Hi. I can't google how to check ECC in a read NAND image.
NAND chip from Micron, 29F2G16
for READ ID (90h) command gives 2C CA 90 D5 86 00 00 00
according to the PDF, the bits say that 4-bit ECC.
512+4 (data) + 4 (spare/"not_used") + 8 (parity/ECC) bytes
and Internal ECC enabled
an old micron decoder with pudn/google calculate
bch_encoder_0x201b.exe -m 13 -k 4128 -t 4 <noname.txt // -> 07ED34D14242C
bch_encoder_0x25af.exe -m 13 -k 4128 -t 4 <noname.txt // -> EDE66E50C82B7
depending on the polynomial, but not A3BE308501E09E8A as in my dump
below is an example of a sector. maybe someone can help. thanks.
00000000 74 65 6d 20 66 6f 75 6e 64 20 61 74 20 62 6c 6f |tem found at blo|
00000010 63 6b 20 25 64 0a 00 00 3c 35 3e 52 41 4d 44 49 |ck %d...<5>RAMDI|
00000020 53 4b 3a 20 43 6f 75 6c 64 6e 27 74 20 66 69 6e |SK: Couldn't fin|
00000030 64 20 76 61 6c 69 64 20 52 41 4d 20 64 69 73 6b |d valid RAM disk|
00000040 20 69 6d 61 67 65 20 73 74 61 72 74 69 6e 67 20 | image starting |
00000050 61 74 20 25 64 2e 0a 00 3c 33 3e 52 41 4d 44 49 |at %d...<3>RAMDI|
00000060 53 4b 3a 20 43 6f 75 6c 64 6e 27 74 20 61 6c 6c |SK: Couldn't all|
00000070 6f 63 61 74 65 20 67 7a 69 70 20 62 75 66 66 65 |ocate gzip buffe|
00000080 72 0a 00 00 3c 33 3e 52 41 4d 44 49 53 4b 3a 20 |r...<3>RAMDISK: |
00000090 43 6f 75 6c 64 6e 27 74 20 61 6c 6c 6f 63 61 74 |Couldn't allocat|
000000a0 65 20 67 7a 69 70 20 77 69 6e 64 6f 77 0a 00 00 |e gzip window...|
000000b0 62 61 64 20 67 7a 69 70 20 6d 61 67 69 63 20 6e |bad gzip magic n|
000000c0 75 6d 62 65 72 73 00 00 69 6e 74 65 72 6e 61 6c |umbers..internal|
000000d0 20 65 72 72 6f 72 2c 20 69 6e 76 61 6c 69 64 20 | error, invalid |
000000e0 6d 65 74 68 6f 64 00 00 49 6e 70 75 74 20 69 73 |method..Input is|
000000f0 20 65 6e 63 72 79 70 74 65 64 00 00 4d 75 6c 74 | encrypted..Mult|
00000100 69 20 70 61 72 74 20 69 6e 70 75 74 00 00 00 00 |i part input....|
00000110 49 6e 70 75 74 20 68 61 73 20 69 6e 76 61 6c 69 |Input has invali|
00000120 64 20 66 6c 61 67 73 00 69 6e 76 61 6c 69 64 20 |d flags.invalid |
00000130 63 6f 6d 70 72 65 73 73 65 64 20 66 6f 72 6d 61 |compressed forma|
00000140 74 20 28 65 72 72 3d 31 29 00 00 00 69 6e 76 61 |t (err=1)...inva|
00000150 6c 69 64 20 63 6f 6d 70 72 65 73 73 65 64 20 66 |lid compressed f|
00000160 6f 72 6d 61 74 20 28 65 72 72 3d 32 29 00 00 00 |ormat (err=2)...|
00000170 6f 75 74 20 6f 66 20 6d 65 6d 6f 72 79 00 00 00 |out of memory...|
00000180 6f 75 74 20 6f 66 20 69 6e 70 75 74 20 64 61 74 |out of input dat|
00000190 61 00 00 00 69 6e 76 61 6c 69 64 20 63 6f 6d 70 |a...invalid comp|
000001a0 72 65 73 73 65 64 20 66 6f 72 6d 61 74 20 28 6f |ressed format (o|
000001b0 74 68 65 72 29 00 00 00 63 72 63 20 65 72 72 6f |ther)...crc erro|
000001c0 72 00 00 00 6c 65 6e 67 74 68 20 65 72 72 6f 72 |r...length error|
000001d0 00 00 00 00 52 41 4d 44 49 53 4b 3a 20 69 6d 61 |....RAMDISK: ima|
000001e0 67 65 20 74 6f 6f 20 62 69 67 21 20 28 25 64 4b |ge too big! (%dK|
000001f0 69 42 2f 25 6c 64 4b 69 42 29 0a 00 2f 69 6e 69 |iB/%ldKiB)../ini|
00000200 ff ff ff ff ff ff ff ff a3 be 30 85 01 e0 9e 8a |..........0.....|
yea. at my pdf 2C CA 90 D5 86 = Micron MT29F2G16ABAEA.
