Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
EEVblog
Other Blogs
DIY Power bank for less than 5$
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DIY Power bank for less than 5$ (Read 1026 times)
wintech
Contributor
Country:
on:
September 02, 2019, 07:53:02 am »
https://youtu.be/WeayJ7kyYSU
Logged
aandrew
Frequent Contributor
Country:
Re: DIY Power bank for less than 5$
Reply #1 on:
September 02, 2019, 04:59:55 pm »
Questionable batteries - check.
soldering to batteries (and fuses) - check.
flammable enclosure - check.
A great example of how *not* to build a $5 battery bank, although I do admit that using the fuses and series resistors will probably keep you safe, especially since the battery bank module doesn't look like it can supply any kind of serious current.
Any reason why you chose to solder rather than just using 18650 battery holders such as
https://www.aliexpress.com/item/32821725795.html
(cheaper/alternate options also exist)?
Logged
ledtester
Super Contributor
Country:
Reply #2 on:
September 02, 2019, 05:35:33 pm »
Some things I don't understand about the schematic:
1. Why is the fuse protecting only one of the batteries in each pair? Seems that putting it in series with the 10R makes more sense.
2. Won't there be a huge voltage drop over the 10R resistors? If you want 5V 1A at the output, then you need at least 1.6W from each pair of cells. If a cell pair is charged up to 4V that means a pair needs to deliver 400mA. The drop across the 10R will be 4V! Or am I missing something?
Logged
wintech
Contributor
Country:
Reply #3 on:
September 03, 2019, 05:01:41 pm »
@ledtester
Well I've messed up the diagram.The 3 resistors should connect to the + terminal like that:Battery pack 1 to battery pack 2 ,battery pack 3 to battery pack 2 and battery pack 1 to battery pack 3.
Logged
Monkeh
Super Contributor
Country:
Reply #4 on:
September 03, 2019, 05:07:51 pm »
So for your less than $5 you've got an ugly, flimsy, bulky package with highly questionable capacity, which can source 1A on a really good day?
I'll stick to proper ones.
Logged
StillTrying
Super Contributor
Country:
Country: Broken Britain
Reply #5 on:
September 03, 2019, 05:28:59 pm »
I'm afraid that's one of the worst 'electrical things' I've ever seen.
Logged
That took
much
longer than I thought it would.
Print
Search
Pages: [
1
Go Up
« previous
next »
EEVblog
Other Blogs
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
