Author Topic: KPE - www.kaizerpowerelectronics.dk (see latest post for new videoes)  (Read 8555 times)
bsdphk and 1 Guest are viewing this topic.
Offline madsbarnkob
    • Kaizer Power Electronics
Re: KPE - www.kaizerpowerelectronics.dk (see latest post for new videoes)
« Reply #25 on: September 16, 2019, 07:32:48 pm »
I have news about my solar setup, summer is over and so is the solar setup :( In part 4 I take a look at the efficiency and look at the performance over the last 60 days.
http://www.kaizerpowerelectronics.dk - Tesla coils, high voltage, pulse power and more :)
http://www.highvoltageforum.net - Dedicated high voltage / Tesla coils forum
Offline madsbarnkob
« Reply #26 on: September 26, 2019, 08:33:38 am »
Thank you Cliff, I also love my mug and the coffee inside of it, it is needed!  :=\
Also a new video :)
The high resolution pictures and circuit explanation in text are hosted on my website: http://kaizerpowerelectronics.dk/teardown/nokia-siemens-flexi-3x90w-fxeb-1800mhz-base-station-teardown-power-amplifier-part-2-of-2/
Offline madsbarnkob
« Reply #27 on: September 30, 2019, 06:18:25 am »
The 1800W IH is now boxed up with all power supplies, water cooling, foot switch, current meter and insulated work coil.
The following users thanked this post: Cliff Matthews
Offline madsbarnkob
« Reply #28 on: October 03, 2019, 07:53:05 am »
Test with using regular mineral wool for house insulation, to insulated the work coil in order to achieve higher steel temperatures.
Here is another try, just with horizontal instead to contain some more heat, accidentally melted some plastic on the enclosure from that
Offline madsbarnkob
« Reply #29 on: October 07, 2019, 07:48:40 am »
I visited HI Tech & Industry Scandinavia 2019 in Herning, Denmark and while doing so I recorded clips of the most interesting robots, robotics, machines, vision, PLC and machine technology.
You can find booth exhibitions from Schneider Electric, Beckhoff, Flir, MakerBot, Wago, Rhode&Schwartz, Coherent and so on.
Offline madsbarnkob
« Reply #30 on: October 16, 2019, 07:11:38 am »
I needed a 50A current meter for the 1800W induction heater ( https://highvoltageforum.net/index.php?topic=530.0 ), but had none with the proper scaling. I do however have a large box of 1mA blank scale meters, so I decided to do a video on the following topics:
- Learn how to calculate the shunt resistor for your analog panel meter
- Guesstimate the internal resistance of a unknown meter
- Design custom scales if you have a blank meter or want to use a meter for another purpose than its original.
Link to scale-o-matic: http://stiftsbogtrykkeriet.dk/~mcs/Scale.html
Link to Meter from Tonne software: http://www.tonnesoftware.com/meter.html
Offline madsbarnkob
« Reply #31 on: November 08, 2019, 01:37:35 pm »
The HP T-620 Thin Client is a powerful little machine, that with ease can be hacked into using a random 19VDC PSU and run Windows as any normal PC, easy and cheap PC!
This thin client was thrown out, without anything else than the box itself, no power supplies, no nothing.
The port and connector layout from the manual shows that the HP T-620 models needs a 19VDC power supply. A little searching showed that it was not as simple as just supplying it with 19VDC. HP has put in a few tricks to make a "smart laptop charger" so that you can only use their chargers.
The "smart laptop charger" restriction can be bypassed with a simple current limiting hack as per this little schematics. All credits for this hack goes to:  http://nerdipedia.com/wiki/tiki-index.php?page=Smart+laptop+charger
Offline madsbarnkob
Offline madsbarnkob
Aethra CCD Webcam Teardown - From Back When Streaming Was Expensive!
« Reply #33 on: December 08, 2019, 12:36:33 pm »
This is a Aethra Colour CCD #Webcam that was part of a system made for remote #medical diagnose / consultation for patients in remote locations.
The system was mounted in a car to be mobile, so a driver could visit patients and make a call to the doctor do complete the consultation within the patients home. The system was driven by a #embedded PC with a complete circuit for the interface, audio/video and running all peripherals on a RS232 daisy chain. The whole setup used some kind of GSM link to transfer the video and audio signal, seemed to be a very expensive and complex setup.
Offline madsbarnkob
« Reply #34 on: December 16, 2019, 09:09:57 am »
Test and Teardown of a Julabo ED heating immersion circulator from a decommissioned laboratory.
JULABO immersion circulators for controlling temperature +20 to +150 °C in any bath tank up to 50 liters. Parts that are immersed in bath liquid are constructed of stainless steel or synthetic material. Common applications include controlling the temperature of samples, temperature testing of articles, materials testing, and evaluation, adjustment, and calibration or thermometers and thermal switches.
Offline madsbarnkob
Merry Christmas and a Happy New Year!
« Reply #35 on: December 23, 2019, 09:59:44 pm »
How to fix a broken iphone, shoutout to Louis Rossmann :)
This years seasonal greetings is a bit of comedy.
Offline madsbarnkob
« Reply #36 on: January 03, 2020, 08:37:37 am »
A teardown of a Kjellberg CUTi 31 Plasma Cutter with a power rating of 10 kVA. Made for cutting in 25-30 mm steel.
Connecting voltage (V): 3x 400VAC
Connecting power (kVA) 10.4
Mains fuse, slow(A) 16
Open circuit voltage (V) 240
Cutting current (A) 20...70
Duty cycle 70A/35% or 50A/100%
Offline Cliff Matthews
    • General Repair and Support
« Reply #37 on: January 03, 2020, 03:03:50 pm »
I don't see that reed relay as lasting too long.. maybe when it got stuck they would kick the box to make it work for a while longer. I wonder if that isolation transfo would have reqired litz wire? Also, nice outro music - Cheers! and Happy New Year!
Offline madsbarnkob
« Reply #38 on: January 11, 2020, 11:34:01 am »
Thank you Cliff and happy new year, my friend Mikas made the music for me, so I got some royalty free to use on youtube without loosing monitization :)
Review and test of a mini induction heater. At just 12V 10-15A you can have a small and effective induction heater for your work bench.
Offline madsbarnkob
DSO138, Not Even Once
« Reply #39 on: Today at 10:21:31 am »
Before you buy a DSO30 or DSO150 from ebay, amazon, wish or aliexpress, it is important to understand what you are getting. The specifications are very loosely written and what looks good on paper is useless in practical use. Here I test the DSO138 specified at 200 kHz, but in reality it is worthless above 20 kHz.
Buying the right oscilloscope is knowing your work area limits and where it might be in the future. I recommend that you read: 12 things to consider when choosing an oscilloscope: https://www.mouser.com/pdfdocs/Tektronix12_things_to_consider1.pdf
For the Nyquist applet to play with: http://195.134.76.37/applets/AppletNyquist/Appl_Nyquist2.html
