export SDL_VIDEO_FBCON_ROTATION="NONE"
export SDL_TOUCHSCREEN=1
export SDL_VIDEODRIVER=fbcon
export SDL_FBDEV=/dev/fb0
export TSLIB_FBDEVICE=/dev/fb0
export TSLIB_CONSOLEDEVICE="none"
export TSLIB_TSDEVICE=/dev/input/event1
export TSLIB_TSEVENTTYPE=INPUT
export TSLIB_CONFFILE=/etc/ts.conf #path to tslib configuration file
export TSLIB_CALIBFILE=/etc/pointercal #path to tslib calibration file
export SDL_MOUSEDRV=TSLIB
export SDL_MOUSEDEV=/dev/input/event1
VT=7
chvt $VT
NAME
chvt - change foreground virtual terminal
SYNOPSIS
chvt N
DESCRIPTION
The command chvt N makes /dev/ttyN the foreground terminal. (The corresponding screen is created if
it did not exist yet. To get rid of unused VTs, use deallocvt(1).) The key combination (Ctrl-)Left-
Alt-FN (with N in the range 1-12) usually has a similar effe
Now it works, I mean the (x,y) are not rotated, but ... coordinates are noisy, and the five buttons on the screen don't work.Better not use tslib, then. If I were you, I'd adjust the coordinates in your SDL application.
static double xytrans[6] = { 1.0, 0.0, 0.0, 0.0, 1.0, 0.0 };
static inline Uint32 GetMouse(int *xp, int *yp)
Uint32 retval;
int xc, int yc;
retval = SDL_GetGlobalMouseState(&xc, &yc);
if (xp) *xp = (int)( xc*xytrans[0] + yc*xytrans[1] + xytrans[2]);
if (yp) *yp = (int)( xc*xytrans[3] + yc*xytrans[4] + xytrans[5]);
return retval;
static int parse_xytrans(const char *from)
double c[6] = { 1.0, 0.0, 0.0, 0.0, 1.0, 0.0 };
const char *next;
if (!from)
return errno = EINVAL;
for (int i = 0; i < 6; i++) {
const char *next = from;
errno = 0;
c[i] = strtod(curr, (char **)(&next));
if (errno)
return errno;
if (next == from)
from = next;
if (*from == ':')
from++;
if (*from != '\0')
xytrans[i] = c[i];
return 0;
where you use GetMouse(&x,&y) instead of SDL_Get*MouseState(&x,&y).what is this?It switches to a specific console (/dev/tty7), just as if you pressed Alt+F7 on the console terminal. The first few consoles (/dev/tty1 and up) usually have a console login (getty) running, and that makes sure the SDL application does not interfere with those. X11 and Wayland etc. do the same.Code: [Select]VT=7
chvt $VT
I found it in an old example before invoking the SDL app
I wonder, is there a way to have two layers with SDL?Of course, except SDL talks about SDL_Surfaces instead. Consider the following example.c:
// SPDX-License-Identifier: CC0-1.0
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
#include "SDL.h"
#include "SDL_image.h"
/* Surface-specific RGB color; use 0xRRGGBB for HTML color #RRGGBB. */
static inline Uint32 RGB(SDL_Surface *s, unsigned int rgb)
return SDL_MapRGB(s->format, (rgb >> 16) & 255, (rgb >> 8) & 255, rgb & 255);
/* Surface-specific RGBA color; use 0xRRGGBBAA for HTML color #RRGGBB with opacity 0xAA/255. */
static inline Uint32 RGBA(SDL_Surface *s, unsigned int rgba)
return SDL_MapRGBA(s->format, (rgba >> 24) & 255, (rgba >> 16) & 255, (rgba >> 8) & 255, rgba & 255);
int main(int argc, char *argv[])
if (argc != 2 || !strcmp(argv[1], "-h") || !strcmp(argv[1], "--help")) {
const char *arg0 = (argc > 0 && argv && argv[0] && argv[0][0]) ? argv[0] : "(this)";
fprintf(stderr, "\n");
fprintf(stderr, "Usage: %s [ -h | --help ]\n", arg0);
fprintf(stderr, " %s IMAGE-FILE\n", arg0);
return EXIT_FAILURE;
/* Initialize SDL. */
if (SDL_Init(SDL_INIT_VIDEO | SDL_INIT_EVENTS) == -1) {
fprintf(stderr, "Cannot initialize SDL2: %s.\n", SDL_GetError());
/* Default to best possible scaling. */
SDL_SetHintWithPriority(SDL_HINT_RENDER_SCALE_QUALITY, "2", SDL_HINT_DEFAULT);
/* Load the desired image file. */
SDL_Surface *image = IMG_Load(argv[1]);
if (!image) {
fprintf(stderr, "%s: %s.\n", argv[1], IMG_GetError());
SDL_Quit();
if (SDL_SetSurfaceBlendMode(image, SDL_BLENDMODE_NONE)) {
fprintf(stderr, "Image surface cannot be copied as is: %s.\n", SDL_GetError());
SDL_FreeSurface(image);
SDL_Quit();
/* Create a window using the image dimensions. */
SDL_Window *window = SDL_CreateWindow("Example",
SDL_WINDOWPOS_UNDEFINED, SDL_WINDOWPOS_UNDEFINED,
image->w, image->h,
SDL_WINDOW_RESIZABLE | SDL_WINDOW_OPENGL);
if (!window) {
fprintf(stderr, "Cannot create an SDL window (%dx%d): %s.\n",
image->w, image->h, SDL_GetError());
SDL_Quit();
/* Obtain the window surface (target).
Note: This is owned by the window; never SDL_FreeSurface() this.
This will also be invalidated if the window size changes.
SDL_Surface *target = SDL_GetWindowSurface(window);
if (!target) {
fprintf(stderr, "Cannot obtain SDL window surface: %s.\n", SDL_GetError());
SDL_DestroyWindow(window);
SDL_Quit();
/* Fill it initially with a neutral grey. */
SDL_FillRect(target, NULL, RGB(target, 0xCCCCCC));
/* TODO: Better bit depth and pixel format, optimized for current window?
It should have alpha, unless we use color keying.
int drawable_bitdepth = 32;
int drawable_format = SDL_PIXELFORMAT_RGBA32;
/* Create a surface we can draw on.
TODO: Better bit depth and pixel format for the given window? Should have alpha, though.
SDL_Surface *drawable = SDL_CreateRGBSurfaceWithFormat(0, image->w, image->h,
drawable_bitdepth, drawable_format);
if (!drawable) {
fprintf(stderr, "Cannot create a drawable SDL surface: %s.\n", SDL_GetError());
SDL_Quit();
if (SDL_SetSurfaceBlendMode(drawable, SDL_BLENDMODE_BLEND) == -1) {
fprintf(stderr, "Drawable SDL surface does not support alpha blending: %s.\n", SDL_GetError());
SDL_FreeSurface(drawable);
SDL_Quit();
/* Clear the surface to transparent white. */
SDL_FillRect(drawable, NULL, RGBA(drawable, 0xFFFFFF00));
/* Main event loop */
while (1) {
SDL_Event event;
if (SDL_WaitEvent(&event) == 1) {
if (event.type == SDL_QUIT) {
break;
} else
if (event.type == SDL_MOUSEBUTTONDOWN) {
if (event.button.button == SDL_BUTTON_LEFT) {
const SDL_Rect r = { .x = event.button.x - 1, .y = event.button.y - 1, .w = 3, .h = 3 };
SDL_FillRect(drawable, &r, RGBA(drawable, 0xFF0000FF));
} else
if (event.type == SDL_MOUSEMOTION) {
if (event.motion.state & SDL_BUTTON_LMASK) {
SDL_Rect r = { .x = event.motion.x, .y = event.motion.y, .w = 1, .h = 1 };
} else
if (event.type == SDL_WINDOWEVENT) {
if (event.window.event == SDL_WINDOWEVENT_RESIZED ||
event.window.event == SDL_WINDOWEVENT_SIZE_CHANGED) {
int new_width = event.window.data1;
int new_height = event.window.data2;
/* The old window surface was invalidated. Refresh it. */
/* And fill it with a neutral grey. */
/* Expand? (We never shrink our drawable size, since it'd be lossy.) */
if (drawable->w < new_width || drawable->h < new_height) {
/* Don't shrink the drawable, as that'd be lossy. */
if (new_width < drawable->w)
new_width = drawable->w;
if (new_height < drawable->h)
new_height = drawable->h;
SDL_Surface *new_drawable = SDL_CreateRGBSurfaceWithFormat(0, new_width, new_height,
if (!new_drawable) {
fprintf(stderr, "Warning: Cannot extend drawable from %dx%d to %dx%d: %s.\n",
drawable->w, drawable->h, new_width, new_height, SDL_GetError());
} else {
SDL_SetSurfaceBlendMode(new_drawable, SDL_BLENDMODE_BLEND);
SDL_FillRect(new_drawable, NULL, RGBA(new_drawable, 0xFFFFFF00));
/* Blit the current contents of the drawable to the new drawable, */
SDL_BlitSurface(drawable, NULL, new_drawable, NULL);
/* and replace it with this new one. */
drawable = new_drawable;
/* Assume all events require a window content update. Normally, we'd only do this if and only if
event.type == SDL_WINDOWEVENT && (event.window.event == SDL_WINDOWEVENT_RESIZED ||
event.window.event == SDL_WINDOWEVENT_SIZE_CHANGED ||
event.window.event == SDL_WINDOWEVENT_SHOWN ||
event.window.event == SDL_WINDOWEVENT_EXPOSED)
but we'll keep things simple here. */
/* Blit the underlying image there. */
SDL_BlitSurface(image, NULL, target, NULL);
/* Then blit the drawable on top. */
SDL_BlitSurface(drawable, NULL, target, NULL);
/* Finally, update window contents. */
SDL_UpdateWindowSurface(window);
/* We could save the drawable as an image here. */
SDL_Quit();
return EXIT_SUCCESS;
}CC := gcc
CFLAGS := -Wall -Wextra -O2 `pkg-config --cflags sdl2 SDL2_image`
LDFLAGS := `pkg-config --libs sdl2 SDL2_image`
PROGS := example
.PHONY: all clean
all: clean $(PROGS)
clean:
rm -f *.o $(PROGS)
example: example.c
$(CC) $(CFLAGS) $^ $(LDFLAGS) -o $@
What is SDL ?
Simple DirectMedia Layer is a cross-platform development library designed to provide low level access to audio, keyboard, mouse, joystick, and graphics hardware via OpenGL and Direct3D.
Now it works in a "usable way" :D
I'd like to load a bitmap on layer0, and to draw on layer1, with layer1 displayed on the top of layer0, but with its pixels not "fused" with layer0.
So basically I want to save layer1 to a dedicated file.
What do you think about this?
case SDL_KEYDOWN:
switch (event.key.keysym.sym)
case SDLK_ESCAPE:
debug ("Escape pressed\n");
return 1;
case SDLK_1:
debug ("1 pressed\n");
clear_screen ();
break;
I mean none of these "virtual? buttons" cause a event, while pressing physical buttons on the keyboard does cause event, and the code reacts as expected.First, run
for D in /sys/class/input/event* ; do echo "$D: " "'$(cat $D/device/name)'" ; doneto list all input event devices the machine knows about. One of them should be the touch display; let's say event3.hexdump -C /dev/input/event3and touch the display buttons. Do you get any output? There should be at least one event device that generates something when you touch the buttons.
So I wonder what should I have to investigate. SDL? Some config? Or the kernel driver? :-//
/sys/class/input/event0/device/
bus/ driver/ input:input0/ modalias power/ subsystem/ uevent
/dev/input/
by-path/ event0 event1 mice mouse0
On some of the display modules I have, there are four "icons" at the bottom edge of the display. These are implemented simply by extending the touch sensor further than the display itself, with the icons drawn on the display glass (beneath the resistive touch surface). They are not really buttons at all, just report higher Y coordinate than anything within the display itself. So, to support these, one just treats them as mouse button (or touch) events that happen to occur outside the visible display region.
