IMHO if you're looking for >1kW you might be better off looking at more efficient speakers. Are you trying to outfit a large arena or something?
I'm sure it could be pared down.
Perhaps simply run at a lower voltage, knowing that it's well inside its SOA.
I agree that the need for a high-powered single amp channel is likely a sign that something else is wrong. At least in the context of audio (re)production.
And yes, efficiency
IS more important than power! Just a 3dB increase in the dB/W/m number represents TWICE the sound for the same electrical power! But very few people understand that. Decades of consumer products speccing
peak electrical input power (yeah, that's stupid) with a carefully selected test signal (not a valid test) has produced widespread expectations of ridiculous wattage for a given sound.
The boxes that we're all familiar with are only about as efficient as an incandescent light bulb. There are far more efficient designs (mostly horns in some form or another), but they're not as well known and hardly ever sought out. And they're a bit more sensitive to mass manufacturers cutting corners too, so if you've had one of those, it might poison your opinion as well.
I guess if you've done all of that research, and put an efficient driver that actually meets its specs, in an efficient enclosure that is made RIGHT, and you
still want an array of them that all do the same thing, then you could series/parallel them onto a single massive amp like this. One (minor) advantage of something this size is that you can rectify a 120VAC power input directly to the main power rails...if you can also
GUARANTEE (no excuses, ever, I don't care why) that no one will touch the
speaker leads either,
and that you also use an audio transformer at the input that can block the mains voltage. Good ones of those are expensive too. If it ends up being worth that, it might still be useful as-is for a massive powered subwoofer. (external connections are IEC and XLR, nothing else)
