Author Topic: linux, is it possible to get the driver name of a built-in ethernet device?  (Read 5091 times)
Offline macboy
lspci -k
Will show kernel module in use for each PCI or PCIe device and kernel modules compatible with each, if more than one. e.g. I have 2.5 GbE cards compatible with r8169 built into kernel and r8125 as a loadable module. It shows both as compatible and which is actually controlling the device.