# hexdump -C /dev/input/event1
00000000 ed 5a f7 5f e0 0e 05 00 03 00 00 00 82 06 00 00 |.Z._............|
00000010 ed 5a f7 5f f7 0e 05 00 03 00 01 00 b7 06 00 00 |.Z._............|
00000020 ed 5a f7 5f fd 0e 05 00 03 00 18 00 7d 38 00 00 |.Z._........}8..|
00000030 ed 5a f7 5f 07 0f 05 00 00 00 00 00 00 00 00 00 |.Z._............|
00000040 ed 5a f7 5f ee 23 05 00 03 00 00 00 83 06 00 00 |.Z._.#..........|
00000050 ed 5a f7 5f fd 23 05 00 03 00 18 00 f0 31 00 00 |.Z._.#.......1..|
00000060 ed 5a f7 5f 07 24 05 00 00 00 00 00 00 00 00 00 |.Z._.$..........|
00000070 ed 5a f7 5f fe 4a 05 00 03 00 00 00 b4 06 00 00 |.Z._.J..........|
00000080 ed 5a f7 5f 0b 4b 05 00 03 00 01 00 93 06 00 00 |.Z._.K..........|
00000090 ed 5a f7 5f 10 4b 05 00 03 00 18 00 13 23 00 00 |.Z._.K.......#..|
000000a0 ed 5a f7 5f 19 4b 05 00 00 00 00 00 00 00 00 00 |.Z._.K..........|
000000b0 ed 5a f7 5f 08 72 05 00 03 00 00 00 d4 06 00 00 |.Z._.r..........|
000000c0 ed 5a f7 5f 13 72 05 00 03 00 01 00 4f 06 00 00 |.Z._.r......O...|
000000d0 ed 5a f7 5f 19 72 05 00 03 00 18 00 cb 23 00 00 |.Z._.r.......#..|
000000e0 ed 5a f7 5f 22 72 05 00 00 00 00 00 00 00 00 00 |.Z._"r..........|
000000f0 ed 5a f7 5f 97 e5 05 00 03 00 18 00 00 00 00 00 |.Z._............|
00000100 ed 5a f7 5f bd e5 05 00 00 00 00 00 00 00 00 00 |.Z._............|
00000110 ed 5a f7 5f 11 0e 06 00 03 00 00 00 ec 07 00 00 |.Z._............|
00000120 ed 5a f7 5f 34 0e 06 00 03 00 01 00 0a 07 00 00 |.Z._4...........|
00000130 ed 5a f7 5f 3a 0e 06 00 03 00 18 00 80 29 00 00 |.Z._:........)..|
00000140 ed 5a f7 5f 44 0e 06 00 00 00 00 00 00 00 00 00 |.Z._D...........|
00000150 ed 5a f7 5f 42 35 06 00 03 00 00 00 0a 08 00 00 |.Z._B5..........|
00000160 ed 5a f7 5f 66 35 06 00 03 00 01 00 26 07 00 00 |.Z._f5......&...|
00000170 ed 5a f7 5f 6b 35 06 00 03 00 18 00 8b 11 00 00 |.Z._k5..........|
00000180 ed 5a f7 5f 76 35 06 00 00 00 00 00 00 00 00 00 |.Z._v5..........|
00000190 ed 5a f7 5f 44 5c 06 00 03 00 00 00 10 08 00 00 |.Z._D\..........|
000001a0 ed 5a f7 5f 6a 5c 06 00 03 00 01 00 25 07 00 00 |.Z._j\......%...|
000001b0 ed 5a f7 5f 6f 5c 06 00 03 00 18 00 bc 11 00 00 |.Z._o\..........|
000001c0 ed 5a f7 5f 79 5c 06 00 00 00 00 00 00 00 00 00 |.Z._y\..........|
000001d0 ed 5a f7 5f 5c 83 06 00 03 00 00 00 17 08 00 00 |.Z._\...........|
000001e0 ed 5a f7 5f 81 83 06 00 03 00 01 00 1c 07 00 00 |.Z._............|
000001f0 ed 5a f7 5f 86 83 06 00 03 00 18 00 7b 17 00 00 |.Z._........{...|
00000200 ed 5a f7 5f 90 83 06 00 00 00 00 00 00 00 00 00 |.Z._............|
00000210 ed 5a f7 5f 62 aa 06 00 03 00 00 00 3b 08 00 00 |.Z._b.......;...|
00000220 ed 5a f7 5f 84 aa 06 00 03 00 01 00 2b 07 00 00 |.Z._........+...|
00000230 ed 5a f7 5f 8a aa 06 00 03 00 18 00 a0 11 00 00 |.Z._............|
00000240 ed 5a f7 5f 94 aa 06 00 00 00 00 00 00 00 00 00 |.Z._............|
00000250 ed 5a f7 5f 7d d1 06 00 03 00 00 00 4a 08 00 00 |.Z._}.......J...|
00000260 ed 5a f7 5f a0 d1 06 00 03 00 01 00 2f 07 00 00 |.Z._......../...|
00000270 ed 5a f7 5f a6 d1 06 00 03 00 18 00 fa 0f 00 00 |.Z._............|
00000280 ed 5a f7 5f b0 d1 06 00 00 00 00 00 00 00 00 00 |.Z._............|
00000290 ed 5a f7 5f 24 45 07 00 03 00 18 00 00 00 00 00 |.Z._$E..........|
000002a0 ed 5a f7 5f 4b 45 07 00 00 00 00 00 00 00 00 00 |.Z._KE..........|
000002b0 ed 5a f7 5f 17 5d 09 00 03 00 00 00 73 0a 00 00 |.Z._.]......s...|
000002c0 ed 5a f7 5f 3b 5d 09 00 03 00 01 00 fa 08 00 00 |.Z._;]..........|
000002d0 ed 5a f7 5f 41 5d 09 00 03 00 18 00 c3 32 00 00 |.Z._A].......2..|
000002e0 ed 5a f7 5f 4b 5d 09 00 00 00 00 00 00 00 00 00 |.Z._K]..........|
000002f0 ed 5a f7 5f b4 69 09 00 03 00 00 00 7d 0a 00 00 |.Z._.i......}...|
00000300 ed 5a f7 5f dc 69 09 00 03 00 01 00 fd 08 00 00 |.Z._.i..........|
00000310 ed 5a f7 5f e1 69 09 00 03 00 18 00 32 21 00 00 |.Z._.i......2!..|
00000320 ed 5a f7 5f eb 69 09 00 00 00 00 00 00 00 00 00 |.Z._.i..........|
00000330 ed 5a f7 5f 9d 90 09 00 03 00 00 00 81 0a 00 00 |.Z._............|
00000340 ed 5a f7 5f c2 90 09 00 03 00 01 00 0a 09 00 00 |.Z._............|
00000350 ed 5a f7 5f c7 90 09 00 03 00 18 00 d7 16 00 00 |.Z._............|
00000360 ed 5a f7 5f d1 90 09 00 00 00 00 00 00 00 00 00 |.Z._............|
00000370 ed 5a f7 5f a2 b7 09 00 03 00 00 00 80 0a 00 00 |.Z._............|
00000380 ed 5a f7 5f c5 b7 09 00 03 00 01 00 04 09 00 00 |.Z._............|
00000390 ed 5a f7 5f ca b7 09 00 03 00 18 00 51 12 00 00 |.Z._........Q...|
000003a0 ed 5a f7 5f d4 b7 09 00 00 00 00 00 00 00 00 00 |.Z._............|
000003b0 ed 5a f7 5f be de 09 00 03 00 00 00 86 0a 00 00 |.Z._............|
000003c0 ed 5a f7 5f e3 de 09 00 03 00 01 00 09 09 00 00 |.Z._............|
000003d0 ed 5a f7 5f e8 de 09 00 03 00 18 00 d4 10 00 00 |.Z._............|
000003e0 ed 5a f7 5f f2 de 09 00 00 00 00 00 00 00 00 00 |.Z._............|
000003f0 ed 5a f7 5f c4 05 0a 00 03 00 00 00 87 0a 00 00 |.Z._............|
00000400 ed 5a f7 5f e7 05 0a 00 03 00 01 00 e8 08 00 00 |.Z._............|
00000410 ed 5a f7 5f ec 05 0a 00 03 00 18 00 7f 10 00 00 |.Z._............|
00000420 ed 5a f7 5f f7 05 0a 00 00 00 00 00 00 00 00 00 |.Z._............|
00000430 ed 5a f7 5f dd 2c 0a 00 03 00 00 00 8c 0a 00 00 |.Z._.,..........|
00000440 ed 5a f7 5f 00 2d 0a 00 03 00 01 00 9c 08 00 00 |.Z._.-..........|
00000450 ed 5a f7 5f 06 2d 0a 00 03 00 18 00 23 0e 00 00 |.Z._.-......#...|
00000460 ed 5a f7 5f 10 2d 0a 00 00 00 00 00 00 00 00 00 |.Z._.-..........|
00000470 ed 5a f7 5f e0 53 0a 00 03 00 00 00 8a 0a 00 00 |.Z._.S..........|
00000480 ed 5a f7 5f 01 54 0a 00 03 00 01 00 70 08 00 00 |.Z._.T......p...|
00000490 ed 5a f7 5f 07 54 0a 00 03 00 18 00 cf 0b 00 00 |.Z._.T..........|
000004a0 ed 5a f7 5f 11 54 0a 00 00 00 00 00 00 00 00 00 |.Z._.T..........|
000004b0 ed 5a f7 5f fb 7a 0a 00 03 00 00 00 82 0a 00 00 |.Z._.z..........|
000004c0 ed 5a f7 5f 1f 7b 0a 00 03 00 01 00 58 08 00 00 |.Z._.{......X...|
000004d0 ed 5a f7 5f 24 7b 0a 00 03 00 18 00 26 0b 00 00 |.Z._${......&...|
000004e0 ed 5a f7 5f 2e 7b 0a 00 00 00 00 00 00 00 00 00 |.Z._.{..........|
000004f0 ed 5a f7 5f ff a1 0a 00 03 00 00 00 7c 0a 00 00 |.Z._........|...|
00000500 ed 5a f7 5f 20 a2 0a 00 03 00 01 00 37 08 00 00 |.Z._ .......7...|
00000510 ed 5a f7 5f 26 a2 0a 00 03 00 18 00 f1 0a 00 00 |.Z._&...........|
00000520 ed 5a f7 5f 30 a2 0a 00 00 00 00 00 00 00 00 00 |.Z._0...........|
00000530 ed 5a f7 5f 1d c9 0a 00 03 00 00 00 76 0a 00 00 |.Z._........v...|
00000540 ed 5a f7 5f 41 c9 0a 00 03 00 01 00 0d 08 00 00 |.Z._A...........|
00000550 ed 5a f7 5f 46 c9 0a 00 03 00 18 00 28 0b 00 00 |.Z._F.......(...|
00000560 ed 5a f7 5f 50 c9 0a 00 00 00 00 00 00 00 00 00 |.Z._P...........|
00000570 ed 5a f7 5f 1f f0 0a 00 03 00 00 00 68 0a 00 00 |.Z._........h...|
00000580 ed 5a f7 5f 42 f0 0a 00 03 00 01 00 e8 07 00 00 |.Z._B...........|
00000590 ed 5a f7 5f 47 f0 0a 00 03 00 18 00 32 0b 00 00 |.Z._G.......2...|
000005a0 ed 5a f7 5f 51 f0 0a 00 00 00 00 00 00 00 00 00 |.Z._Q...........|
000005b0 ed 5a f7 5f 3a 17 0b 00 03 00 00 00 41 0a 00 00 |.Z._:.......A...|
000005c0 ed 5a f7 5f 5e 17 0b 00 03 00 01 00 c5 07 00 00 |.Z._^...........|
000005d0 ed 5a f7 5f 64 17 0b 00 03 00 18 00 c0 09 00 00 |.Z._d...........|
000005e0 ed 5a f7 5f 6e 17 0b 00 00 00 00 00 00 00 00 00 |.Z._n...........|
000005f0 ed 5a f7 5f 41 3e 0b 00 03 00 00 00 25 0a 00 00 |.Z._A>......%...|
00000600 ed 5a f7 5f 64 3e 0b 00 03 00 01 00 b4 07 00 00 |.Z._d>..........|
00000610 ed 5a f7 5f 69 3e 0b 00 03 00 18 00 a8 09 00 00 |.Z._i>..........|
00000620 ed 5a f7 5f 73 3e 0b 00 00 00 00 00 00 00 00 00 |.Z._s>..........|
00000630 ed 5a f7 5f 59 65 0b 00 03 00 00 00 0c 0a 00 00 |.Z._Ye..........|
00000640 ed 5a f7 5f 7c 65 0b 00 03 00 01 00 a8 07 00 00 |.Z._|e..........|
00000650 ed 5a f7 5f 82 65 0b 00 03 00 18 00 68 09 00 00 |.Z._.e......h...|
00000660 ed 5a f7 5f 8c 65 0b 00 00 00 00 00 00 00 00 00 |.Z._.e..........|
00000670 ed 5a f7 5f 63 8c 0b 00 03 00 00 00 e6 09 00 00 |.Z._c...........|
00000680 ed 5a f7 5f 84 8c 0b 00 03 00 01 00 90 07 00 00 |.Z._............|
00000690 ed 5a f7 5f 8a 8c 0b 00 03 00 18 00 44 09 00 00 |.Z._........D...|
000006a0 ed 5a f7 5f 94 8c 0b 00 00 00 00 00 00 00 00 00 |.Z._............|
000006b0 ed 5a f7 5f 79 b3 0b 00 03 00 00 00 c0 09 00 00 |.Z._y...........|
000006c0 ed 5a f7 5f 9e b3 0b 00 03 00 01 00 81 07 00 00 |.Z._............|
000006d0 ed 5a f7 5f a3 b3 0b 00 03 00 18 00 08 09 00 00 |.Z._............|
