Author Topic: Embedded System, IoT Projects, Arduino Tutorials  (Read 2344 times)
Offline epy
« on: June 04, 2020, 09:20:19 am »
Visit my Channel for Projects and Tutorials about Embedded System. I post videos IoT based projects, Electronics based projects, Arduino Based Projects and Tutorials. Here is my channel Link.
https://www.youtube.com/c/stechiezdiy
Here is my latest video
https://youtu.be/AiN5hsTEHks
« Last Edit: June 04, 2020, 09:23:23 am by epy »
Offline epy
Re: Embedded System, IoT Projects, Arduino Tutorials
« Reply #1 on: November 07, 2020, 08:51:38 am »
In this video we will cover interface STONE with Arduino and we will see following Parts.
1. Slider Bar (Drag Adjustment)
2. Gauge
3. ICON Generation
4. ADC Controlled Gauge
Here is the complete video tutorial
https://youtu.be/VXdlGUU4Too
Offline epy
« Reply #2 on: November 28, 2020, 06:46:02 am »
Send Data to Google Spread Sheet using ESP32 IFTTT, DHT11 | IoT Projects | IoT Training
ESP32 interface with DHT11 sensor and LDR sensor
https://youtu.be/YkA4TUgCmRA
Offline epy
« Reply #3 on: December 07, 2020, 08:08:28 am »
Arduino Datalogger Project
The sensor used: LDR, DHT11
Other modules: SD card module, RTC (DS1307 module)
Don't forget to subscribe to the channel to get more videos and projects..
https://youtu.be/Zr-Zb0e_lww
Offline epy
« Reply #4 on: February 02, 2021, 08:56:57 am »
Raspberry Pi Pico with microPython (uPyCraft and Thonny IDE) | GPIO control
https://youtu.be/86IkLcUk40I
Offline ebclr
« Reply #5 on: February 03, 2021, 01:23:39 am »
From where in India did you come from?
Offline epy
« Reply #6 on: February 26, 2021, 04:58:30 am »
In this video we will see shift register (74HC595) based LCD module instead of I2C based module. We need 3 wires only to control LCD using Arduino.
https://youtu.be/32OSnSKYB84
Offline epy
« Reply #7 on: June 17, 2021, 03:10:03 am »
In this video we will see how to interface Raspberry Pi Pico with Ultrasonic sensor (HCSR04) and OLED display (SSD1306). I have used micropython on pico.
Connection and Code :
https://github.com/stechiez/raspberrypi-pico/tree/main/SSD1306_HCSR04
https://youtu.be/_i6PY9hoSW8
Offline epy
« Reply #8 on: June 30, 2021, 05:02:36 am »
In this video we will see how to interface ST7735 with Raspberry Pi Pico using micropython.
https://youtu.be/9rDXPcwuXLA
Offline epy
« Reply #9 on: July 08, 2021, 11:52:51 am »
In this video we will see how to use Slamtec Lidar M1M1 mapper. You can get more info on following link:
https://www.slamtec.com/en/Support
https://youtu.be/HaQvKwt-eKg
[attach=1]
Offline epy
« Reply #10 on: September 10, 2021, 02:52:32 am »
Led Matrix Clock using ESP32 NTP without RTC IC
In this video we will see how to build Led Matrix Clock using ESP32 NTP without RTC IC. In this video we will use ESP32 as NTP client and we will read the time from pool.ntp.org, time.nist.gov.
https://youtu.be/Xj0NXzh0vXg
Offline epy
« Reply #11 on: September 20, 2021, 06:54:44 am »
Read Google Spread Sheet Data from ESP32
In this video we will see how to read data from google spread sheet and update the data on ESP32.
https://youtu.be/0LoeaewIAdY
