Author Topic: Active Low Pass Filter Bode Plot Analysis using Siglent SDS2102X Plus Oscillosco  (Read 827 times)
Offline hesam.moshiri
    • MyVanitar
In the second part of the active low pass filter analysis videos, I used the bode plot to analyze the low pass active filter's behavior in practice. There are not many devices that can calculate and demonstrate the bode plot. I used Siglent SDS2102X Plus oscilloscope to plot the bode curve. The cut-off frequency of the filter, in theory, is around 722Hz, however, in practice, the result would be different.