000006e0 ed 5a f7 5f ad b3 0b 00 00 00 00 00 00 00 00 00 |.Z._............|
000006f0 ed 5a f7 5f 80 da 0b 00 03 00 00 00 94 09 00 00 |.Z._............|
00000700 ed 5a f7 5f a2 da 0b 00 03 00 01 00 6b 07 00 00 |.Z._........k...|
00000710 ed 5a f7 5f a8 da 0b 00 03 00 18 00 d3 08 00 00 |.Z._............|
00000720 ed 5a f7 5f b1 da 0b 00 00 00 00 00 00 00 00 00 |.Z._............|
00000730 ed 5a f7 5f 9c 01 0c 00 03 00 00 00 60 09 00 00 |.Z._........`...|
00000740 ed 5a f7 5f c0 01 0c 00 03 00 01 00 5c 07 00 00 |.Z._........\...|
00000750 ed 5a f7 5f c5 01 0c 00 03 00 18 00 e5 08 00 00 |.Z._............|
00000760 ed 5a f7 5f cf 01 0c 00 00 00 00 00 00 00 00 00 |.Z._............|
00000770 ed 5a f7 5f a0 28 0c 00 03 00 00 00 2a 09 00 00 |.Z._.(......*...|
00000780 ed 5a f7 5f c2 28 0c 00 03 00 01 00 4d 07 00 00 |.Z._.(......M...|
00000790 ed 5a f7 5f c8 28 0c 00 03 00 18 00 52 08 00 00 |.Z._.(......R...|
000007a0 ed 5a f7 5f d2 28 0c 00 00 00 00 00 00 00 00 00 |.Z._.(..........|
000007b0 ed 5a f7 5f bc 4f 0c 00 03 00 00 00 fb 08 00 00 |.Z._.O..........|
000007c0 ed 5a f7 5f e0 4f 0c 00 03 00 01 00 48 07 00 00 |.Z._.O......H...|
000007d0 ed 5a f7 5f e6 4f 0c 00 03 00 18 00 7d 08 00 00 |.Z._.O......}...|
000007e0 ed 5a f7 5f f0 4f 0c 00 00 00 00 00 00 00 00 00 |.Z._.O..........|
000007f0 ed 5a f7 5f c3 76 0c 00 03 00 00 00 c6 08 00 00 |.Z._.v..........|
00000800 ed 5a f7 5f e5 76 0c 00 03 00 01 00 40 07 00 00 |.Z._.v......@...|
00000810 ed 5a f7 5f eb 76 0c 00 03 00 18 00 77 08 00 00 |.Z._.v......w...|
00000820 ed 5a f7 5f f5 76 0c 00 00 00 00 00 00 00 00 00 |.Z._.v..........|
00000830 ed 5a f7 5f dc 9d 0c 00 03 00 00 00 84 08 00 00 |.Z._............|
00000840 ed 5a f7 5f 00 9e 0c 00 03 00 01 00 39 07 00 00 |.Z._........9...|
00000850 ed 5a f7 5f 06 9e 0c 00 03 00 18 00 20 08 00 00 |.Z._........ ...|
00000860 ed 5a f7 5f 10 9e 0c 00 00 00 00 00 00 00 00 00 |.Z._............|
00000870 ed 5a f7 5f e3 c4 0c 00 03 00 00 00 3f 08 00 00 |.Z._........?...|
00000880 ed 5a f7 5f 05 c5 0c 00 03 00 01 00 44 07 00 00 |.Z._........D...|
00000890 ed 5a f7 5f 0b c5 0c 00 03 00 18 00 45 08 00 00 |.Z._........E...|
000008a0 ed 5a f7 5f 14 c5 0c 00 00 00 00 00 00 00 00 00 |.Z._............|
000008b0 ed 5a f7 5f f9 eb 0c 00 03 00 00 00 ee 07 00 00 |.Z._............|
000008c0 ed 5a f7 5f 1d ec 0c 00 03 00 01 00 50 07 00 00 |.Z._........P...|
000008d0 ed 5a f7 5f 23 ec 0c 00 03 00 18 00 6a 08 00 00 |.Z._#.......j...|
000008e0 ed 5a f7 5f 2d ec 0c 00 00 00 00 00 00 00 00 00 |.Z._-...........|
000008f0 ed 5a f7 5f 00 13 0d 00 03 00 00 00 a0 07 00 00 |.Z._............|
00000900 ed 5a f7 5f 22 13 0d 00 03 00 01 00 58 07 00 00 |.Z._".......X...|
00000910 ed 5a f7 5f 27 13 0d 00 03 00 18 00 4a 08 00 00 |.Z._'.......J...|
00000920 ed 5a f7 5f 32 13 0d 00 00 00 00 00 00 00 00 00 |.Z._2...........|
00000930 ed 5a f7 5f 1f 3a 0d 00 03 00 00 00 5e 07 00 00 |.Z._.:......^...|
00000940 ed 5a f7 5f 44 3a 0d 00 03 00 01 00 5c 07 00 00 |.Z._D:......\...|
00000950 ed 5a f7 5f 49 3a 0d 00 03 00 18 00 03 08 00 00 |.Z._I:..........|
00000960 ed 5a f7 5f 53 3a 0d 00 00 00 00 00 00 00 00 00 |.Z._S:..........|
00000970 ed 5a f7 5f 22 61 0d 00 03 00 00 00 22 07 00 00 |.Z._"a......"...|
00000980 ed 5a f7 5f 44 61 0d 00 03 00 01 00 5e 07 00 00 |.Z._Da......^...|
00000990 ed 5a f7 5f 4a 61 0d 00 03 00 18 00 ef 07 00 00 |.Z._Ja..........|
000009a0 ed 5a f7 5f 54 61 0d 00 00 00 00 00 00 00 00 00 |.Z._Ta..........|
000009b0 ed 5a f7 5f 3d 88 0d 00 03 00 00 00 f1 06 00 00 |.Z._=...........|
000009c0 ed 5a f7 5f 63 88 0d 00 03 00 01 00 75 07 00 00 |.Z._c.......u...|
000009d0 ed 5a f7 5f 68 88 0d 00 03 00 18 00 02 08 00 00 |.Z._h...........|
000009e0 ed 5a f7 5f 72 88 0d 00 00 00 00 00 00 00 00 00 |.Z._r...........|
000009f0 ed 5a f7 5f 41 af 0d 00 03 00 00 00 bb 06 00 00 |.Z._A...........|
00000a00 ed 5a f7 5f 63 af 0d 00 03 00 01 00 6e 07 00 00 |.Z._c.......n...|
00000a10 ed 5a f7 5f 69 af 0d 00 03 00 18 00 f4 07 00 00 |.Z._i...........|
00000a20 ed 5a f7 5f 73 af 0d 00 00 00 00 00 00 00 00 00 |.Z._s...........|
00000a30 ed 5a f7 5f 5b d6 0d 00 03 00 00 00 90 06 00 00 |.Z._[...........|
00000a40 ed 5a f7 5f 7f d6 0d 00 03 00 01 00 80 07 00 00 |.Z._............|
00000a50 ed 5a f7 5f 85 d6 0d 00 03 00 18 00 0f 08 00 00 |.Z._............|
00000a60 ed 5a f7 5f 8f d6 0d 00 00 00 00 00 00 00 00 00 |.Z._............|
00000a70 ed 5a f7 5f 5f fd 0d 00 03 00 00 00 5a 06 00 00 |.Z.__.......Z...|
00000a80 ed 5a f7 5f 84 fd 0d 00 03 00 18 00 0b 08 00 00 |.Z._............|
00000a90 ed 5a f7 5f 8e fd 0d 00 00 00 00 00 00 00 00 00 |.Z._............|
00000aa0 ed 5a f7 5f 7d 24 0e 00 03 00 00 00 27 06 00 00 |.Z._}$......'...|
00000ab0 ed 5a f7 5f a0 24 0e 00 03 00 01 00 92 07 00 00 |.Z._.$..........|
00000ac0 ed 5a f7 5f a6 24 0e 00 03 00 18 00 80 08 00 00 |.Z._.$..........|
00000ad0 ed 5a f7 5f b0 24 0e 00 00 00 00 00 00 00 00 00 |.Z._.$..........|
00000ae0 ed 5a f7 5f 84 4b 0e 00 03 00 00 00 fc 05 00 00 |.Z._.K..........|
00000af0 ed 5a f7 5f a6 4b 0e 00 03 00 01 00 8c 07 00 00 |.Z._.K..........|
00000b00 ed 5a f7 5f ac 4b 0e 00 03 00 18 00 61 08 00 00 |.Z._.K......a...|
00000b10 ed 5a f7 5f b6 4b 0e 00 00 00 00 00 00 00 00 00 |.Z._.K..........|
00000b20 ed 5a f7 5f 98 72 0e 00 03 00 00 00 ea 05 00 00 |.Z._.r..........|
00000b30 ed 5a f7 5f bb 72 0e 00 03 00 01 00 8e 07 00 00 |.Z._.r..........|
00000b40 ed 5a f7 5f c0 72 0e 00 03 00 18 00 30 08 00 00 |.Z._.r......0...|
00000b50 ed 5a f7 5f cb 72 0e 00 00 00 00 00 00 00 00 00 |.Z._.r..........|
00000b60 ed 5a f7 5f 9f 99 0e 00 03 00 00 00 e7 05 00 00 |.Z._............|
00000b70 ed 5a f7 5f c0 99 0e 00 03 00 01 00 92 07 00 00 |.Z._............|
00000b80 ed 5a f7 5f c6 99 0e 00 03 00 18 00 1a 08 00 00 |.Z._............|
00000b90 ed 5a f7 5f d0 99 0e 00 00 00 00 00 00 00 00 00 |.Z._............|
00000ba0 ed 5a f7 5f bf c0 0e 00 03 00 00 00 e5 05 00 00 |.Z._............|
00000bb0 ed 5a f7 5f e4 c0 0e 00 03 00 01 00 95 07 00 00 |.Z._............|
00000bc0 ed 5a f7 5f e9 c0 0e 00 03 00 18 00 ef 07 00 00 |.Z._............|
00000bd0 ed 5a f7 5f f3 c0 0e 00 00 00 00 00 00 00 00 00 |.Z._............|
00000be0 ed 5a f7 5f c4 e7 0e 00 03 00 00 00 e2 05 00 00 |.Z._............|
00000bf0 ed 5a f7 5f e9 e7 0e 00 03 00 18 00 a1 07 00 00 |.Z._............|
00000c00 ed 5a f7 5f f4 e7 0e 00 00 00 00 00 00 00 00 00 |.Z._............|
00000c10 ed 5a f7 5f da 0e 0f 00 03 00 00 00 d5 05 00 00 |.Z._............|
00000c20 ed 5a f7 5f fe 0e 0f 00 03 00 01 00 85 07 00 00 |.Z._............|
00000c30 ed 5a f7 5f 04 0f 0f 00 03 00 18 00 fb 06 00 00 |.Z._............|
00000c40 ed 5a f7 5f 0e 0f 0f 00 00 00 00 00 00 00 00 00 |.Z._............|
00000c50 ed 5a f7 5f e0 35 0f 00 03 00 00 00 d3 05 00 00 |.Z._.5..........|
00000c60 ed 5a f7 5f 02 36 0f 00 03 00 01 00 80 07 00 00 |.Z._.6..........|
00000c70 ed 5a f7 5f 08 36 0f 00 03 00 18 00 cb 06 00 00 |.Z._.6..........|
00000c80 ed 5a f7 5f 11 36 0f 00 00 00 00 00 00 00 00 00 |.Z._.6..........|
00000c90 ee 5a f7 5f be 1a 00 00 03 00 00 00 d4 05 00 00 |.Z._............|
00000ca0 ee 5a f7 5f e3 1a 00 00 03 00 01 00 7c 07 00 00 |.Z._........|...|
00000cb0 ee 5a f7 5f e8 1a 00 00 03 00 18 00 b5 06 00 00 |.Z._............|
00000cc0 ee 5a f7 5f f2 1a 00 00 00 00 00 00 00 00 00 00 |.Z._............|
00000cd0 ee 5a f7 5f c7 41 00 00 03 00 00 00 d8 05 00 00 |.Z._.A..........|
00000ce0 ee 5a f7 5f ec 41 00 00 03 00 18 00 a0 06 00 00 |.Z._.A..........|
00000cf0 ee 5a f7 5f f7 41 00 00 00 00 00 00 00 00 00 00 |.Z._.A..........|
00000d00 ee 5a f7 5f dc 68 00 00 03 00 00 00 e4 05 00 00 |.Z._.h..........|
00000d10 ee 5a f7 5f 04 69 00 00 03 00 18 00 92 06 00 00 |.Z._.i..........|
00000d20 ee 5a f7 5f 0e 69 00 00 00 00 00 00 00 00 00 00 |.Z._.i..........|
00000d30 ee 5a f7 5f e3 8f 00 00 03 00 00 00 09 06 00 00 |.Z._............|
00000d40 ee 5a f7 5f 05 90 00 00 03 00 01 00 80 07 00 00 |.Z._............|
00000d50 ee 5a f7 5f 0a 90 00 00 03 00 18 00 70 06 00 00 |.Z._........p...|
00000d60 ee 5a f7 5f 14 90 00 00 00 00 00 00 00 00 00 00 |.Z._............|
00000d70 ee 5a f7 5f fd b6 00 00 03 00 00 00 38 06 00 00 |.Z._........8...|
00000d80 ee 5a f7 5f 22 b7 00 00 03 00 01 00 8b 07 00 00 |.Z._"...........|
00000d90 ee 5a f7 5f 28 b7 00 00 03 00 18 00 63 06 00 00 |.Z._(.......c...|
00000da0 ee 5a f7 5f 31 b7 00 00 00 00 00 00 00 00 00 00 |.Z._1...........|
00000db0 ee 5a f7 5f 00 de 00 00 03 00 00 00 72 06 00 00 |.Z._........r...|
00000dc0 ee 5a f7 5f 22 de 00 00 03 00 01 00 95 07 00 00 |.Z._"...........|
