Products => Computers => Programming => Topic started by: Scratch.HTF on September 30, 2021, 08:23:53 am
When I was writing four PLL/VCO libraries (ADF4351/ADF4355/HMC830/MAX2870), these pointers came to mind which I had to adjust accordingly:
- Bits which must be set as appropriate corresponding to an Integer (all Fraction values = 0) or Fractional (any Fraction value not 0) mode
- Charge Pump and Bleed settings which may be dependent on VCO frequency or integer (N) value
- Double buffering enable for certain bits in registers (including RF dividers) which will be latched on writing a certain register
- VCO feedback (divided/fundamental) source
- Prescaler based on VCO frequency
- Lock Detect cycle count and timeout settings
- ADC clock divider
- MUX OUT pin logic level
There may be more which need to be checked, but this was enough to get my libraries working.
