The peak power for a sine wave is twice the mean power (rms power is a vulgar error).
72 V pk-pk = 36 V peak = 25.46 V rms.
(25.46)2 / 8 = 81 W mean power.
Hmmm, make me wonder. I have an amp I measured with a clean 95vp-p output. The manufacturer claims a 200w RMS output. According to TimFox, they are off by a huge amount since:
95/2=47.5v, = 33.59v
(33.59)
2 / 8 = 141 W mean power.
On the other hand, if I fed the amp a square wave, then:
(47.50)
2 / 8 = 202 W mean power.
But, this is a square wave, so, always all 47.5v will be seen by the 8 ohm resistor. (Assuming infinite slew-rate)
That's 5.9375 amps seen by the 8 ohm load.
5.9375 amps X 47.5v = 282 watts? Double of TimFox's 'mean' power output formula.
Ok, am I to assume by TimFox's results that a sine wave's 'mean' power output into a resistive load is ~50% of a square wave at the same peak voltage?