00000dd0 ee 5a f7 5f 28 de 00 00 03 00 18 00 2f 06 00 00 |.Z._(......./...|
00000de0 ee 5a f7 5f 32 de 00 00 00 00 00 00 00 00 00 00 |.Z._2...........|
00000df0 ee 5a f7 5f 1c 05 01 00 03 00 00 00 a8 06 00 00 |.Z._............|
00000e00 ee 5a f7 5f 41 05 01 00 03 00 01 00 b2 07 00 00 |.Z._A...........|
00000e10 ee 5a f7 5f 46 05 01 00 03 00 18 00 07 06 00 00 |.Z._F...........|
00000e20 ee 5a f7 5f 50 05 01 00 00 00 00 00 00 00 00 00 |.Z._P...........|
00000e30 ee 5a f7 5f 21 2c 01 00 03 00 00 00 d9 06 00 00 |.Z._!,..........|
00000e40 ee 5a f7 5f 43 2c 01 00 03 00 01 00 ca 07 00 00 |.Z._C,..........|
00000e50 ee 5a f7 5f 48 2c 01 00 03 00 18 00 fa 05 00 00 |.Z._H,..........|
00000e60 ee 5a f7 5f 53 2c 01 00 00 00 00 00 00 00 00 00 |.Z._S,..........|
00000e70 ee 5a f7 5f 3e 53 01 00 03 00 00 00 05 07 00 00 |.Z._>S..........|
00000e80 ee 5a f7 5f 63 53 01 00 03 00 01 00 d7 07 00 00 |.Z._cS..........|
00000e90 ee 5a f7 5f 69 53 01 00 03 00 18 00 06 06 00 00 |.Z._iS..........|
00000ea0 ee 5a f7 5f 73 53 01 00 00 00 00 00 00 00 00 00 |.Z._sS..........|
00000eb0 ee 5a f7 5f 42 7a 01 00 03 00 00 00 31 07 00 00 |.Z._Bz......1...|
00000ec0 ee 5a f7 5f 64 7a 01 00 03 00 01 00 e2 07 00 00 |.Z._dz..........|
00000ed0 ee 5a f7 5f 69 7a 01 00 03 00 18 00 f3 05 00 00 |.Z._iz..........|
00000ee0 ee 5a f7 5f 73 7a 01 00 00 00 00 00 00 00 00 00 |.Z._sz..........|
00000ef0 ee 5a f7 5f 77 a1 01 00 03 00 00 00 5e 07 00 00 |.Z._w.......^...|
00000f00 ee 5a f7 5f 8a a1 01 00 03 00 01 00 eb 07 00 00 |.Z._............|
00000f10 ee 5a f7 5f 8f a1 01 00 03 00 18 00 e0 05 00 00 |.Z._............|
00000f20 ee 5a f7 5f 99 a1 01 00 00 00 00 00 00 00 00 00 |.Z._............|
00000f30 ee 5a f7 5f 62 c8 01 00 03 00 00 00 94 07 00 00 |.Z._b...........|
00000f40 ee 5a f7 5f 84 c8 01 00 03 00 01 00 fa 07 00 00 |.Z._............|
00000f50 ee 5a f7 5f 8a c8 01 00 03 00 18 00 d1 05 00 00 |.Z._............|
00000f60 ee 5a f7 5f 94 c8 01 00 00 00 00 00 00 00 00 00 |.Z._............|
00000f70 ee 5a f7 5f 7a ef 01 00 03 00 00 00 c2 07 00 00 |.Z._z...........|
00000f80 ee 5a f7 5f 9f ef 01 00 03 00 01 00 0b 08 00 00 |.Z._............|
00000f90 ee 5a f7 5f a4 ef 01 00 03 00 18 00 aa 05 00 00 |.Z._............|
00000fa0 ee 5a f7 5f ae ef 01 00 00 00 00 00 00 00 00 00 |.Z._............|
00000fb0 ee 5a f7 5f 80 16 02 00 03 00 00 00 ee 07 00 00 |.Z._............|
00000fc0 ee 5a f7 5f a1 16 02 00 03 00 01 00 23 08 00 00 |.Z._........#...|
00000fd0 ee 5a f7 5f a7 16 02 00 03 00 18 00 9e 05 00 00 |.Z._............|
00000fe0 ee 5a f7 5f b1 16 02 00 00 00 00 00 00 00 00 00 |.Z._............|
00000ff0 ee 5a f7 5f 9d 3d 02 00 03 00 00 00 2c 08 00 00 |.Z._.=......,...|
00001000 ee 5a f7 5f c2 3d 02 00 03 00 01 00 32 08 00 00 |.Z._.=......2...|
00001010 ee 5a f7 5f c7 3d 02 00 03 00 18 00 d8 05 00 00 |.Z._.=..........|
00001020 ee 5a f7 5f d1 3d 02 00 00 00 00 00 00 00 00 00 |.Z._.=..........|
00001030 ee 5a f7 5f 9f 64 02 00 03 00 00 00 80 08 00 00 |.Z._.d..........|
00001040 ee 5a f7 5f c1 64 02 00 03 00 01 00 40 08 00 00 |.Z._.d......@...|
00001050 ee 5a f7 5f c7 64 02 00 03 00 18 00 4e 06 00 00 |.Z._.d......N...|
00001060 ee 5a f7 5f d0 64 02 00 00 00 00 00 00 00 00 00 |.Z._.d..........|
00001070 ee 5a f7 5f bc 8b 02 00 03 00 00 00 e9 08 00 00 |.Z._............|
00001080 ee 5a f7 5f e4 8b 02 00 03 00 18 00 09 06 00 00 |.Z._............|
00001090 ee 5a f7 5f ee 8b 02 00 00 00 00 00 00 00 00 00 |.Z._............|
000010a0 ee 5a f7 5f c0 b2 02 00 03 00 00 00 1a 09 00 00 |.Z._............|
000010b0 ee 5a f7 5f e2 b2 02 00 03 00 01 00 4c 08 00 00 |.Z._........L...|
000010c0 ee 5a f7 5f e7 b2 02 00 03 00 18 00 7a 06 00 00 |.Z._........z...|
000010d0 ee 5a f7 5f f2 b2 02 00 00 00 00 00 00 00 00 00 |.Z._............|
000010e0 ee 5a f7 5f d9 d9 02 00 03 00 00 00 34 09 00 00 |.Z._........4...|
000010f0 ee 5a f7 5f fe d9 02 00 03 00 01 00 52 08 00 00 |.Z._........R...|
00001100 ee 5a f7 5f 03 da 02 00 03 00 18 00 d1 07 00 00 |.Z._............|
00001110 ee 5a f7 5f 0d da 02 00 00 00 00 00 00 00 00 00 |.Z._............|
00001120 ee 5a f7 5f de 00 03 00 03 00 00 00 91 09 00 00 |.Z._............|
00001130 ee 5a f7 5f 00 01 03 00 03 00 01 00 3d 08 00 00 |.Z._........=...|
00001140 ee 5a f7 5f 06 01 03 00 03 00 18 00 04 08 00 00 |.Z._............|
00001150 ee 5a f7 5f 10 01 03 00 00 00 00 00 00 00 00 00 |.Z._............|
00001160 ee 5a f7 5f fa 27 03 00 03 00 00 00 b7 09 00 00 |.Z._.'..........|
00001170 ee 5a f7 5f 1e 28 03 00 03 00 01 00 5d 08 00 00 |.Z._.(......]...|
00001180 ee 5a f7 5f 23 28 03 00 03 00 18 00 a0 07 00 00 |.Z._#(..........|
00001190 ee 5a f7 5f 2c 28 03 00 00 00 00 00 00 00 00 00 |.Z._,(..........|
000011a0 ee 5a f7 5f ff 4e 03 00 03 00 00 00 a6 09 00 00 |.Z._.N..........|
000011b0 ee 5a f7 5f 21 4f 03 00 03 00 01 00 61 08 00 00 |.Z._!O......a...|
000011c0 ee 5a f7 5f 26 4f 03 00 03 00 18 00 62 0a 00 00 |.Z._&O......b...|
000011d0 ee 5a f7 5f 30 4f 03 00 00 00 00 00 00 00 00 00 |.Z._0O..........|
000011e0 ee 5a f7 5f 1c 76 03 00 03 00 00 00 d7 09 00 00 |.Z._.v..........|
000011f0 ee 5a f7 5f 40 76 03 00 03 00 01 00 80 08 00 00 |.Z._@v..........|
00001200 ee 5a f7 5f 45 76 03 00 03 00 18 00 af 08 00 00 |.Z._Ev..........|
00001210 ee 5a f7 5f 50 76 03 00 00 00 00 00 00 00 00 00 |.Z._Pv..........|
00001220 ee 5a f7 5f 1f 9d 03 00 03 00 00 00 dc 09 00 00 |.Z._............|
00001230 ee 5a f7 5f 41 9d 03 00 03 00 01 00 85 08 00 00 |.Z._A...........|
00001240 ee 5a f7 5f 47 9d 03 00 03 00 18 00 29 08 00 00 |.Z._G.......)...|
00001250 ee 5a f7 5f 50 9d 03 00 00 00 00 00 00 00 00 00 |.Z._P...........|
00001260 ee 5a f7 5f 40 c4 03 00 03 00 01 00 89 08 00 00 |.Z._@...........|
00001270 ee 5a f7 5f 65 c4 03 00 03 00 18 00 33 09 00 00 |.Z._e.......3...|
00001280 ee 5a f7 5f 6e c4 03 00 00 00 00 00 00 00 00 00 |.Z._n...........|
00001290 ee 5a f7 5f 42 eb 03 00 03 00 00 00 ce 09 00 00 |.Z._B...........|
000012a0 ee 5a f7 5f 65 eb 03 00 03 00 01 00 8f 08 00 00 |.Z._e...........|
000012b0 ee 5a f7 5f 6a eb 03 00 03 00 18 00 68 0b 00 00 |.Z._j.......h...|
000012c0 ee 5a f7 5f 74 eb 03 00 00 00 00 00 00 00 00 00 |.Z._t...........|
000012d0 ee 5a f7 5f 5c 12 04 00 03 00 00 00 e0 09 00 00 |.Z._\...........|
000012e0 ee 5a f7 5f 80 12 04 00 03 00 01 00 92 08 00 00 |.Z._............|
000012f0 ee 5a f7 5f 85 12 04 00 03 00 18 00 9c 17 00 00 |.Z._............|
00001300 ee 5a f7 5f 90 12 04 00 00 00 00 00 00 00 00 00 |.Z._............|
00001310 ee 5a f7 5f 05 86 04 00 03 00 18 00 00 00 00 00 |.Z._............|
00001320 ee 5a f7 5f 2c 86 04 00 00 00 00 00 00 00 00 00 |.Z._,...........|
00001330 ee 5a f7 5f 25 2e 07 00 03 00 00 00 16 06 00 00 |.Z._%...........|
00001340 ee 5a f7 5f 39 2e 07 00 03 00 01 00 46 02 00 00 |.Z._9.......F...|
00001350 ee 5a f7 5f 3f 2e 07 00 03 00 18 00 9e 36 00 00 |.Z._?........6..|
00001360 ee 5a f7 5f 49 2e 07 00 00 00 00 00 00 00 00 00 |.Z._I...........|
00001370 ee 5a f7 5f a0 46 07 00 03 00 00 00 1c 06 00 00 |.Z._.F..........|
00001380 ee 5a f7 5f c6 46 07 00 03 00 01 00 49 02 00 00 |.Z._.F......I...|
00001390 ee 5a f7 5f cb 46 07 00 03 00 18 00 34 19 00 00 |.Z._.F......4...|
000013a0 ee 5a f7 5f d5 46 07 00 00 00 00 00 00 00 00 00 |.Z._.F..........|
000013b0 ee 5a f7 5f bd 6d 07 00 03 00 00 00 26 06 00 00 |.Z._.m......&...|
000013c0 ee 5a f7 5f e2 6d 07 00 03 00 01 00 5a 02 00 00 |.Z._.m......Z...|
000013d0 ee 5a f7 5f e7 6d 07 00 03 00 18 00 ea 18 00 00 |.Z._.m..........|
000013e0 ee 5a f7 5f f2 6d 07 00 00 00 00 00 00 00 00 00 |.Z._.m..........|
000013f0 ee 5a f7 5f c0 94 07 00 03 00 00 00 38 06 00 00 |.Z._........8...|
00001400 ee 5a f7 5f e1 94 07 00 03 00 01 00 8b 02 00 00 |.Z._............|
00001410 ee 5a f7 5f e7 94 07 00 03 00 18 00 b1 15 00 00 |.Z._............|
00001420 ee 5a f7 5f f1 94 07 00 00 00 00 00 00 00 00 00 |.Z._............|
00001430 ee 5a f7 5f db bb 07 00 03 00 00 00 69 06 00 00 |.Z._........i...|
00001440 ee 5a f7 5f ff bb 07 00 03 00 01 00 ef 02 00 00 |.Z._............|
00001450 ee 5a f7 5f 05 bc 07 00 03 00 18 00 9e 0d 00 00 |.Z._............|
00001460 ee 5a f7 5f 0e bc 07 00 00 00 00 00 00 00 00 00 |.Z._............|
00001470 ee 5a f7 5f e1 e2 07 00 03 00 00 00 73 06 00 00 |.Z._........s...|
00001480 ee 5a f7 5f 04 e3 07 00 03 00 01 00 3f 03 00 00 |.Z._........?...|
00001490 ee 5a f7 5f 09 e3 07 00 03 00 18 00 77 0b 00 00 |.Z._........w...|
000014a0 ee 5a f7 5f 13 e3 07 00 00 00 00 00 00 00 00 00 |.Z._............|
000014b0 ee 5a f7 5f ff 09 08 00 03 00 00 00 82 06 00 00 |.Z._............|
