Yeah... I have spent a few months this year doing the UBLOX PUBX stuff
There is a lot to learn and a lot of weird stuff. Like the way EGNOS sats are reported... not same was WAAS ones. No support except by one guy on the UBLOX forum and he doesn't even work for them afaict. In the end I ended up parsing PUBX00, PUBX03 and one of the binary ones to get the sat status. I disabled all the other NMEA stuff. A lot of code... then I needed the DATE and that comes in the NMEA RMC packet so I had to enable that one. Also I need 5Hz and at 38400 you quickly reach some 50% of the port bandwidth at 38k, especially with 20+ sats being reported.
Anyway - all working now. I even generalised the code so it works with a non-UBLOX GPS, and then it sees only the RMC packet, used for date/time. I use this for setting the RTC, at some specified hour each day.
I was just looking for some standard API but there isn't anything really good. The basics are easy (date/time, lat, long, alt) but there is other stuff e.g. hdop vdop, hacc, vacc, whether SBAS is being used, and so on. So I will do my own one, which uses doubles for the coordinates and floats for much of the rest.
