Products => Computers => Programming => Topic started by: orgamisho on January 31, 2021, 08:16:52 am
Title: Beginner on TL866 needs some help
Post by: orgamisho on January 31, 2021, 08:16:52 am
Hello all!
I am repairing  a device and to do so I have to reprogram the nand flash in it. I've successfuly read the nand and I found the data I need to change before programming it back to the nand but it seem that the data is grayed out and I can not change the cells.
I am using TL866ii PLUS with xgpro v10.75 software
Thank you in advance!
Title: Re: Beginner on TL866 needs some help
Post by: Bicurico on January 31, 2021, 09:23:42 am
You need to edit the data with a hex editor.
I usually use Notepad++ with the hex editor plugin.
Regards,
Vitor
Post by: orgamisho on January 31, 2021, 11:28:02 am
Unfortunately Notepad++ coould not open the file as it is doo big, but tried with a different hex editor and it worked!
Thank you!