000014c0 ee 5a f7 5f 23 0a 08 00 03 00 01 00 a3 03 00 00 |.Z._#...........|
000014d0 ee 5a f7 5f 28 0a 08 00 03 00 18 00 65 0b 00 00 |.Z._(.......e...|
000014e0 ee 5a f7 5f 33 0a 08 00 00 00 00 00 00 00 00 00 |.Z._3...........|
000014f0 ee 5a f7 5f 02 31 08 00 03 00 00 00 9e 06 00 00 |.Z._.1..........|
00001500 ee 5a f7 5f 24 31 08 00 03 00 01 00 ee 03 00 00 |.Z._$1..........|
00001510 ee 5a f7 5f 2a 31 08 00 03 00 18 00 0a 0b 00 00 |.Z._*1..........|
00001520 ee 5a f7 5f 34 31 08 00 00 00 00 00 00 00 00 00 |.Z._41..........|
00001530 ee 5a f7 5f 1f 58 08 00 03 00 00 00 c0 06 00 00 |.Z._.X..........|
00001540 ee 5a f7 5f 43 58 08 00 03 00 01 00 68 04 00 00 |.Z._CX......h...|
00001550 ee 5a f7 5f 49 58 08 00 03 00 18 00 b2 0a 00 00 |.Z._IX..........|
00001560 ee 5a f7 5f 53 58 08 00 00 00 00 00 00 00 00 00 |.Z._SX..........|
00001570 ee 5a f7 5f 23 7f 08 00 03 00 00 00 c9 06 00 00 |.Z._#...........|
00001580 ee 5a f7 5f 46 7f 08 00 03 00 01 00 b8 04 00 00 |.Z._F...........|
00001590 ee 5a f7 5f 4b 7f 08 00 03 00 18 00 78 09 00 00 |.Z._K.......x...|
000015a0 ee 5a f7 5f 55 7f 08 00 00 00 00 00 00 00 00 00 |.Z._U...........|
000015b0 ee 5a f7 5f 3d a6 08 00 03 00 00 00 ce 06 00 00 |.Z._=...........|
000015c0 ee 5a f7 5f 60 a6 08 00 03 00 01 00 ee 04 00 00 |.Z._`...........|
000015d0 ee 5a f7 5f 66 a6 08 00 03 00 18 00 00 09 00 00 |.Z._f...........|
000015e0 ee 5a f7 5f 70 a6 08 00 00 00 00 00 00 00 00 00 |.Z._p...........|
000015f0 ee 5a f7 5f 43 cd 08 00 03 00 00 00 e8 06 00 00 |.Z._C...........|
00001600 ee 5a f7 5f 65 cd 08 00 03 00 01 00 34 05 00 00 |.Z._e.......4...|
00001610 ee 5a f7 5f 6b cd 08 00 03 00 18 00 3d 08 00 00 |.Z._k.......=...|
00001620 ee 5a f7 5f 75 cd 08 00 00 00 00 00 00 00 00 00 |.Z._u...........|
00001630 ee 5a f7 5f 5f f4 08 00 03 00 00 00 09 07 00 00 |.Z.__...........|
00001640 ee 5a f7 5f 83 f4 08 00 03 00 01 00 a9 05 00 00 |.Z._............|
00001650 ee 5a f7 5f 88 f4 08 00 03 00 18 00 50 08 00 00 |.Z._........P...|
00001660 ee 5a f7 5f 92 f4 08 00 00 00 00 00 00 00 00 00 |.Z._............|
00001670 ee 5a f7 5f 60 1b 09 00 03 00 00 00 29 07 00 00 |.Z._`.......)...|
00001680 ee 5a f7 5f 83 1b 09 00 03 00 01 00 0f 06 00 00 |.Z._............|
00001690 ee 5a f7 5f 88 1b 09 00 03 00 18 00 8c 08 00 00 |.Z._............|
000016a0 ee 5a f7 5f 93 1b 09 00 00 00 00 00 00 00 00 00 |.Z._............|
000016b0 ee 5a f7 5f 78 42 09 00 03 00 00 00 4e 07 00 00 |.Z._xB......N...|
000016c0 ee 5a f7 5f 9d 42 09 00 03 00 01 00 77 06 00 00 |.Z._.B......w...|
000016d0 ee 5a f7 5f a3 42 09 00 03 00 18 00 c6 08 00 00 |.Z._.B..........|
000016e0 ee 5a f7 5f ad 42 09 00 00 00 00 00 00 00 00 00 |.Z._.B..........|
000016f0 ee 5a f7 5f 82 69 09 00 03 00 00 00 6c 07 00 00 |.Z._.i......l...|
00001700 ee 5a f7 5f a4 69 09 00 03 00 01 00 d2 06 00 00 |.Z._.i..........|
00001710 ee 5a f7 5f aa 69 09 00 03 00 18 00 22 0c 00 00 |.Z._.i......"...|
00001720 ee 5a f7 5f b4 69 09 00 00 00 00 00 00 00 00 00 |.Z._.i..........|
00001730 ee 5a f7 5f 9c 90 09 00 03 00 00 00 d0 07 00 00 |.Z._............|
00001740 ee 5a f7 5f c0 90 09 00 03 00 01 00 a8 07 00 00 |.Z._............|
00001750 ee 5a f7 5f c5 90 09 00 03 00 18 00 b9 09 00 00 |.Z._............|
00001760 ee 5a f7 5f cf 90 09 00 00 00 00 00 00 00 00 00 |.Z._............|
00001770 ee 5a f7 5f a0 b7 09 00 03 00 00 00 1c 08 00 00 |.Z._............|
00001780 ee 5a f7 5f c2 b7 09 00 03 00 01 00 64 08 00 00 |.Z._........d...|
00001790 ee 5a f7 5f c8 b7 09 00 03 00 18 00 bb 0a 00 00 |.Z._............|
000017a0 ee 5a f7 5f d2 b7 09 00 00 00 00 00 00 00 00 00 |.Z._............|
000017b0 ee 5a f7 5f bc de 09 00 03 00 00 00 38 08 00 00 |.Z._........8...|
000017c0 ee 5a f7 5f e1 de 09 00 03 00 01 00 06 09 00 00 |.Z._............|
000017d0 ee 5a f7 5f e6 de 09 00 03 00 18 00 86 08 00 00 |.Z._............|
000017e0 ee 5a f7 5f f1 de 09 00 00 00 00 00 00 00 00 00 |.Z._............|
000017f0 ee 5a f7 5f c1 05 0a 00 03 00 00 00 52 08 00 00 |.Z._........R...|
00001800 ee 5a f7 5f e3 05 0a 00 03 00 01 00 7c 09 00 00 |.Z._........|...|
00001810 ee 5a f7 5f e9 05 0a 00 03 00 18 00 18 08 00 00 |.Z._............|
00001820 ee 5a f7 5f f3 05 0a 00 00 00 00 00 00 00 00 00 |.Z._............|
00001830 ee 5a f7 5f f1 2c 0a 00 03 00 00 00 71 08 00 00 |.Z._.,......q...|
00001840 ee 5a f7 5f 15 2d 0a 00 03 00 01 00 e1 09 00 00 |.Z._.-..........|
00001850 ee 5a f7 5f 1b 2d 0a 00 03 00 18 00 ba 07 00 00 |.Z._.-..........|
00001860 ee 5a f7 5f 24 2d 0a 00 00 00 00 00 00 00 00 00 |.Z._$-..........|
00001870 ee 5a f7 5f e0 53 0a 00 03 00 00 00 82 08 00 00 |.Z._.S..........|
00001880 ee 5a f7 5f 03 54 0a 00 03 00 01 00 1c 0a 00 00 |.Z._.T..........|
00001890 ee 5a f7 5f 08 54 0a 00 03 00 18 00 be 07 00 00 |.Z._.T..........|
000018a0 ee 5a f7 5f 12 54 0a 00 00 00 00 00 00 00 00 00 |.Z._.T..........|
000018b0 ee 5a f7 5f fe 7a 0a 00 03 00 00 00 96 08 00 00 |.Z._.z..........|
000018c0 ee 5a f7 5f 23 7b 0a 00 03 00 01 00 78 0a 00 00 |.Z._#{......x...|
000018d0 ee 5a f7 5f 28 7b 0a 00 03 00 18 00 e8 07 00 00 |.Z._({..........|
000018e0 ee 5a f7 5f 32 7b 0a 00 00 00 00 00 00 00 00 00 |.Z._2{..........|
000018f0 ee 5a f7 5f 01 a2 0a 00 03 00 00 00 a4 08 00 00 |.Z._............|
00001900 ee 5a f7 5f 23 a2 0a 00 03 00 01 00 93 0a 00 00 |.Z._#...........|
00001910 ee 5a f7 5f 28 a2 0a 00 03 00 18 00 da 07 00 00 |.Z._(...........|
00001920 ee 5a f7 5f 33 a2 0a 00 00 00 00 00 00 00 00 00 |.Z._3...........|
00001930 ee 5a f7 5f 19 c9 0a 00 03 00 00 00 af 08 00 00 |.Z._............|
00001940 ee 5a f7 5f 3d c9 0a 00 03 00 01 00 c7 0a 00 00 |.Z._=...........|
00001950 ee 5a f7 5f 43 c9 0a 00 03 00 18 00 4c 07 00 00 |.Z._C.......L...|
00001960 ee 5a f7 5f 4d c9 0a 00 00 00 00 00 00 00 00 00 |.Z._M...........|
00001970 ee 5a f7 5f 20 f0 0a 00 03 00 00 00 b5 08 00 00 |.Z._ ...........|
00001980 ee 5a f7 5f 42 f0 0a 00 03 00 01 00 d0 0a 00 00 |.Z._B...........|
00001990 ee 5a f7 5f 48 f0 0a 00 03 00 18 00 44 07 00 00 |.Z._H.......D...|
000019a0 ee 5a f7 5f 52 f0 0a 00 00 00 00 00 00 00 00 00 |.Z._R...........|
000019b0 ee 5a f7 5f 3c 17 0b 00 03 00 00 00 ba 08 00 00 |.Z._<...........|
000019c0 ee 5a f7 5f 5e 17 0b 00 03 00 01 00 c6 0a 00 00 |.Z._^...........|
000019d0 ee 5a f7 5f 64 17 0b 00 03 00 18 00 23 07 00 00 |.Z._d.......#...|
000019e0 ee 5a f7 5f 6e 17 0b 00 00 00 00 00 00 00 00 00 |.Z._n...........|
000019f0 ee 5a f7 5f 40 3e 0b 00 03 00 00 00 bf 08 00 00 |.Z._@>..........|
00001a00 ee 5a f7 5f 61 3e 0b 00 03 00 01 00 be 0a 00 00 |.Z._a>..........|
00001a10 ee 5a f7 5f 68 3e 0b 00 03 00 18 00 29 07 00 00 |.Z._h>......)...|
00001a20 ee 5a f7 5f 71 3e 0b 00 00 00 00 00 00 00 00 00 |.Z._q>..........|
00001a30 ee 5a f7 5f 5c 65 0b 00 03 00 00 00 c3 08 00 00 |.Z._\e..........|
00001a40 ee 5a f7 5f 80 65 0b 00 03 00 01 00 b8 0a 00 00 |.Z._.e..........|
00001a50 ee 5a f7 5f 85 65 0b 00 03 00 18 00 27 07 00 00 |.Z._.e......'...|
00001a60 ee 5a f7 5f 8f 65 0b 00 00 00 00 00 00 00 00 00 |.Z._.e..........|
00001a70 ee 5a f7 5f 64 8c 0b 00 03 00 00 00 c8 08 00 00 |.Z._d...........|
00001a80 ee 5a f7 5f 87 8c 0b 00 03 00 01 00 9a 0a 00 00 |.Z._............|
00001a90 ee 5a f7 5f 8c 8c 0b 00 03 00 18 00 27 08 00 00 |.Z._........'...|
00001aa0 ee 5a f7 5f 96 8c 0b 00 00 00 00 00 00 00 00 00 |.Z._............|
00001ab0 ee 5a f7 5f 7b b3 0b 00 03 00 00 00 ba 08 00 00 |.Z._{...........|
00001ac0 ee 5a f7 5f 9f b3 0b 00 03 00 01 00 50 0a 00 00 |.Z._........P...|
00001ad0 ee 5a f7 5f a4 b3 0b 00 03 00 18 00 37 09 00 00 |.Z._........7...|
00001ae0 ee 5a f7 5f af b3 0b 00 00 00 00 00 00 00 00 00 |.Z._............|
00001af0 ee 5a f7 5f 7f da 0b 00 03 00 00 00 a2 08 00 00 |.Z._............|
00001b00 ee 5a f7 5f a1 da 0b 00 03 00 01 00 ca 09 00 00 |.Z._............|
00001b10 ee 5a f7 5f a6 da 0b 00 03 00 18 00 67 0b 00 00 |.Z._........g...|
00001b20 ee 5a f7 5f b0 da 0b 00 00 00 00 00 00 00 00 00 |.Z._............|
00001b30 ee 5a f7 5f 9c 01 0c 00 03 00 00 00 5f 08 00 00 |.Z._........_...|
00001b40 ee 5a f7 5f c0 01 0c 00 03 00 01 00 30 09 00 00 |.Z._........0...|
00001b50 ee 5a f7 5f c6 01 0c 00 03 00 18 00 f4 1b 00 00 |.Z._............|
00001b60 ee 5a f7 5f d0 01 0c 00 00 00 00 00 00 00 00 00 |.Z._............|
00001b70 ee 5a f7 5f a1 28 0c 00 03 00 00 00 30 08 00 00 |.Z._.(......0...|
00001b80 ee 5a f7 5f c4 28 0c 00 03 00 01 00 36 08 00 00 |.Z._.(......6...|
00001b90 ee 5a f7 5f ca 28 0c 00 03 00 18 00 2b 14 00 00 |.Z._.(......+...|
00001ba0 ee 5a f7 5f d4 28 0c 00 00 00 00 00 00 00 00 00 |.Z._.(..........|
