Hello everyone and good Sunday
I am checking the MCP25625 device with Arduino M0 Pro and in particular with its SPI.
I have to enable loopback mode by manipulating three bits of the CANCTRL register. to manipulate them you have to first send the statement, address, then a mask and then the data.
What happens to me is that as soon as I turn on I perform the reset and then I expect to see, in steps 44 and 45, the value of those registers to reset.
If I press for example 44 I actually have its reset value but if then I press immediately 45 I get a value that does not match the reset value; then if I reset again and I do the vice versa I see the correct reset value of point 45 but if then I push 44 I do not see it anymore.
And of course this does not allow me to understand whether I write or not and whether or not I write the bit for activating the loopback function correctly.
Someone can tell me where I'm wrong.
Thank you very much
/******* TEST CAN ***************/
#define RESET_CAN_NEG 1
#define CS_CAN_NEG 2
#define CAN_INT_NEG 3
#define FPGA_RX_CAN 8
#define FPGA_TX_CAN 9
#define CAN_STAND_BY A3
SPISettings SPI_Settings(20000000, MSBFIRST, SPI_MODE0);
unsigned int SPI_Received_Value = 0;
unsigned int SPI_Received_Value_1 = 0;
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
delay(2000);
SPI.begin();
pinMode(CS_CAN_NEG, OUTPUT);
pinMode(RESET_CAN_NEG, OUTPUT);
pinMode(CAN_STAND_BY, OUTPUT);
digitalWrite(CS_CAN_NEG, HIGH);
digitalWrite(RESET_CAN_NEG, HIGH);
digitalWrite(CAN_STAND_BY, LOW);
void loop() {
if(Serial.available()) {
String Stringa = Serial.readString();
int Dato = atoi(Stringa.c_str());
delay(500);
/**** SPI ****/
if(Dato == 42) {
digitalWrite(CAN_STAND_BY, HIGH);
Serial.println("Chip Reset");
digitalWrite(RESET_CAN_NEG, LOW);
delay(50);
//digitalWrite(CS_CAN_NEG, LOW);
//SPI.transfer(0b11000000);
//digitalWrite(CS_CAN_NEG, HIGH);
if(Dato == 43) {
Serial.println("Active LoopBack Mode");
//digitalWrite(CAN_STAND_BY, HIGH);
SPI.beginTransaction(SPI_Settings);
SPI.transfer(0b00000101); // Istruction
SPI.transfer(0xF); // Address
SPI.transfer(0b11111111); // Mask
SPI.transfer(0b01000000); // Data
SPI.endTransaction();
//digitalWrite(CAN_STAND_BY, LOW);
//SPI.end();
if(Dato == 44) {
//SPI.begin();
Serial.println("Read Register CAN Control Register");
SPI.transfer(0b00000011); // Istruction
SPI_Received_Value = SPI.transfer(0);
Serial.println(SPI_Received_Value);
//SPI.end();
if(Dato == 45) {
//SPI.begin();
Serial.println("Read Register CAN Status Register");
SPI.transfer(0xE); // Address
SPI_Received_Value_1 = SPI.transfer(0);
Serial.println(SPI_Received_Value_1);
//SPI.end();