before I save forum and gogle space, and post only 512+16 bytes, here full 2112 bytes (2048 + 64 bytes)
00000000 65 72 72 75 70 74 73 00 64 69 73 61 62 6c 65 64 |errupts.disabled|
00000010 20 68 61 72 64 20 69 6e 74 65 72 72 75 70 74 73 | hard interrupts|
00000020 00 00 00 00 3c 34 3e 69 6e 69 74 63 61 6c 6c 20 |....<4>initcall |
00000030 61 74 20 30 78 25 70 00 3a 20 72 65 74 75 72 6e |at 0x%p.: return|
00000040 65 64 20 77 69 74 68 20 25 73 0a 00 69 6e 69 74 |ed with %s..init|
00000050 2f 6d 61 69 6e 2e 63 00 2f 64 65 76 2f 63 6f 6e |/main.c./dev/con|
00000060 73 6f 6c 65 00 00 00 00 3c 34 3e 57 61 72 6e 69 |sole....<4>Warni|
00000070 6e 67 3a 20 75 6e 61 62 6c 65 20 74 6f 20 6f 70 |ng: unable to op|
00000080 65 6e 20 61 6e 20 69 6e 69 74 69 61 6c 20 63 6f |en an initial co|
00000090 6e 73 6f 6c 65 2e 0a 00 3c 34 3e 46 61 69 6c 65 |nsole...<4>Faile|
000000a0 64 20 74 6f 20 65 78 65 63 75 74 65 20 25 73 0a |d to execute %s.|
000000b0 00 00 00 00 3c 34 3e 46 61 69 6c 65 64 20 74 6f |....<4>Failed to|
000000c0 20 65 78 65 63 75 74 65 20 25 73 2e 20 20 41 74 | execute %s. At|
000000d0 74 65 6d 70 74 69 6e 67 20 64 65 66 61 75 6c 74 |tempting default|
000000e0 73 2e 2e 2e 0a 00 00 00 2f 73 62 69 6e 2f 69 6e |s......./sbin/in|
000000f0 69 74 00 00 2f 65 74 63 2f 69 6e 69 74 00 00 00 |it../etc/init...|
00000100 2f 62 69 6e 2f 69 6e 69 74 00 00 00 2f 62 69 6e |/bin/init.../bin|
00000110 2f 73 68 00 4e 6f 20 69 6e 69 74 20 66 6f 75 6e |/sh.No init foun|
00000120 64 2e 20 20 54 72 79 20 70 61 73 73 69 6e 67 20 |d. Try passing |
00000130 69 6e 69 74 3d 20 6f 70 74 69 6f 6e 20 74 6f 20 |init= option to |
00000140 6b 65 72 6e 65 6c 2e 00 3c 34 3e 50 61 72 61 6d |kernel..<4>Param|
00000150 65 74 65 72 20 25 73 20 69 73 20 6f 62 73 6f 6c |eter %s is obsol|
00000160 65 74 65 2c 20 69 67 6e 6f 72 65 64 0a 00 00 00 |ete, ignored....|
00000170 3c 33 3e 55 6e 6b 6e 6f 77 6e 20 62 6f 6f 74 20 |<3>Unknown boot |
00000180 6f 70 74 69 6f 6e 20 60 25 73 27 3a 20 69 67 6e |option `%s': ign|
00000190 6f 72 69 6e 67 0a 00 00 54 6f 6f 20 6d 61 6e 79 |oring...Too many|
000001a0 20 62 6f 6f 74 20 65 6e 76 20 76 61 72 73 20 61 | boot env vars a|
000001b0 74 20 60 25 73 27 00 00 54 6f 6f 20 6d 61 6e 79 |t `%s'..Too many|
000001c0 20 62 6f 6f 74 20 69 6e 69 74 20 76 61 72 73 20 | boot init vars |
000001d0 61 74 20 60 25 73 27 00 65 61 72 6c 79 20 6f 70 |at `%s'.early op|
000001e0 74 69 6f 6e 73 00 00 00 3c 34 3e 4d 61 6c 66 6f |tions...<4>Malfo|
000001f0 72 6d 65 64 20 65 61 72 6c 79 20 6f 70 74 69 6f |rmed early optio|
00000200 6e 20 27 25 73 27 0a 00 3c 35 3e 00 3c 35 3e 4b |n '%s'..<5>.<5>K|