00001bb0 ee 5a f7 5f 56 9c 0c 00 03 00 18 00 00 00 00 00 |.Z._V...........|
00001bc0 ee 5a f7 5f 7e 9c 0c 00 00 00 00 00 00 00 00 00 |.Z._~...........|
00001bd0 ff 5a f7 5f 43 ae 04 00 03 00 00 00 d0 0e 00 00 |.Z._C...........|
00001be0 ff 5a f7 5f 5a ae 04 00 03 00 01 00 7f 0a 00 00 |.Z._Z...........|
00001bf0 ff 5a f7 5f 60 ae 04 00 03 00 18 00 ff 28 00 00 |.Z._`........(..|
00001c00 ff 5a f7 5f 69 ae 04 00 00 00 00 00 00 00 00 00 |.Z._i...........|
00001c10 ff 5a f7 5f 79 fc 04 00 03 00 00 00 de 0e 00 00 |.Z._y...........|
00001c20 ff 5a f7 5f 9c fc 04 00 03 00 01 00 79 0a 00 00 |.Z._........y...|
00001c30 ff 5a f7 5f a2 fc 04 00 03 00 18 00 16 14 00 00 |.Z._............|
00001c40 ff 5a f7 5f ac fc 04 00 00 00 00 00 00 00 00 00 |.Z._............|
00001c50 ff 5a f7 5f ce 23 05 00 03 00 00 00 dd 0e 00 00 |.Z._.#..........|
00001c60 ff 5a f7 5f f2 23 05 00 03 00 01 00 73 0a 00 00 |.Z._.#......s...|
00001c70 ff 5a f7 5f f8 23 05 00 03 00 18 00 78 12 00 00 |.Z._.#......x...|
00001c80 ff 5a f7 5f 02 24 05 00 00 00 00 00 00 00 00 00 |.Z._.$..........|
00001c90 ff 5a f7 5f d0 4a 05 00 03 00 00 00 d9 0e 00 00 |.Z._.J..........|
00001ca0 ff 5a f7 5f f2 4a 05 00 03 00 01 00 6f 0a 00 00 |.Z._.J......o...|
00001cb0 ff 5a f7 5f f7 4a 05 00 03 00 18 00 52 12 00 00 |.Z._.J......R...|
00001cc0 ff 5a f7 5f 02 4b 05 00 00 00 00 00 00 00 00 00 |.Z._.K..........|
00001cd0 ff 5a f7 5f ef 71 05 00 03 00 01 00 68 0a 00 00 |.Z._.q......h...|
00001ce0 ff 5a f7 5f 13 72 05 00 03 00 18 00 25 12 00 00 |.Z._.r......%...|
00001cf0 ff 5a f7 5f 1d 72 05 00 00 00 00 00 00 00 00 00 |.Z._.r..........|
00001d00 ff 5a f7 5f f2 98 05 00 03 00 00 00 d6 0e 00 00 |.Z._............|
00001d10 ff 5a f7 5f 14 99 05 00 03 00 01 00 62 0a 00 00 |.Z._........b...|
00001d20 ff 5a f7 5f 1a 99 05 00 03 00 18 00 0e 12 00 00 |.Z._............|
00001d30 ff 5a f7 5f 24 99 05 00 00 00 00 00 00 00 00 00 |.Z._$...........|
00001d40 ff 5a f7 5f 31 c0 05 00 03 00 01 00 5d 0a 00 00 |.Z._1.......]...|
00001d50 ff 5a f7 5f 56 c0 05 00 03 00 18 00 df 11 00 00 |.Z._V...........|
00001d60 ff 5a f7 5f 60 c0 05 00 00 00 00 00 00 00 00 00 |.Z._`...........|
00001d70 ff 5a f7 5f 13 e7 05 00 03 00 00 00 d4 0e 00 00 |.Z._............|
00001d80 ff 5a f7 5f 35 e7 05 00 03 00 01 00 57 0a 00 00 |.Z._5.......W...|
00001d90 ff 5a f7 5f 3b e7 05 00 03 00 18 00 c6 11 00 00 |.Z._;...........|
00001da0 ff 5a f7 5f 45 e7 05 00 00 00 00 00 00 00 00 00 |.Z._E...........|
00001db0 ff 5a f7 5f 28 0e 06 00 03 00 00 00 d0 0e 00 00 |.Z._(...........|
00001dc0 ff 5a f7 5f 4d 0e 06 00 03 00 01 00 52 0a 00 00 |.Z._M.......R...|
00001dd0 ff 5a f7 5f 53 0e 06 00 03 00 18 00 91 11 00 00 |.Z._S...........|
00001de0 ff 5a f7 5f 5d 0e 06 00 00 00 00 00 00 00 00 00 |.Z._]...........|
00001df0 ff 5a f7 5f 2f 35 06 00 03 00 00 00 ce 0e 00 00 |.Z._/5..........|
00001e00 ff 5a f7 5f 51 35 06 00 03 00 01 00 4c 0a 00 00 |.Z._Q5......L...|
00001e10 ff 5a f7 5f 57 35 06 00 03 00 18 00 8a 11 00 00 |.Z._W5..........|
00001e20 ff 5a f7 5f 61 35 06 00 00 00 00 00 00 00 00 00 |.Z._a5..........|
00001e30 ff 5a f7 5f 50 5c 06 00 03 00 00 00 cc 0e 00 00 |.Z._P\..........|
00001e40 ff 5a f7 5f 74 5c 06 00 03 00 01 00 46 0a 00 00 |.Z._t\......F...|
00001e50 ff 5a f7 5f 79 5c 06 00 03 00 18 00 2f 11 00 00 |.Z._y\....../...|
00001e60 ff 5a f7 5f 83 5c 06 00 00 00 00 00 00 00 00 00 |.Z._.\..........|
00001e70 ff 5a f7 5f 53 83 06 00 03 00 00 00 c6 0e 00 00 |.Z._S...........|
00001e80 ff 5a f7 5f 75 83 06 00 03 00 01 00 40 0a 00 00 |.Z._u.......@...|
00001e90 ff 5a f7 5f 7b 83 06 00 03 00 18 00 72 11 00 00 |.Z._{.......r...|
00001ea0 ff 5a f7 5f 85 83 06 00 00 00 00 00 00 00 00 00 |.Z._............|
00001eb0 ff 5a f7 5f 6d aa 06 00 03 00 00 00 c7 0e 00 00 |.Z._m...........|
00001ec0 ff 5a f7 5f 91 aa 06 00 03 00 01 00 3d 0a 00 00 |.Z._........=...|
00001ed0 ff 5a f7 5f 97 aa 06 00 03 00 18 00 3c 11 00 00 |.Z._........<...|
00001ee0 ff 5a f7 5f a1 aa 06 00 00 00 00 00 00 00 00 00 |.Z._............|
00001ef0 ff 5a f7 5f 72 d1 06 00 03 00 00 00 c6 0e 00 00 |.Z._r...........|
00001f00 ff 5a f7 5f 94 d1 06 00 03 00 01 00 3c 0a 00 00 |.Z._........<...|
00001f10 ff 5a f7 5f 9a d1 06 00 03 00 18 00 07 11 00 00 |.Z._............|
00001f20 ff 5a f7 5f a4 d1 06 00 00 00 00 00 00 00 00 00 |.Z._............|
00001f30 ff 5a f7 5f 8d f8 06 00 03 00 00 00 c4 0e 00 00 |.Z._............|
00001f40 ff 5a f7 5f b2 f8 06 00 03 00 01 00 39 0a 00 00 |.Z._........9...|
00001f50 ff 5a f7 5f b8 f8 06 00 03 00 18 00 e1 10 00 00 |.Z._............|
00001f60 ff 5a f7 5f c2 f8 06 00 00 00 00 00 00 00 00 00 |.Z._............|
00001f70 ff 5a f7 5f 8f 1f 07 00 03 00 00 00 c6 0e 00 00 |.Z._............|
00001f80 ff 5a f7 5f b1 1f 07 00 03 00 01 00 38 0a 00 00 |.Z._........8...|
00001f90 ff 5a f7 5f b7 1f 07 00 03 00 18 00 eb 10 00 00 |.Z._............|
00001fa0 ff 5a f7 5f c0 1f 07 00 00 00 00 00 00 00 00 00 |.Z._............|
00001fb0 ff 5a f7 5f a9 46 07 00 03 00 00 00 c5 0e 00 00 |.Z._.F..........|
00001fc0 ff 5a f7 5f cd 46 07 00 03 00 01 00 34 0a 00 00 |.Z._.F......4...|
00001fd0 ff 5a f7 5f d4 46 07 00 03 00 18 00 e7 10 00 00 |.Z._.F..........|
00001fe0 ff 5a f7 5f dd 46 07 00 00 00 00 00 00 00 00 00 |.Z._.F..........|
00001ff0 ff 5a f7 5f b4 6d 07 00 03 00 00 00 c3 0e 00 00 |.Z._.m..........|
00002000 ff 5a f7 5f d5 6d 07 00 03 00 01 00 33 0a 00 00 |.Z._.m......3...|
00002010 ff 5a f7 5f db 6d 07 00 03 00 18 00 e0 10 00 00 |.Z._.m..........|
00002020 ff 5a f7 5f e5 6d 07 00 00 00 00 00 00 00 00 00 |.Z._.m..........|
00002030 ff 5a f7 5f cc 94 07 00 03 00 00 00 c2 0e 00 00 |.Z._............|
00002040 ff 5a f7 5f f1 94 07 00 03 00 01 00 34 0a 00 00 |.Z._........4...|
00002050 ff 5a f7 5f f6 94 07 00 03 00 18 00 c5 10 00 00 |.Z._............|
00002060 ff 5a f7 5f 00 95 07 00 00 00 00 00 00 00 00 00 |.Z._............|
00002070 ff 5a f7 5f d1 bb 07 00 03 00 00 00 c3 0e 00 00 |.Z._............|
00002080 ff 5a f7 5f f3 bb 07 00 03 00 01 00 32 0a 00 00 |.Z._........2...|
00002090 ff 5a f7 5f f8 bb 07 00 03 00 18 00 ad 10 00 00 |.Z._............|
000020a0 ff 5a f7 5f 03 bc 07 00 00 00 00 00 00 00 00 00 |.Z._............|
000020b0 ff 5a f7 5f ee e2 07 00 03 00 00 00 c1 0e 00 00 |.Z._............|
000020c0 ff 5a f7 5f 13 e3 07 00 03 00 01 00 31 0a 00 00 |.Z._........1...|
000020d0 ff 5a f7 5f 19 e3 07 00 03 00 18 00 c7 10 00 00 |.Z._............|
000020e0 ff 5a f7 5f 23 e3 07 00 00 00 00 00 00 00 00 00 |.Z._#...........|
000020f0 ff 5a f7 5f f3 09 08 00 03 00 01 00 32 0a 00 00 |.Z._........2...|
00002100 ff 5a f7 5f 15 0a 08 00 03 00 18 00 e0 10 00 00 |.Z._............|
00002110 ff 5a f7 5f 1f 0a 08 00 00 00 00 00 00 00 00 00 |.Z._............|
00002120 ff 5a f7 5f 0c 31 08 00 03 00 00 00 c0 0e 00 00 |.Z._.1..........|
00002130 ff 5a f7 5f 34 31 08 00 03 00 18 00 f2 10 00 00 |.Z._41..........|
00002140 ff 5a f7 5f 3e 31 08 00 00 00 00 00 00 00 00 00 |.Z._>1..........|
00002150 ff 5a f7 5f 13 58 08 00 03 00 00 00 c2 0e 00 00 |.Z._.X..........|
00002160 ff 5a f7 5f 34 58 08 00 03 00 01 00 38 0a 00 00 |.Z._4X......8...|
00002170 ff 5a f7 5f 3a 58 08 00 03 00 18 00 9f 11 00 00 |.Z._:X..........|
00002180 ff 5a f7 5f 44 58 08 00 00 00 00 00 00 00 00 00 |.Z._DX..........|
00002190 ff 5a f7 5f 2d 7f 08 00 03 00 00 00 c4 0e 00 00 |.Z._-...........|
000021a0 ff 5a f7 5f 51 7f 08 00 03 00 01 00 3c 0a 00 00 |.Z._Q.......<...|
000021b0 ff 5a f7 5f 56 7f 08 00 03 00 18 00 0c 18 00 00 |.Z._V...........|
000021c0 ff 5a f7 5f 61 7f 08 00 00 00 00 00 00 00 00 00 |.Z._a...........|
000021d0 ff 5a f7 5f d5 f2 08 00 03 00 18 00 00 00 00 00 |.Z._............|
000021e0 ff 5a f7 5f fc f2 08 00 00 00 00 00 00 00 00 00 |.Z._............|
000021f0 ff 5a f7 5f dc a4 0c 00 03 00 00 00 e5 0e 00 00 |.Z._............|
00002200 ff 5a f7 5f 00 a5 0c 00 03 00 01 00 af 0a 00 00 |.Z._............|
00002210 ff 5a f7 5f 06 a5 0c 00 03 00 18 00 92 13 00 00 |.Z._............|
00002220 ff 5a f7 5f 10 a5 0c 00 00 00 00 00 00 00 00 00 |.Z._............|
00002230 ff 5a f7 5f e3 c4 0c 00 03 00 00 00 e1 0e 00 00 |.Z._............|
00002240 ff 5a f7 5f 06 c5 0c 00 03 00 01 00 ae 0a 00 00 |.Z._............|
00002250 ff 5a f7 5f 0b c5 0c 00 03 00 18 00 bd 11 00 00 |.Z._............|
00002260 ff 5a f7 5f 15 c5 0c 00 00 00 00 00 00 00 00 00 |.Z._............|
00002270 ff 5a f7 5f 14 ec 0c 00 03 00 00 00 de 0e 00 00 |.Z._............|
00002280 ff 5a f7 5f 27 ec 0c 00 03 00 01 00 b0 0a 00 00 |.Z._'...........|
