The question is, why Musk puts up propositions which upon a minimum of reflection are unworkable?
I will remind again, just a decade nearly everyone in the industry was saying that landing rocket boosters is a stupid idea that will never work. Now SpaceX made more than 400 successful booster landings and up to 25 refights per booster, and launch rockets more often than anyone ever before. I'm fairly skeptical if they ever will be using Starship for point-to-point travel, however technically it's absolutely possible. There are no physics that would prevent it. The question is if Musk can actually pull it off. My opinion is that it's extremely hard to do but I would not bet against it. If you're going to debunk something, do it properly. Spewing emotions diluted by bullshit, poor research and call for reason does not make your debunking stronger on actual merit. Watching one of Thunderf00t's Starship livestreams revealed that he did not research the thing and knew fuck all about what he was watching and what Starship should do.
Back in the 1950s, there was great excitement about the Fairey Rotodyne "Compound Gyroplane".
It was a large vertical take off aircraft, capable of carrying 50 passengers at 150mph.
There was great interest in using it for relatively short hops, between city centres.
Passengers would be saved the time wasting travel to an airport, as it could take off like a helicopter, then transfer to horizontal flight, before heading off to the other city, where it would land vertically in the centre of the destination.
There were no physics to prevent this being done, the aircraft worked, but the noise from the tip jets on the large rotor was a major problem for its intended purpose.
it went through a number of iterations, including a planned 150 passenger version, before its "Achilles heel" of noise eventually killed it.
The noise from Starship results in it being banished to 32km out at sea, so that will never be fixable by any clever ideas.
As a sad commentary upon how things work out, if the Rotodyne (especially the 150 passenger version) had survived, such an aircraft
would have made trips to & from Starship launch/landing platforms much more viable.
Even in a timeline when something like Rotodyne was available, the logistics problems of embarking 100 passengers via an entrance high up on Starship, suitably preparing them for the flight, then sealing then in whilst refuelling the craft add hours to the time between reaching the site & liftoff.
All except the refuelling has to be repeated at disembarkation,again burning time.
No emotion, just cold, hard facts will ensure that point to point services using the kind of technology we currently possess won't happen.
It happens in visionary fiction due to the possession of technology which can just be hand waved up out of the air, technology which we may not ever have, if there is even a theoretical basis for it.
