Author Topic: Video Keithley 2460 Source Measure Unit (SMU) Review, Teardown and Experiments  (Read 37948 times)
Offline HugoneusTopic starter
    • The Signal Path Video Blog
Hi everyone,
This is a full review of the Keithley 2460. I already have done the review of the 2450 and this episode features a whole new set of experiments as well as a teardown of the unit. I hope you like it.
Watch the video here: [1 Hour & 5 Minutes]
http://youtu.be/zT80zDZgOWU
More videos at The Signal Path:
http://www.TheSignalPath.com
Offline TiN
  • Country: ua
    • xDevs.com
We don't like it, we Love it !  O0
Do you happen to have teardown photos? Can you post those , just in case? I do like look into Keithley gear inside.
Great!
I did not take any photos yet. I'll try to take some and post it.
Online HighVoltage
Wonderful review video, thanks so much.
You are welcome.
Offline JohnnyBerg
Nice video, however: you've been very, very mild to Keithley!
At 11:15 you compare the 2450 with the 2460 against the reference. The 2460 is spot on, but the 2450 is 10 counts off!
But because it is Keithley, you say: "is all accurate and I have no doubt .."
I find 10 count difference between 2 instruments at the same temperature and accuracy rather much.
I wonder what you would have said if it was a unknown brand, or a Chinese one? A bit more critical look perhaps?
note: same applies to the fan, position and noise. Again very mild about this.
I wonder if its a Keithley sponsored video?
No the video is not sponsored by anyone. None of my videos are sponsored.
The specified range accuracy of these units is +/- 0.015% rdg + 1mV. These measurements are well within the specified calibration limits. These units have also been calibrated 8 months apart. Furthermore, yes, I trust Keithley because they have earned it.
I mention the fan noise of the 2460 several times throughout the video. I also mention that for me personally the fan noise compromise to get the unit in the same form factor is worth it. This is the only statement I make in the whole video which is a personal preference.
I would have said the exact same thing if it was a Chinese brand. Watch my Rigol video reviews, they are Chinese. If it is an unknown brand (Chinese or not) I would spend more time verifying the claimed specification. For that see my Analog Arts USB scope review.
« Last Edit: March 24, 2015, 05:23:08 pm by Hugoneus »
Offline Len
Wow, I'm glad I don't make youtube videos. Every time someone says something good about something, they're accused of taking a bribe; and if they say something bad they're a biased hater. Often both at once.
Thank you, Shahriar, for putting up with the bullshit and continuing to make interesting videos.
DIY Eurorack Synth: https://lenp.net/synth/
Thank you. I really don't have any issue with criticism. I welcome it! Without any criticism how could I ever improve my work or find mistakes? I just hope that the discussions are always based on evidence and reason.
Offline es
For comparison, it would be nice to see a teardown of the 2450 too!
Offline dadler
I think we have established quite authoritatively that Shahriar is not biased and has no vested interest whatsoever in being less than objective. Listen to the amp hour episode with Shahriar, and you will learn about his background and qualifications. He has much better things to do than create and share these videos, and we collectively are quite privileged that he takes the time to do so.
Offline economist
Another great video. I really enjoy the combination of new equipment with the experiments. That takes a lot of work and planning and as a regular viewer of your videos I very much appreciate the effort. Great work.
Offline Lightages
  • Canadian po
Shahriar:
I always enjoy your reviews and other videos. They always bring more to the table than just "look at this box". They are very educational as well as being a thorough review.
Please take the next comment as constructive criticism. The color balance of your videos is always way off and very distracting to me, personally. It may just be me but others might see it the same way. Adjusting your color balance is a necessary thing for video if you want high quality production. In many cameras it is an easy function to find in a menu. If you can find it, just find something in the lab that is what looks like neutral grey to you and make sure it fills the frame and then set your white balance. This is not perfect but should make a huge difference in the appearance of your videos. There are white balance cards available in almost every camera shop that will will do it better if you are so inclined.
Again, thanks for your videos. I always watch them to the end and always learn something.
« Last Edit: March 25, 2015, 10:03:15 pm by Lightages »
Offline quantumvolt
  • Country: th
I am sure you must be mistaken. In this video:
he uses a Chinese 6 1/2 digit bench meter to probe some 5/15 volt internal supply voltages in a HP-box. The meter gets a very positive report.
I use a 10 dollar handheld for "OK or Faulty" probing of internal supplies, but that is another question.
[Edit - grammar and shortened]
« Last Edit: March 25, 2015, 11:42:04 am by quantumvolt »
Offline JohnnyBerg
I obviously stepped on some soles here and there. Wow.
@quantumvolt: no, I quote from the video. I mentioned even the exact moment, 11:15
@Shahriar: So you actually own a 2450 AND a 2460 unit?
Just to be clear, I liked the video very much.
But there is nothing wrong when reviewing gear to be critical on the review, despite the brand or origin. Every reporter/journalist has to ask the right questions, to get the most of it.