00002290 ff 5a f7 5f 2d ec 0c 00 03 00 18 00 6c 12 00 00 |.Z._-.......l...|
000022a0 ff 5a f7 5f 37 ec 0c 00 00 00 00 00 00 00 00 00 |.Z._7...........|
000022b0 ff 5a f7 5f 02 13 0d 00 03 00 00 00 e5 0e 00 00 |.Z._............|
000022c0 ff 5a f7 5f 28 13 0d 00 03 00 18 00 ca 10 00 00 |.Z._(...........|
000022d0 ff 5a f7 5f 32 13 0d 00 00 00 00 00 00 00 00 00 |.Z._2...........|
000022e0 ff 5a f7 5f 1c 3a 0d 00 03 00 00 00 e7 0e 00 00 |.Z._.:..........|
000022f0 ff 5a f7 5f 40 3a 0d 00 03 00 01 00 af 0a 00 00 |.Z._@:..........|
00002300 ff 5a f7 5f 46 3a 0d 00 03 00 18 00 c0 10 00 00 |.Z._F:..........|
00002310 ff 5a f7 5f 50 3a 0d 00 00 00 00 00 00 00 00 00 |.Z._P:..........|
00002320 ff 5a f7 5f 20 61 0d 00 03 00 00 00 e8 0e 00 00 |.Z._ a..........|
00002330 ff 5a f7 5f 42 61 0d 00 03 00 01 00 ae 0a 00 00 |.Z._Ba..........|
00002340 ff 5a f7 5f 48 61 0d 00 03 00 18 00 b4 10 00 00 |.Z._Ha..........|
00002350 ff 5a f7 5f 52 61 0d 00 00 00 00 00 00 00 00 00 |.Z._Ra..........|
00002360 ff 5a f7 5f 3f 88 0d 00 03 00 01 00 ab 0a 00 00 |.Z._?...........|
00002370 ff 5a f7 5f 65 88 0d 00 03 00 18 00 8a 10 00 00 |.Z._e...........|
00002380 ff 5a f7 5f 6f 88 0d 00 00 00 00 00 00 00 00 00 |.Z._o...........|
00002390 ff 5a f7 5f 43 af 0d 00 03 00 01 00 a9 0a 00 00 |.Z._C...........|
000023a0 ff 5a f7 5f 65 af 0d 00 03 00 18 00 78 10 00 00 |.Z._e.......x...|
000023b0 ff 5a f7 5f 6f af 0d 00 00 00 00 00 00 00 00 00 |.Z._o...........|
000023c0 ff 5a f7 5f 5c d6 0d 00 03 00 01 00 a6 0a 00 00 |.Z._\...........|
000023d0 ff 5a f7 5f 80 d6 0d 00 03 00 18 00 7a 10 00 00 |.Z._........z...|
000023e0 ff 5a f7 5f 8a d6 0d 00 00 00 00 00 00 00 00 00 |.Z._............|
000023f0 ff 5a f7 5f 61 fd 0d 00 03 00 00 00 ea 0e 00 00 |.Z._a...........|
00002400 ff 5a f7 5f 84 fd 0d 00 03 00 01 00 a5 0a 00 00 |.Z._............|
00002410 ff 5a f7 5f 92 fd 0d 00 00 00 00 00 00 00 00 00 |.Z._............|
00002420 ff 5a f7 5f 7b 24 0e 00 03 00 00 00 e8 0e 00 00 |.Z._{$..........|
00002430 ff 5a f7 5f a0 24 0e 00 03 00 01 00 a1 0a 00 00 |.Z._.$..........|
00002440 ff 5a f7 5f a5 24 0e 00 03 00 18 00 76 10 00 00 |.Z._.$......v...|
00002450 ff 5a f7 5f af 24 0e 00 00 00 00 00 00 00 00 00 |.Z._.$..........|
00002460 ff 5a f7 5f 88 4b 0e 00 03 00 18 00 78 10 00 00 |.Z._.K......x...|
00002470 ff 5a f7 5f ae 4b 0e 00 00 00 00 00 00 00 00 00 |.Z._.K..........|
00002480 ff 5a f7 5f 9a 72 0e 00 03 00 00 00 e6 0e 00 00 |.Z._.r..........|
00002490 ff 5a f7 5f be 72 0e 00 03 00 01 00 a0 0a 00 00 |.Z._.r..........|
000024a0 ff 5a f7 5f c3 72 0e 00 03 00 18 00 b4 10 00 00 |.Z._.r..........|
000024b0 ff 5a f7 5f cd 72 0e 00 00 00 00 00 00 00 00 00 |.Z._.r..........|
000024c0 ff 5a f7 5f a4 99 0e 00 03 00 00 00 df 0e 00 00 |.Z._............|
000024d0 ff 5a f7 5f c6 99 0e 00 03 00 01 00 9f 0a 00 00 |.Z._............|
000024e0 ff 5a f7 5f cb 99 0e 00 03 00 18 00 6d 11 00 00 |.Z._........m...|
000024f0 ff 5a f7 5f d5 99 0e 00 00 00 00 00 00 00 00 00 |.Z._............|
00002500 ff 5a f7 5f bb c0 0e 00 03 00 00 00 cd 0e 00 00 |.Z._............|
00002510 ff 5a f7 5f df c0 0e 00 03 00 01 00 9c 0a 00 00 |.Z._............|
00002520 ff 5a f7 5f e5 c0 0e 00 03 00 18 00 71 2a 00 00 |.Z._........q*..|
00002530 ff 5a f7 5f ef c0 0e 00 00 00 00 00 00 00 00 00 |.Z._............|
00002540 ff 5a f7 5f 64 34 0f 00 03 00 18 00 00 00 00 00 |.Z._d4..........|
00002550 ff 5a f7 5f 8a 34 0f 00 00 00 00 00 00 00 00 00 |.Z._.4..........|
00002560 00 5b f7 5f 6c 92 01 00 03 00 00 00 c4 0e 00 00 |.[._l...........|
00002570 00 5b f7 5f 82 92 01 00 03 00 18 00 02 14 00 00 |.[._............|
00002580 00 5b f7 5f 8c 92 01 00 00 00 00 00 00 00 00 00 |.[._............|
00002590 00 5b f7 5f 79 a1 01 00 03 00 00 00 ca 0e 00 00 |.[._y...........|
000025a0 00 5b f7 5f 8f a1 01 00 03 00 01 00 9d 0a 00 00 |.[._............|
000025b0 00 5b f7 5f 94 a1 01 00 03 00 18 00 a3 11 00 00 |.[._............|
000025c0 00 5b f7 5f 9d a1 01 00 00 00 00 00 00 00 00 00 |.[._............|
000025d0 00 5b f7 5f 6b c8 01 00 03 00 00 00 bb 0e 00 00 |.[._k...........|
000025e0 00 5b f7 5f 8f c8 01 00 03 00 01 00 98 0a 00 00 |.[._............|
000025f0 00 5b f7 5f 95 c8 01 00 03 00 18 00 b9 12 00 00 |.[._............|
00002600 00 5b f7 5f 9f c8 01 00 00 00 00 00 00 00 00 00 |.[._............|
00002610 00 5b f7 5f 74 ef 01 00 03 00 00 00 c3 0e 00 00 |.[._t...........|
00002620 00 5b f7 5f 96 ef 01 00 03 00 01 00 94 0a 00 00 |.[._............|
00002630 00 5b f7 5f 9c ef 01 00 03 00 18 00 17 11 00 00 |.[._............|
00002640 00 5b f7 5f a6 ef 01 00 00 00 00 00 00 00 00 00 |.[._............|
00002650 00 5b f7 5f 8d 16 02 00 03 00 00 00 c5 0e 00 00 |.[._............|
00002660 00 5b f7 5f b2 16 02 00 03 00 01 00 90 0a 00 00 |.[._............|
00002670 00 5b f7 5f b8 16 02 00 03 00 18 00 ce 10 00 00 |.[._............|
00002680 00 5b f7 5f c2 16 02 00 00 00 00 00 00 00 00 00 |.[._............|
00002690 00 5b f7 5f 8e 3d 02 00 03 00 00 00 c6 0e 00 00 |.[._.=..........|
000026a0 00 5b f7 5f af 3d 02 00 03 00 01 00 8c 0a 00 00 |.[._.=..........|
000026b0 00 5b f7 5f b5 3d 02 00 03 00 18 00 c9 10 00 00 |.[._.=..........|
000026c0 00 5b f7 5f bf 3d 02 00 00 00 00 00 00 00 00 00 |.[._.=..........|
000026d0 00 5b f7 5f a8 64 02 00 03 00 00 00 c7 0e 00 00 |.[._.d..........|
000026e0 00 5b f7 5f cd 64 02 00 03 00 01 00 89 0a 00 00 |.[._.d..........|
000026f0 00 5b f7 5f d3 64 02 00 03 00 18 00 a9 10 00 00 |.[._.d..........|
00002700 00 5b f7 5f dc 64 02 00 00 00 00 00 00 00 00 00 |.[._.d..........|
00002710 00 5b f7 5f b4 8b 02 00 03 00 00 00 c4 0e 00 00 |.[._............|
00002720 00 5b f7 5f d6 8b 02 00 03 00 01 00 87 0a 00 00 |.[._............|
00002730 00 5b f7 5f dc 8b 02 00 03 00 18 00 96 10 00 00 |.[._............|
00002740 00 5b f7 5f e5 8b 02 00 00 00 00 00 00 00 00 00 |.[._............|
00002750 00 5b f7 5f ca b2 02 00 03 00 00 00 c8 0e 00 00 |.[._............|
00002760 00 5b f7 5f ee b2 02 00 03 00 01 00 86 0a 00 00 |.[._............|
00002770 00 5b f7 5f f4 b2 02 00 03 00 18 00 7a 10 00 00 |.[._........z...|
00002780 00 5b f7 5f fe b2 02 00 00 00 00 00 00 00 00 00 |.[._............|
00002790 00 5b f7 5f d2 d9 02 00 03 00 00 00 c6 0e 00 00 |.[._............|
000027a0 00 5b f7 5f f4 d9 02 00 03 00 01 00 84 0a 00 00 |.[._............|
000027b0 00 5b f7 5f f9 d9 02 00 03 00 18 00 6b 10 00 00 |.[._........k...|
000027c0 00 5b f7 5f 03 da 02 00 00 00 00 00 00 00 00 00 |.[._............|
000027d0 00 5b f7 5f f2 00 03 00 03 00 18 00 7f 10 00 00 |.[._............|
000027e0 00 5b f7 5f 1b 01 03 00 00 00 00 00 00 00 00 00 |.[._............|
000027f0 00 5b f7 5f ef 27 03 00 03 00 00 00 bc 0e 00 00 |.[._.'..........|
00002800 00 5b f7 5f 12 28 03 00 03 00 01 00 82 0a 00 00 |.[._.(..........|
00002810 00 5b f7 5f 17 28 03 00 03 00 18 00 c7 11 00 00 |.[._.(..........|
00002820 00 5b f7 5f 21 28 03 00 00 00 00 00 00 00 00 00 |.[._!(..........|
00002830 00 5b f7 5f a6 9b 03 00 03 00 18 00 00 00 00 00 |.[._............|
00002840 00 5b f7 5f cf 9b 03 00 00 00 00 00 00 00 00 00 |.[._............|
00002850 00 5b f7 5f 44 06 05 00 03 00 00 00 d6 0e 00 00 |.[._D...........|
00002860 00 5b f7 5f 66 06 05 00 03 00 01 00 74 0a 00 00 |.[._f.......t...|
00002870 00 5b f7 5f 6c 06 05 00 03 00 18 00 46 12 00 00 |.[._l.......F...|
00002880 00 5b f7 5f 76 06 05 00 00 00 00 00 00 00 00 00 |.[._v...........|
00002890 00 5b f7 5f ce 23 05 00 03 00 01 00 73 0a 00 00 |.[._.#......s...|
000028a0 00 5b f7 5f f4 23 05 00 03 00 18 00 c9 10 00 00 |.[._.#..........|
000028b0 00 5b f7 5f fd 23 05 00 00 00 00 00 00 00 00 00 |.[._.#..........|
000028c0 00 5b f7 5f d0 4a 05 00 03 00 00 00 d4 0e 00 00 |.[._.J..........|
000028d0 00 5b f7 5f f2 4a 05 00 03 00 01 00 74 0a 00 00 |.[._.J......t...|
000028e0 00 5b f7 5f f8 4a 05 00 03 00 18 00 c7 10 00 00 |.[._.J..........|
000028f0 00 5b f7 5f 01 4b 05 00 00 00 00 00 00 00 00 00 |.[._.K..........|
00002900 00 5b f7 5f ec 71 05 00 03 00 00 00 de 0e 00 00 |.[._.q..........|
00002910 00 5b f7 5f 14 72 05 00 03 00 18 00 91 10 00 00 |.[._.r..........|
00002920 00 5b f7 5f 1e 72 05 00 00 00 00 00 00 00 00 00 |.[._.r..........|
import struct
#f = open("/dev/input/mice", "rb");
f = open("/dev/input/event1", "rb");
while 1:
data = f.read(3)
print struct.unpack('3b',data)
It is also well possible that there isn't anything generated at all. In that case Linux or SDL has no means to know that some part of your LCD is labeled as a soft button. That is up to you to manage, using the coordinates from the touchscreen.
