Author Topic: Inrush Current Limiter (Soft Starter) for AC and DC Loads  (Read 259 times)
Offline hesam.moshiri
    • MyVanitar
« on: June 09, 2020, 06:04:36 am »
Inrush current/Switch-ON surge is the maximal instantaneous input current drawn by an electrical device when first turned on. Inrush current is much higher than the load’s steady-state current and that’s the source of many problems such as fuse blowing up, load failure, load’s lifetime reduction, sparks at the switch contacts … etc. I tried to address this problem with an easy, however effective solution. I have introduced two circuits for both AC and DC loads.
« Last Edit: June 09, 2020, 08:48:12 am by hesam.moshiri »