00000210 65 72 6e 65 6c 20 63 6f 6d 6d 61 6e 64 20 6c 69 |ernel command li|
00000220 6e 65 3a 20 25 73 0a 00 42 6f 6f 74 69 6e 67 20 |ne: %s..Booting |
00000230 6b 65 72 6e 65 6c 00 00 73 74 61 72 74 5f 6b 65 |kernel..start_ke|
00000240 72 6e 65 6c 28 29 3a 20 62 75 67 3a 20 69 6e 74 |rnel(): bug: int|
00000250 65 72 72 75 70 74 73 20 77 65 72 65 20 65 6e 61 |errupts were ena|
00000260 62 6c 65 64 20 65 61 72 6c 79 0a 00 3c 32 3e 69 |bled early..<2>i|
00000270 6e 69 74 72 64 20 6f 76 65 72 77 72 69 74 74 65 |nitrd overwritte|
00000280 6e 20 28 30 78 25 30 38 6c 78 20 3c 20 30 78 25 |n (0x%08lx < 0x%|
00000290 30 38 6c 78 29 20 2d 20 64 69 73 61 62 6c 69 6e |08lx) - disablin|
000002a0 67 20 69 74 2e 0a 00 00 48 4f 4d 45 3d 2f 00 00 |g it....HOME=/..|
000002b0 54 45 52 4d 3d 6c 69 6e 75 78 00 00 69 6e 69 74 |TERM=linux..init|
000002c0 00 00 00 00 2f 64 65 76 2f 72 6f 6f 74 00 00 00 |..../dev/root...|
000002d0 3c 35 3e 56 46 53 3a 20 49 6e 73 65 72 74 20 25 |<5>VFS: Insert %|
000002e0 73 20 61 6e 64 20 70 72 65 73 73 20 45 4e 54 45 |s and press ENTE|
000002f0 52 0a 00 00 20 72 65 61 64 6f 6e 6c 79 00 00 00 |R... readonly...|
00000300 56 46 53 3a 20 4d 6f 75 6e 74 65 64 20 72 6f 6f |VFS: Mounted roo|
00000310 74 20 28 25 73 20 66 69 6c 65 73 79 73 74 65 6d |t (%s filesystem|
00000320 29 25 73 2e 0a 00 00 00 56 46 53 3a 20 43 61 6e |)%s.....VFS: Can|
00000330 6e 6f 74 20 6f 70 65 6e 20 72 6f 6f 74 20 64 65 |not open root de|
00000340 76 69 63 65 20 22 25 73 22 20 6f 72 20 25 73 0a |vice "%s" or %s.|
00000350 00 00 00 00 50 6c 65 61 73 65 20 61 70 70 65 6e |....Please appen|
00000360 64 20 61 20 63 6f 72 72 65 63 74 20 22 72 6f 6f |d a correct "roo|
00000370 74 3d 22 20 62 6f 6f 74 20 6f 70 74 69 6f 6e 0a |t=" boot option.|
00000380 00 00 00 00 56 46 53 3a 20 55 6e 61 62 6c 65 20 |....VFS: Unable |
00000390 74 6f 20 6d 6f 75 6e 74 20 72 6f 6f 74 20 66 73 |to mount root fs|
000003a0 20 6f 6e 20 25 73 00 00 4e 6f 20 66 69 6c 65 73 | on %s..No files|
000003b0 79 73 74 65 6d 20 63 6f 75 6c 64 20 6d 6f 75 6e |ystem could moun|
000003c0 74 20 72 6f 6f 74 2c 20 74 72 69 65 64 3a 20 00 |t root, tried: .|
000003d0 2f 73 79 73 2f 62 6c 6f 63 6b 2f 25 73 2f 64 65 |/sys/block/%s/de|
000003e0 76 00 00 00 25 75 3a 25 75 00 00 00 2f 73 79 73 |v...%u:%u.../sys|
000003f0 2f 62 6c 6f 63 6b 2f 25 73 2f 72 61 6e 67 65 00 |/block/%s/range.|
00000400 2f 73 79 73 00 00 00 00 73 79 73 66 73 00 00 00 |/sys....sysfs...|
00000410 2f 64 65 76 2f 00 00 00 6e 66 73 00 3c 36 3e 57 |/dev/...nfs.<6>W|
00000420 61 69 74 69 6e 67 20 25 64 73 65 63 20 62 65 66 |aiting %dsec bef|
00000430 6f 72 65 20 6d 6f 75 6e 74 69 6e 67 20 72 6f 6f |ore mounting roo|
