Author Topic: CAN Controller with Integrated Transceiver set with SPI  (Read 127 times)
Offline lorenrus
« on: May 25, 2020, 06:21:54 pm »
Hello everyone and good Sunday
I am checking the MCP25625 device with Arduino M0 Pro and in particular with its SPI.
I have to enable loopback mode by manipulating three bits of the CANCTRL register. to manipulate them you have to first send the statement, address, then a mask and then the data.
What happens to me is that as soon as I turn on I perform the reset and then I expect to see, in steps 44 and 45, the value of those registers to reset.
If I press for example 44 I actually have its reset value but if then I press immediately 45 I get a value that does not match the reset value; then if I reset again and I do the vice versa I see the correct reset value of point 45 but if then I push 44 I do not see it anymore.
And of course this does not allow me to understand whether I write or not and whether or not I write the bit for activating the loopback function correctly.
Someone can tell me where I'm wrong.
Thank you very much
/******* TEST CAN ***************/
  #define RESET_CAN_NEG 1
  #define CS_CAN_NEG 2
  #define CAN_INT_NEG 3
  #define FPGA_RX_CAN 8
  #define FPGA_TX_CAN 9
  #define CAN_STAND_BY A3
  SPISettings SPI_Settings(20000000, MSBFIRST, SPI_MODE0);
  unsigned int SPI_Received_Value = 0;
  unsigned int SPI_Received_Value_1 = 0;
void setup() {
  // put your setup code here, to run once:
  Serial.begin(9600);
  delay(2000);
  SPI.begin();
  pinMode(CS_CAN_NEG, OUTPUT);
  pinMode(RESET_CAN_NEG, OUTPUT);
  pinMode(CAN_STAND_BY, OUTPUT);
  digitalWrite(CS_CAN_NEG, HIGH);
  digitalWrite(RESET_CAN_NEG, HIGH);
  digitalWrite(CAN_STAND_BY, LOW);
void loop() {
  if(Serial.available()) {
    String Stringa = Serial.readString();
    int Dato = atoi(Stringa.c_str());
    delay(500);
/**** SPI ****/
    if(Dato == 42) {
        digitalWrite(CAN_STAND_BY, HIGH);
        Serial.println("Chip Reset");
        digitalWrite(RESET_CAN_NEG, LOW);
        delay(50);
        //digitalWrite(CS_CAN_NEG, LOW);
        //SPI.transfer(0b11000000);
        //digitalWrite(CS_CAN_NEG, HIGH);
    if(Dato == 43) {
        Serial.println("Active LoopBack Mode");
        //digitalWrite(CAN_STAND_BY, HIGH);
        SPI.beginTransaction(SPI_Settings);
        SPI.transfer(0b00000101); // Istruction
        SPI.transfer(0xF); // Address
        SPI.transfer(0b11111111); // Mask
        SPI.transfer(0b01000000); // Data
        SPI.endTransaction();
        //digitalWrite(CAN_STAND_BY, LOW);
        //SPI.end();
    if(Dato == 44) {
        //SPI.begin();
        Serial.println("Read Register CAN Control Register");
        SPI.transfer(0b00000011); // Istruction
        SPI_Received_Value = SPI.transfer(0);
        Serial.println(SPI_Received_Value);
        //SPI.end();
    if(Dato == 45) {
        //SPI.begin();
        Serial.println("Read Register CAN Status Register");
        SPI.transfer(0xE); // Address
        SPI_Received_Value_1 = SPI.transfer(0);
        Serial.println(SPI_Received_Value_1);
        //SPI.end();
Offline lorenrus
Re: CAN Controller with Integrated Transceiver set with SPI
« Reply #1 on: May 28, 2020, 06:26:06 am »
Can you help me ?
