Author Topic: (For Resin Printers) PrusaSL1Viewer - Open,view,extract, edit, convert SL1 Files  (Read 161 times)
Offline sn4k3
  • Country: pt
PrusaSL1Viewer - Open, view, extract, edit and convert SL1 Files
OpenSource
Features
  • View image layer by layer
  • View and extract thumbnails
  • View all used settings
  • Edit print properties and save file
  • Export file to a folder
  • Convert SL1 format to another format
  • Portable (No installation needed)
For the lack of redudancy i'm not replicating the information on the post, if you have the interest read github page:
https://github.com/sn4k3/PrusaSL1Viewer
Releases: https://github.com/sn4k3/PrusaSL1Viewer/releases
« Last Edit: May 04, 2020, 06:21:52 pm by sn4k3 »
Offline AndyC_772
It's probably worth mentioning that .SL1 files are actually .ZIP files containing each layer as a .PNG.
If you want to see what's inside, all you need to do is rename the .SL1 to .ZIP and explore away.
Offline sn4k3
  • Country: pt
Like Zortax they are zip, but the main objective of this software is convertion to another format. So you can use prusa slicer and export the file to your printer without the need of reslice in the target slicer. It allow modify parameters without the reslice. While you can do that manualy it's easy to mess or miss something inside the zip. While that is true for zip, you can't do the same by hand on binary formats (.photo, .cbt, .cbddlp)
« Last Edit: May 04, 2020, 06:25:42 pm by sn4k3 »
Offline sn4k3
  • Country: pt
New version 0.3.3: https://github.com/sn4k3/PrusaSL1Viewer/releases/tag/v0.3.3
(Add) PHZ file format
(Add) "Phrozen Sonic Mini" printer
(Add) Convert Chitubox files to PHZ files and otherwise
(Add) Convert Chitubox and PHZ files to ZCodex
(Add) Elapsed seconds to convertion and extract dialog
(Improvement) "Convert To" menu now only show available formats to convert to, if none menu is disabled
(Fixed) Enforce cbt encryption
(Fixed) Not implemented convertions stay processing forever
