As far as testing environments, I have a small W7 box I picked up after finding that neither Parallels or VMWare Fusion would work on a M1 Mac.
(things may have changed since then, but this small PC was VERY reasonable in price and was probably a better choice for my remaining Windows needs in the end)
I have both THRSim11 and 6811IDE (former for full compile, latter for quick routine testing)
MIS42N, ozcar: Yes, well spotted. That was a typo - yes, the LDX and CPX opcodes should be immediate-mode (in other words, #readout+7 and #readout)
Circlotron: I'm not sure, but that code is as fragile as it is atrocious. Any attempts to make it flow better visually causes the code to fall apart in a multitude of brainfarts, hence my question to see if it could be rewritten a bit better.
Oh, and there are other parts of the code that are
even worse, but that's another thread.
The reason I use 'addr' for the 24-bit binary result is that is exactly what it is - the address of the unit to be tested (this is part of some code for a piece of test equipment I reverse engineered a while back)
And regarding the arrangement of the readout bytes - that was dictated by the requirements of the Intel 8279 display / keyboard controller IC.
If I ever finish optimizing the code, I can probably redo it to work on something juuuust a bit more modern.
Anyway, the data readout portion of the display is 8 digits, the MSB being on the left (readout+7), going right towards readout+1, then the LSB (readout+0) contains the checksum digit (for example - if 64738 is entered as the address, the sum of the digits is 28, which is lopped off to leave just the 8. When the enter key is pressed, the code checks to ensure 8 was entered as the checksum before passing the data down to this routine).
Nominal Animal: Your code didn't work.
The X register address just kept drifting upwards and never exited.
