Author Topic: See3CAM_20CUG make your Driver Monitoring System safer and smarter  (Read 261 times)
Offline jm677zz
  • Country: in
Introducing See3CAM_20CUG - 2MP global shutter monochrome USB 3.1 Gen1 Camera for Driver Monitoring System (DMS). This industrial global shutter USB camera is based on High Resolution 1/2.9" OmniVision's OV2311 Image global shutter sensor with 3μm x 3μm pixel OmniPixel® 3-GS technology.  This monochrome USB camera can capture high frame rate images without any motion blur and its IR sensitivity helps to produce stunning image quality even at the Near Infrared (NIR) regions.
Offline JoseASanchez
Re: See3CAM_20CUG make your Driver Monitoring System safer and smarter
« Reply #1 on: June 05, 2020, 10:31:46 am »
Hi jm677zz,
Really impresive results of the camera. My company is already working in Driver Monitoring Systems. I would like to know what the best NIR waverlenght (850 or 940 nm) is for the camera. Do you have any specific parameters configuration for the camera for real driving light environment conditions?.
Thanks
