCPCB and hand-soldering select components (connectors and the more obscure passives), you can build two units at approx US $50 each.
Cheers,
Ralph.
Offline DimitriP
Re: Open source GPS-disciplined frequency generator.
« Reply #1 on: December 09, 2025, 07:03:46 pm »
I like a grand entrance!
Welcome to the forum :)
The following users thanked this post: cncjerry, richnormand, rcls
Offline 5U4GB
« Reply #2 on: December 11, 2025, 05:15:16 am »
Nice, and nice detailed writeup!  Have you thought about submitting it to Silicon Chip as a project?
The following users thanked this post: rcls
« Reply #3 on: December 14, 2025, 08:28:05 pm »
Thanks for the suggestion, I'm looking into it.
The following users thanked this post: 5U4GB
Offline 5U4GB
« Reply #4 on: December 15, 2025, 03:30:01 am »
Just realised my note was a bit ambiguous, I meant it'd quality as a full-blown article, not just their reader-contributed circuit ideas at the back of the issue.
Offline SCSKITS
  • Retired electrical engineer
« Reply #5 on: January 21, 2026, 02:51:30 pm »
Would be nice to have a PDF in the GITHUB of the schematic and maybe the board layout.
SCS, DIY upgrades for older test equipment
The following users thanked this post: ivo
Offline dobsonr741
« Reply #7 on: March 23, 2026, 04:25:40 am »
Nice. Datasheet of LMK05318b say the max output frequency is 800MHz. How did you squeeze 2x of that? How’s the spectrum look like?
Offline Cyclotron
  • *POOF*
« Reply #8 on: March 23, 2026, 05:04:34 am »
This looks very interesting. I'll add it to my project list. Have you posted it to the time-nuts mailing list?
http://leapsecond.com/time-nuts.htm
« Reply #9 on: March 29, 2026, 03:29:07 am »
The TI docs are vague and contradictory on the max frequency. The web page sez 800Mhz. The data sheet sez 1250MHz is the max output frequency, but Footnote 5 on the datasheet "electrical characteristics" says:
An output frequency over fOUT max spec is possible, but output swing can be less than VOD min specification.
On "what does the spectrum look like", it looks good on my oscilloscope but the reality is I don't have equipment capable of characterising it. Although I can confirm that if you set the output frequency to 1575.42MHz and attach an appropriate piece of wire to an output then nearby GPS units notice the interference  :-DD
The following users thanked this post: dobsonr741
