A teardown of a Migatronic Pilot 1800, a combined TIG & stick welder. TIG is short for Tungsten Inert Gas and refers to the tip of the welding handle, which is made out of tungsten. A inert gas comes from the handle, to surround the tip and ensure no air is near the welding bath. This machine can also do stick welding ( Shielded Metal Arc Welding ), which is the same principle, but the way of protecting the welding bath from air is by a layer of flux around the metal stick being deposited into the weld.
In this teardown video, I give a run down of the current paths in the system and I show which parts I kept.