00000440 74 20 64 65 76 69 63 65 2e 2e 2e 0a 00 00 00 00 |t device........|
00000450 6d 74 64 00 3c 33 3e 25 73 0a 00 00 52 41 4d 44 |mtd.<3>%s...RAMD|
00000460 49 53 4b 3a 20 72 61 6e 20 6f 75 74 20 6f 66 20 |ISK: ran out of |
00000470 63 6f 6d 70 72 65 73 73 65 64 20 64 61 74 61 00 |compressed data.|
00000480 3c 33 3e 52 41 4d 44 49 53 4b 3a 20 69 6e 63 6f |<3>RAMDISK: inco|
00000490 6d 70 6c 65 74 65 20 77 72 69 74 65 20 28 25 64 |mplete write (%d|
000004a0 20 21 3d 20 25 64 29 20 25 6c 64 0a 00 00 00 00 | != %d) %ld.....|
000004b0 69 6e 63 6f 6d 70 6c 65 74 65 20 6c 69 74 65 72 |incomplete liter|
000004c0 61 6c 20 74 72 65 65 00 69 6e 63 6f 6d 70 6c 65 |al tree.incomple|
000004d0 74 65 20 64 69 73 74 61 6e 63 65 20 74 72 65 65 |te distance tree|
000004e0 00 00 00 00 2f 64 65 76 2f 72 61 6d 00 00 00 00 |..../dev/ram....|
000004f0 3c 35 3e 52 41 4d 44 49 53 4b 3a 20 43 6f 6d 70 |<5>RAMDISK: Comp|
00000500 72 65 73 73 65 64 20 69 6d 61 67 65 20 66 6f 75 |ressed image fou|
00000510 6e 64 20 61 74 20 62 6c 6f 63 6b 20 25 64 0a 00 |nd at block %d..|
00000520 3c 35 3e 52 41 4d 44 49 53 4b 3a 20 72 6f 6d 66 |<5>RAMDISK: romf|
00000530 73 20 66 69 6c 65 73 79 73 74 65 6d 20 66 6f 75 |s filesystem fou|
00000540 6e 64 20 61 74 20 62 6c 6f 63 6b 20 25 64 0a 00 |nd at block %d..|
00000550 3c 35 3e 52 41 4d 44 49 53 4b 3a 20 63 72 61 6d |<5>RAMDISK: cram|
00000560 66 73 20 66 69 6c 65 73 79 73 74 65 6d 20 66 6f |fs filesystem fo|
00000570 75 6e 64 20 61 74 20 62 6c 6f 63 6b 20 25 64 0a |und at block %d.|
00000580 00 00 00 00 3c 35 3e 52 41 4d 44 49 53 4b 3a 20 |....<5>RAMDISK: |
00000590 73 71 75 61 73 68 66 73 20 66 69 6c 65 73 79 73 |squashfs filesys|
000005a0 74 65 6d 20 66 6f 75 6e 64 20 61 74 20 62 6c 6f |tem found at blo|
000005b0 63 6b 20 25 64 0a 00 00 3c 35 3e 52 41 4d 44 49 |ck %d...<5>RAMDI|
000005c0 53 4b 3a 20 4d 69 6e 69 78 20 66 69 6c 65 73 79 |SK: Minix filesy|
000005d0 73 74 65 6d 20 66 6f 75 6e 64 20 61 74 20 62 6c |stem found at bl|
000005e0 6f 63 6b 20 25 64 0a 00 3c 35 3e 52 41 4d 44 49 |ock %d..<5>RAMDI|
000005f0 53 4b 3a 20 65 78 74 32 20 66 69 6c 65 73 79 73 |SK: ext2 filesys|
00000600 74 65 6d 20 66 6f 75 6e 64 20 61 74 20 62 6c 6f |tem found at blo|
00000610 63 6b 20 25 64 0a 00 00 3c 35 3e 52 41 4d 44 49 |ck %d...<5>RAMDI|
00000620 53 4b 3a 20 43 6f 75 6c 64 6e 27 74 20 66 69 6e |SK: Couldn't fin|
00000630 64 20 76 61 6c 69 64 20 52 41 4d 20 64 69 73 6b |d valid RAM disk|
00000640 20 69 6d 61 67 65 20 73 74 61 72 74 69 6e 67 20 | image starting |
00000650 61 74 20 25 64 2e 0a 00 3c 33 3e 52 41 4d 44 49 |at %d...<3>RAMDI|
00000660 53 4b 3a 20 43 6f 75 6c 64 6e 27 74 20 61 6c 6c |SK: Couldn't all|
