Author Topic: KPE - www.kaizerpowerelectronics.dk (see latest post for new videoes)  (Read 7210 times)
Offline madsbarnkob
    • Kaizer Power Electronics
Re: KPE - www.kaizerpowerelectronics.dk (see latest post for new videoes)
« Reply #25 on: September 16, 2019, 07:32:48 pm »
I have news about my solar setup, summer is over and so is the solar setup :( In part 4 I take a look at the efficiency and look at the performance over the last 60 days.
http://www.kaizerpowerelectronics.dk - Tesla coils, high voltage, pulse power and more :)
http://www.highvoltageforum.net - Dedicated high voltage / Tesla coils forum
Offline madsbarnkob
« Reply #26 on: September 26, 2019, 08:33:38 am »
Thank you Cliff, I also love my mug and the coffee inside of it, it is needed!  :=\
Also a new video :)
The high resolution pictures and circuit explanation in text are hosted on my website: http://kaizerpowerelectronics.dk/teardown/nokia-siemens-flexi-3x90w-fxeb-1800mhz-base-station-teardown-power-amplifier-part-2-of-2/
Offline madsbarnkob
« Reply #27 on: September 30, 2019, 06:18:25 am »
The 1800W IH is now boxed up with all power supplies, water cooling, foot switch, current meter and insulated work coil.
The following users thanked this post: Cliff Matthews
Offline madsbarnkob
« Reply #28 on: October 03, 2019, 07:53:05 am »
Test with using regular mineral wool for house insulation, to insulated the work coil in order to achieve higher steel temperatures.
Here is another try, just with horizontal instead to contain some more heat, accidentally melted some plastic on the enclosure from that
Offline madsbarnkob
« Reply #29 on: October 07, 2019, 07:48:40 am »
I visited HI Tech & Industry Scandinavia 2019 in Herning, Denmark and while doing so I recorded clips of the most interesting robots, robotics, machines, vision, PLC and machine technology.
You can find booth exhibitions from Schneider Electric, Beckhoff, Flir, MakerBot, Wago, Rhode&Schwartz, Coherent and so on.
Offline madsbarnkob
« Reply #30 on: October 16, 2019, 07:11:38 am »
I needed a 50A current meter for the 1800W induction heater ( https://highvoltageforum.net/index.php?topic=530.0 ), but had none with the proper scaling. I do however have a large box of 1mA blank scale meters, so I decided to do a video on the following topics:
- Learn how to calculate the shunt resistor for your analog panel meter
- Guesstimate the internal resistance of a unknown meter
- Design custom scales if you have a blank meter or want to use a meter for another purpose than its original.
Link to scale-o-matic: http://stiftsbogtrykkeriet.dk/~mcs/Scale.html
Link to Meter from Tonne software: http://www.tonnesoftware.com/meter.html
Offline madsbarnkob
« Reply #31 on: November 08, 2019, 01:37:35 pm »
The HP T-620 Thin Client is a powerful little machine, that with ease can be hacked into using a random 19VDC PSU and run Windows as any normal PC, easy and cheap PC!
This thin client was thrown out, without anything else than the box itself, no power supplies, no nothing.
The port and connector layout from the manual shows that the HP T-620 models needs a 19VDC power supply. A little searching showed that it was not as simple as just supplying it with 19VDC. HP has put in a few tricks to make a "smart laptop charger" so that you can only use their chargers.
The "smart laptop charger" restriction can be bypassed with a simple current limiting hack as per this little schematics. All credits for this hack goes to:  http://nerdipedia.com/wiki/tiki-index.php?page=Smart+laptop+charger