I remember Dave say that he has terms and conditions on how he does his reviews. If I remember correctly, LeCroy wanted to donate some stuff for review, but took a hike when they heard about his terms.
Offline krivx
  • Country: ie
I don't think Shahriar's integrity is in question - check out his USB scope review to see him call things out (quite rightly too)
I appreciate everyone's comments and I appreciate that no one is being hostile as there is no need for it.
I addressed this already. Both units are well within specification, they have also been calibrated many months apart. They show a difference of 90uV on a 20V range. How did you want me to criticize this? Would it not have been unscientific and unprofessional for me to criticize an instrument which is well within its specifications? I also mention in the video that I verified all other parameters and they too were in spec. I didn't record that because it would have been a waste of people's time.
That is not really relevant here because you have to show me where I have played favoritism here.
  • I showed the very difficult test of an unstable fan which produced spikes and caused the instrument to supply a different voltage than what was shown on the screen. As a result of my test and criticism Keithley may add a whole new feature to their product line.
  • I showed the plotting mistakes the instrument sometimes makes. Again, I have reported this to Keithley. I had also reported a series of issues to Keithley before which they addressed in a firmware already.
  • I mentioned the fan's loudness several times.
Thank you!  O0
And I was critical as I mentioned above.
No one has ever given me terms and conditions for my reviews. If anyone ever does, that unit will not get reviewed by me.
As I said before, I have no problem with your criticism and I welcome them. But you have to give me something that I can actually work with.
« Last Edit: March 25, 2015, 03:33:03 pm by Hugoneus »
Offline JohnnyBerg
May I conclude that you NOT own the units, and that they were given to you to review?
I think it is better to give full disclosure about those things, it helps to put things into perspective.
Of course, this is public knowledge. Sometimes the units are loaners and they have to go back and sometimes I can hold onto them for future videos. At other times I have purchased the instrument myself. None of this is relevant because it has no impact on my review.
Helps put what into perspective? You are willfully making unwarranted extrapolations that because instrument X was given to me, instrument X received a positive review. This is actually quiet insulting to me as a scientist and considering the amount of effort that goes into making a review such as the ones that I do.
Do you have an example where I have played favoritism of the instrument or not? I am interested in improving the videos. Provide an example and I will be happy to change my approach.
« Last Edit: March 25, 2015, 03:50:58 pm by Hugoneus »
Offline JohnnyBerg
I have no intentions to insult you, and I apologize if I did.
In my first posting I mentioned the part at 11:15, and quoted your comment.
Your answer was:
"Furthermore, yes, I trust Keithley because they have earned it.
I find that very mild towards Keithley. Why is the first unit spot on with the reference and the second unit more then 10 counts off? Yes, they are in spec, but I would expect them closer together. Certainly for what the instruments pretend to be.
My 34401A's are always within 1 count with each other, and I know from a other forum member that his 34401A's and 34470A are also within one count.
I am not a fanboy of any kind, just being critical on what I get told. I guess that came with my education.
But don't let me stop you making video's. I know that it takes a lot of time, and a lot of people are enjoying it very much.
Thank you. I too am sorry if I came across frustrated.
The 2450 and 2460 are rather different internally as a result of their power handling capability. When I had a loaner 2450, I compared two 2450's together and they were 1 or 2 parts apart also. I don't think it is reasonable to expect two rather different instruments to be less than 2 counts apart.
Good qualities which are required for critical thinking. I appreciate that.
As long as I am able to make videos, I will make them. Creation and dissemination of knowledge is a fundamental human responsibility.
Offline economist
The whole review bias issue is overblown in general. A good review reveals absence of bias. This 2460 review/experiments video is a great example. We see what the instrument can do. We see it in operation: fan noise, graphing oddity, and all of the great stuff too. As a result we have much more knowledge of the instrument. At the same time we get to learn something from the experiments themselves. I purchased a 2450 after a lot of research and probably would not have acquired such an expensive instrument without the level of detail shown in Shahriar's 2450 video. On the other hand, I have no need for the 2460. The fan would drive me crazy, and I don't presently need the broader current range it offers. I really hope Keithley is giving him these instruments to keep. His review / experiments videos are more than worth it.
Offline economist
Back on topic...
What I would really like to see from Keithley is a one quadrant version of the 2460 (hopefully resulting in losing that fan noise). An update of the 2280S-32-6 with TSP link and the new touch screen for under $2000 (better, under $1500) would be perfect. So much of the power of these instruments comes from the scripting capability over multiple devices. Many uses only require operation limited to +V +I ranges. A DMM7510 (or 2450 or both) TSP-linked to such an updated power supply would be terrific.
Offline es
They made two mistakes with the 2280S series, 1. not using their touchscreen UI, 2. no sense terminals on the front. They created a winner UI with the 2450, they should use it on all their products from now on.
Yes, I agree with you on this. They probably wanted to keep the cost down, and I am also not sure if the GUI and new touch-screen interface was ready when the 2280S was introduced.
