Author Topic: To whom it may concern: N vs. P channel MOSFETs.  (Read 4842 times)
Offline ElectroIrradiatorTopic starter
  • More analog than digital.
« on: August 04, 2015, 02:04:33 pm »
(Yes, I do believe this is in the right forum section. :D )
Please be adviced that usually you[1] cannot replace an N channel MOSFET with a P channel ditto without suffering some dire consequences. That is why the first replacement MOSFET instantly blew up when you applied power. You shorted out the battery through the body diode, and the current was only limited by the DC resistance of the transformer. ;D
Otherwise enjoyed the video as always. :popcorn:
[1] Message meant for a fairly narrow selection of 'you'.
« Last Edit: August 04, 2015, 02:11:24 pm by ElectroIrradiator »
Offline McBryce
Re: To whom it may concern: N vs. P channel MOSFETs.
« Reply #1 on: August 04, 2015, 02:11:21 pm »
That's a VERY narrow "you" indeed. Any chance of a link to the video? :)
McBryce.
« Reply #2 on: August 04, 2015, 02:13:02 pm »
Apparently Shahriar and I were typing our respective posts at the same time.  ;D
Edit: I spelled Mr. S' name incorrectly... :palm:
« Last Edit: August 04, 2015, 02:29:29 pm by ElectroIrradiator »
Offline McBryce
« Reply #3 on: August 04, 2015, 02:20:07 pm »
It wouldn't be a Shahriar video if nothing exploded or caught fire :)
McBryce.
Offline dadler
« Reply #4 on: August 05, 2015, 02:19:26 am »
I am supremely confident that Shahriar knows the difference between P and N channel mosfets, considering he has a Ph.d in EE and works at Bell Labs (engineering manager, designing microwave-frequency ASICs)--in the building where the transistor was invented.
« Last Edit: August 05, 2015, 02:21:40 am by dadler »
« Reply #5 on: August 05, 2015, 07:55:33 am »
I know about his background in general terms.
I am also supremely confident that we all make those :palm: mistakes from time to time.
Offline MagicSmoker
« Reply #6 on: August 05, 2015, 10:53:35 pm »
...I am also supremely confident that we all make those :palm: mistakes from time to time.
Yes, this. I am always impressed when someone with a stellar pedigree does something exceptional stupid but still owns up to it; conversely, I am totally unamused when some wet-behind-the-ears intern blames an incomplete datasheet or the like for his/her failure.
Offline dadler
« Reply #7 on: August 06, 2015, 12:15:02 am »
In this case though, Shahriar just showed the wrong datasheet in the video. The newly-toasted mosfet in question was indeed N channel and actually only rated for 400mA. Hence why the to-220 mosfet was getting super hot, as the dc converter circuit really pulls a lot of current.
Offline Hugoneus
    • The Signal Path Video Blog
« Reply #8 on: August 21, 2015, 04:11:00 pm »
I just saw this! :)
In this case I showed the wrong datasheet in the video. As I was searching for replacement parts I downloaded many datasheets in the process. I added a note to the video.
Indeed if a PMOS would be used, it would put the DC-DC converter in positive feedback and would surely destroy the device in question.
