Author Topic: 85V-260VAC to 5VDC-2.5A Flyback Switching Power Supply  (Read 6369 times)
Offline hesam.moshiriTopic starter
    • MyVanitar
« on: October 31, 2023, 08:56:59 am »
The key part of any electronic device is the power supply. Any instability or malfunction of the power supply part causes the device to stop working or demonstrate weird behavior. In this article/video, I introduced an AC-to-DC flyback Switching power supply that converts 85V-260VAC to 5VDC-2.5A, which can be used in various applications. The 5V selection for the output makes it friendly for linear regulators that convert 5VDC to lower voltages.
The maximum power delivery of this power supply is around 12W, which means it can handle 2.5A at 5V output. The controller chip is DK1203, which does not need any external supply, a startup resistor, or even an auxiliary winding on the transformer. The ferrite core of the transformer is EE20. A potentiometer allows you to adjust the output voltage and set it exactly at 5.0V.
To design the schematic and PCB, I used Altium Designer 23 and shared the PCB project with my friends for feedback and updates using Altium-365. The fast component search engine, Octopart, proved invaluable in quickly obtaining component information and generating the Bill of Materials (BOM). To ensure high-quality fabricated boards, I sent the Gerber files to PCBWay.
I tested the board for voltage drop, current delivery, and output noise. I used Siglent SDL1020X-E DC Load and Siglent SDS2102X Plus oscilloscope to perform all tests. I am confident that building this circuit enhances your knowledge regarding switching power supply design, except for using it for real applications.
Offline jonpaul
Re: 85V-260VAC to 5VDC-2.5A Flyback Switching Power Supply
« Reply #1 on: October 31, 2023, 10:57:31 am »
Nice....
Transformer wdg sheet?
BOM?
Schema ?
Jean-Paul  the Internet Dinosaur
    • MyVanitar
« Reply #3 on: November 08, 2023, 03:57:07 pm »
Specifications
Input Voltage: 85-265VAC
Output Voltage: 5VDC
Maximum Output Current: 2.5A
Maximum Output Current (continuous): 2A
Output Noise (No load): 1.5mV(rms), 4mV(p-p)
Output Noise (Max Load, 2A): 3mV(rms), 25mV(p-p)
Maximum Voltage Drop (2A load): 50mV
Transformer Type: EE20
Online mariush
« Reply #4 on: November 08, 2023, 05:08:36 pm »
Other than price, what's so special about it to be worth the hassle of making a custom transformer and adding all those other parts?
I'm not sure your design can even sustain 2A for long periods of time with the diodes you used. Also not quite a fan of how that transformer winding looks, I'm worried about the insulation between primary and secondary windings if you couldn't be bothered to even make the windings loop nicely on the exterior.
I would like to see something with a more modern chip, like maybe Power Integration's INN3274C : https://www.digikey.com/en/products/detail/power-integrations/INN3274C-H202-TL/7672281