00000670 6f 63 61 74 65 20 67 7a 69 70 20 62 75 66 66 65 |ocate gzip buffe|
00000680 72 0a 00 00 3c 33 3e 52 41 4d 44 49 53 4b 3a 20 |r...<3>RAMDISK: |
00000690 43 6f 75 6c 64 6e 27 74 20 61 6c 6c 6f 63 61 74 |Couldn't allocat|
000006a0 65 20 67 7a 69 70 20 77 69 6e 64 6f 77 0a 00 00 |e gzip window...|
000006b0 62 61 64 20 67 7a 69 70 20 6d 61 67 69 63 20 6e |bad gzip magic n|
000006c0 75 6d 62 65 72 73 00 00 69 6e 74 65 72 6e 61 6c |umbers..internal|
000006d0 20 65 72 72 6f 72 2c 20 69 6e 76 61 6c 69 64 20 | error, invalid |
000006e0 6d 65 74 68 6f 64 00 00 49 6e 70 75 74 20 69 73 |method..Input is|
000006f0 20 65 6e 63 72 79 70 74 65 64 00 00 4d 75 6c 74 | encrypted..Mult|
00000700 69 20 70 61 72 74 20 69 6e 70 75 74 00 00 00 00 |i part input....|
00000710 49 6e 70 75 74 20 68 61 73 20 69 6e 76 61 6c 69 |Input has invali|
00000720 64 20 66 6c 61 67 73 00 69 6e 76 61 6c 69 64 20 |d flags.invalid |
00000730 63 6f 6d 70 72 65 73 73 65 64 20 66 6f 72 6d 61 |compressed forma|
00000740 74 20 28 65 72 72 3d 31 29 00 00 00 69 6e 76 61 |t (err=1)...inva|
00000750 6c 69 64 20 63 6f 6d 70 72 65 73 73 65 64 20 66 |lid compressed f|
00000760 6f 72 6d 61 74 20 28 65 72 72 3d 32 29 00 00 00 |ormat (err=2)...|
00000770 6f 75 74 20 6f 66 20 6d 65 6d 6f 72 79 00 00 00 |out of memory...|
00000780 6f 75 74 20 6f 66 20 69 6e 70 75 74 20 64 61 74 |out of input dat|
00000790 61 00 00 00 69 6e 76 61 6c 69 64 20 63 6f 6d 70 |a...invalid comp|
000007a0 72 65 73 73 65 64 20 66 6f 72 6d 61 74 20 28 6f |ressed format (o|
000007b0 74 68 65 72 29 00 00 00 63 72 63 20 65 72 72 6f |ther)...crc erro|
000007c0 72 00 00 00 6c 65 6e 67 74 68 20 65 72 72 6f 72 |r...length error|
000007d0 00 00 00 00 52 41 4d 44 49 53 4b 3a 20 69 6d 61 |....RAMDISK: ima|
000007e0 67 65 20 74 6f 6f 20 62 69 67 21 20 28 25 64 4b |ge too big! (%dK|
000007f0 69 42 2f 25 6c 64 4b 69 42 29 0a 00 2f 69 6e 69 |iB/%ldKiB)../ini|
00000800 ff ff ff ff ff ff ff ff 1b 47 01 e3 00 00 39 1e |.........G....9.|
00000810 ff ff ff ff ff ff ff ff fa 08 11 e9 00 30 23 06 |.............0#.|
00000820 ff ff ff ff ff ff ff ff 8f 6d ce 82 01 20 64 74 |.........m... dt|
00000830 ff ff ff ff ff ff ff ff a3 be 30 85 01 e0 9e 8a |..........0.....|
according pdf - internal ECC - its 8 bytes from 516 bytes (512 of data and 4 spare(in my case always 0xFFFFFFFF))
Earlier, on other devices, I came across the fact that after reading data and writing it to another device,
this new device didn't work. them due to uncorrected ECC data.
so, when I need write 0x800 to new flash, I need read 0x840 from old flash, and check ECC.
that's why I'm always check ECC in the read data. but i can't do this here ((
