Products => Computers => Programming => Topic started by: eti on October 10, 2022, 07:21:31 am
Hi all.
Using Arduino code for an ESP32, PlatformIO on VS Code, I'm testing this basic code, and I get junk on the serial monitor. Yes, the "monitor_speed=9600" is set in the .ini file. Thanks. Any idea; do I need to add a short delay after the println() ?
#include <Arduino.h>
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
void loop() {
// put your main code here, to run repeatedly:
Serial.println(":) Hey");
Maybe this will work... add a delay...
void setup() {
Serial.begin(9600);
void loop() {
delay(2000);
Source: https://techtutorialsx.com/2017/04/24/esp32-hello-world/
I should point out that I'm not experienced with Arduino, but I hope it works.
void setup() {
Serial.begin(9600);
void loop() {
delay(2000);
Thanks very much indeed :) - I appreciate it, and I appreciate it that you didn't talk down to me.
