The thing Visual Studio (even the proper full fat one) doesn't have, which I find so useful it's the other primary feature all my code editors since Brief have had, is the preview window. This isn't the VS preview window that merely shows a file preview but a preview of whatever your cursor happens to be on. If it's a function call it will show the function definition. A variable, the declaration. A struct member, the structure declaration. Etc. Even if you're not using it to actually preview, it is so quick that you get used to it signalling that the thing you just typed actually exists. IOW, if you type a name and the preview window doesn't show the declaration, you've made a typo.
The attached screeny gives a flavour. It's part of ESP32 example code, so the highlighted #define is actually defined somewhere within the 1GB of ESP-IDF source. Nevertheless, as soon as I click on it the preview window shows the definition - it is very rare that it doesn't update within a second. (Of course, this is in addition to the usual code hints and stuff.
