I went through a similar thing when I built my new workbenches and I thought long and hard about the layout. The basic question was, which instruments do I use the most? Ideally these should go in the center of the workbench and in my case the big three were the oscilloscope, the VNA and the bench multimeter. These three instruments are right in front of me as I type this with the PC screen directly above them.
Looking at the videos so far the most popular instrument seems to be the service monitor which on your old bench was off to the right so maybe that should move closer to the work space?
I like the idea of nice solid work benches though, some of those tube rigs can be heavy beasts.
Good comment.
I am still toying with the idea of where everything should go.
I did have a bit of theory behind the placement of the IFR. I have attached a picture of the current setup.
Thinking I will be doing most of my repairs near the corner of the bench, I place the IFR off to one side. Reason is working on all this tube equipment there is high voltage involved and did not want to be reaching over a unit. But as I sit here at the bench now I can see a lot of repairs may be directly in front of the monitor.
Also there is a HO8640B right in the corner of the benches.
Pretty sure things will swap places as I move forward. You made some valid points.
I can not have wobbly benches here. Like you said working on old tube stuff. The Apaches TX-1 weigh in at around a whopping 106 pounds. Takes solid bench to hold it