If I put the pen stick in a fixed position, the coordinates (x,y) oscillate both around 6 values.That is quite typical for resistive touch panels, I guess.
I have also noticed that if I move the pen-stick to the position of one of five the icon-buttons, I see its (x,y) coordinates.Yup, so they are not buttons at all, just drawings in an area outside the display, but within the touch panel.
Note that the jitter in the coordinates is usually not because of the touch panel itself, but more because of the low precision of the ADCs used.
uname -r
2.6.23-proof
If there is any room in the enclosure, and it has SPI/I2C/serial pins you can interface to, you can use the same panel but your own touch controller, say based on TI TSC2046EIPWR or similar
Also, instead of doing the touch screen adjustments and filtering in SDL, it is possible to use a simple daemon that grabs the input event device, and provides its own filtered input device.
Don't know, I bought it second hand deal. I know it was priced 500 euro back in 2000. Crappy ADC? Too early technology with the touchscreen film? Who knows. And on the top of this, every ADC is affected by noise in a way you have to filter its samples. Which brings me to question about the kernel driver module, which is not the official one because the dropped the support after the last kernel v2.4, the v2.6 was never support, so what(1) I am using is clearly made by an hobbyist and it doesn't filter anything.Do you have the sources for the driver? I'd like to take a looksee.
However, this is a great idea for a second similar project: take my old 14.1" laptop, and convert it into a tablet by adding a resistive touchscreen film on the top of the screen.Capacitive multitouch panels are nicer, though; I recommend one with an integrated USB controller. They should provide a standard USB HID touch panel interface, so no drivers should be needed at all. At 14.1" inches, I think a resistive one will be much cheaper, though. (I do believe a Teensy LC (https://www.pjrc.com/store/teensylc.html) would make for a pretty good resistive touch controller; its ADC has 12+ bits (16 bits, but 12-13 effective/noise-free bits), it's cheap and small, has native USB (so will support USB HID, and no drivers needed!), and it is very nice to program in Arduino via Teensyduino add-on. All you need is to connect the four resistive touch panel connectors to suitable pins on the Teensy LC.)
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
#include <linux/input.h>
#define EVENT_DEVICE "/dev/input/event1"
#define EVENT_TYPE EV_ABS
#define EVENT_CODE_X ABS_X
#define EVENT_CODE_Y ABS_Y
int main()
struct input_event ev;
int fd;
char name[256] = "Unknown";
fd = open(EVENT_DEVICE, O_RDONLY);
if (fd == -1)
fprintf(stderr, "%s is not a vaild device\n", EVENT_DEVICE);
return EXIT_FAILURE;
ioctl(fd, EVIOCGNAME(sizeof(name)), name);
printf("%s\n", name);
# ./devicename
Corgi Touchscreen
Which kernel version can you run, otherwise, on that hardware?
Have you opened the device to look at what chip handles the touchscreen?
I wrote this simple program to see the device-name.
Which is reported as:Code: [Select]# ./devicename
Corgi Touchscreen
I wrote this simple program to see the device-name.I would have thought that
cat /sys/class/input/event1/device/name
would have been easier! ;D
cat: /sys/class/input/event1/device/name: No such file or directory
yup, but for certain incomprehensible reasons it's not supported :oCode: [Select]cat /sys/class/input/event1/device/name
mount -t sysfs sysfs /sys
Probably sysfs is not mounted. Try:
ls /sys/class/input/event1/device/
bus/ driver/ input:input1/ modalias power/ subsystem/ uevent
TI ADS7846
Are you sure the latest kernels do not work?
The PDA looks a modified clone of a commercial product, this mean nothing does work without specific patches. I haven't yet received sources, but the previous owner has already told me that there are a lot of patches applied to vanilla, and without them nothing does work.Oh, okay.
What I really need is a TS-daemon, in the way you described above.Do you need a skeleton to get started? This laptop has a touchpad and a nipple, so it wouldn't be difficult to whip one up.
Oh, okay
OpenSSL: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
Unable to establish SSL connection.
Writing your own tiny framebuffer functions
With libpng, you can load and save PNG images natively.
Yup, there is no 2D accelerator, there is just a simple framebuffer. Yesterday, I partially wrote something similar. LCD_Pixel_Set(x,y,color) is already working. All the rest still needs to be written, but hey? That function is the most important graphic primitive :DRight. Since the two image buffers reside in RAM, having the underlying image with the same pixel format as the framebuffer makes things easier. The overlay, however, could be 8 or even 4 bit indexed color, saving memory. A scribble_putpixel(x,y,color) will modify the scribble buffer, and update the framebuffer too. You'll eventually implement a scribble_line(x0,y0,x1,y1,color), I bet; a trick with the 4 bit indexed color in the pairwise direction is to do two step iterations in each loop iteration (and thus update either 2 or 4 pixels in the framebuffer), except for an initial odd pixel and/or a final odd pixel that you handle separately. In the nonpairwise direction, there is no special magic needed to be efficient.
Yes, please. I have never written anything similar.Already wrote the initial part, until some lint or something got underneath my dash and up keys on my laptop keyboard, and now they don't work. Neither vacuum nor pressured air seems to dislodge it. >:(
CC := gcc
LDFLAGS := -lm
PROGS := event-pup
.PHONY: all clean
all: $(PROGS)
clean:
rm -f $(PROGS) known-keys.h
known-keys.h:
./generate-known-keys
pup.c: known-keys.h
event-pup: pup.c
#!/bin/sh
rm -f known-keys.h
printf '#ifndef KNOWN_KEYS_H\n'
printf '#define KNOWN_KEYS_H\n'
printf '#include <stdint.h>\n'
printf '#include <linux/input.h>\n'
printf '\n'
printf 'static const struct {\n'
printf ' const char *const name;\n'
printf ' const uint_fast16_t code;\n'
printf '} known_keys[] = {\n'
gcc -E -dM /usr/include/linux/input.h | awk '$1 == "#define" && $2 ~ /^KEY_/ { printf " { .name = %-19s .code = %s },\n", "\"" substr($2, 5) "\",", $2 }' | sort -u
printf ' { .name = NULL, .code = 0 }\n'
printf '};\n'
printf '\n'
printf '#endif /* KNOWN_KEYS_H */\n'
) > known-keys.h
// SPDX-License-Identifier: GPL3
#include <stdlib.h>
#include <stdint.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/ioctl.h>
#include <fcntl.h>
#include <linux/uinput.h>
#include <signal.h>
#include <string.h>
#include <stdio.h>
#include <math.h>
#include <errno.h>
#include "known-keys.h"
#ifndef USB_VENDOR
#define USB_VENDOR 0xDEAD
#endif
#ifndef USB_PRODUCT
#define USB_PRODUCT 0xBEEF
#endif
#ifndef USB_VERSION
#define USB_VERSION 0
#endif
#ifndef USB_NAME
#define USB_NAME "Puppers"
#endif
#ifndef X_MIN
#define X_MIN 0
#endif
#ifndef X_MAX
#define X_MAX 2047
#endif
#ifndef Y_MIN
#define Y_MIN 0
#endif
#ifndef Y_MAX
#define Y_MAX 2047
#endif
#ifndef P_MIN
#define P_MIN 0
#endif
#ifndef P_MAX
#define P_MAX 1023
#endif
* USB vendor:product the synthesized event device will appear as
#if UINPUT_VERSION >= 5
static struct uinput_setup device = {
.id = { .bustype = BUS_USB,
.vendor = USB_VENDOR,
.product = USB_PRODUCT,
.version = USB_VERSION },
.name = USB_NAME,
#else
static struct uinput_user_dev device = {
.name = USB_NAME,
#endif
* Absolute axes
static struct input_absinfo x_axis = { .value = X_MIN + (X_MAX - X_MIN)/2,
.minimum = X_MIN,
.maximum = X_MAX,
.fuzz = 0,
.flat = 0,
.resolution = 15,
static struct input_absinfo y_axis = { .value = Y_MIN + (Y_MAX - Y_MIN)/2,
.minimum = Y_MIN,
.maximum = Y_MAX,
.fuzz = 0,
.flat = 0,
.resolution = 15,
static struct input_absinfo p_axis = { .value = P_MIN + (P_MAX - P_MIN)/2,
.minimum = P_MIN,
.maximum = P_MAX,
.fuzz = 0,
.flat = 0,
.resolution = 0,
* Coordinate transformation matrix in Q15.16 format
static int_fast32_t transform[6] = { 65536,0,0, 0,65536,0 }; /* Identity transform, { 1.0,0.0,0.0, 0.0,1.0,0.0 } */
static inline int_fast32_t transform_x(const int_fast32_t x, const int_fast32_t y)
return ( (int_fast64_t)x * (int_fast64_t)transform[0] +
(int_fast64_t)y * (int_fast64_t)transform[1] +
(int_fast64_t)transform[2] ) / 65536;
static inline int_fast32_t transform_y(const int_fast64_t x, const int_fast64_t y)
return ( (int_fast64_t)x * (int_fast64_t)transform[3] +
(int_fast64_t)y * (int_fast64_t)transform[4] +
(int_fast64_t)transform[5] ) / 65536;
* Virtual button descriptions - in untransformed coordinates
struct vbutton {
int_fast32_t xmin;
int_fast32_t ymin;
int_fast32_t xmax;
int_fast32_t ymax;
uint_fast16_t code;
uint_fast16_t state;
static size_t vbuttons_max = 0;
static size_t vbuttons = 0;
static struct vbutton *vbutton = NULL;
* Signal handler for basic INT/HUP/TERM support
static volatile sig_atomic_t done;
static void handle_done(int signum)
done = signum;
static int install_done(int signum)
struct sigaction act;
memset(&act, 0, sizeof act);
sigemptyset(&act.sa_mask);
act.sa_handler = handle_done;
act.sa_flags = 0; /* We do not want SA_RESTART; we want the EINTR errors at signal delivery. */
if (sigaction(signum, &act, NULL) == -1)
return errno;
return 0;
* Parsing command-line options
static int parse_usb_name(const char *src)
const size_t src_len = (src) ? strlen(src) : 0;
if (src_len < 1 || src_len > sizeof device.name)
return EINVAL;
memset(device.name, 0, sizeof device.name);
memcpy(device.name, src, src_len);
return 0;
static int parse_usb_vendor_product(const char *src)
const char *end;
unsigned long vendor, product;
if (!src || !*src)
return EINVAL;
end = src;
errno = 0;
vendor = strtoul(src, (char **)(&end), 16); /* Always in hex! */
if (errno)
return errno;
if (src == end || vendor > 0xFFFFF)
return EINVAL;
/* Skip whitespace and colon. */
end += strspn(end, "\t\n\v\f\r :");
src = end;
errno = 0;
product = strtoul(src, (char **)(&end), 16); /* Always in hex! */
if (errno)
return errno;
if (src == end || product > 0xFFFF)
return EINVAL;
/* Skip trailing whitespace, so we can check for trailing garbage. */
end += strspn(end, "\t\n\v\f\r ");
if (*end)
return EINVAL;
device.id.vendor = vendor;
device.id.product = product;
return 0;
static int parse_transform(const char *src)
const char *end = src;
double value[6];
int arg;
if (!src || !*src)
return EINVAL;
for (arg = 0; arg < 6; arg++) {
/* Skip leading whitespace and separators. */
end += strspn(end, "\t\n\v\f\r ,/:");
src = end;
/* Parse floating-point coefficient. */
errno = 0;
value[arg] = strtod(src, (char **)(&end));
if (errno)
return errno;
if (src == end)
return EINVAL;
/* Scale to fixed point. */
value[arg] = round(value[arg] / 65536.0);
if (value[arg] < (double)INT32_MIN || value[arg] > (double)INT32_MAX)
return ERANGE;
/* Skip trailing whitespace. */
/* Garbage at end of string? */
if (*end)
return EINVAL;
transform[arg] = value[arg];
return 0;
static int parse_vbutton(const char *src)
const char *end = NULL;
long value[4];
if (!src || !*src)
return EINVAL;
if (vbuttons >= vbuttons_max) {
const size_t temp_max = (vbuttons | 15) + 13;
void *temp;
temp = realloc(vbutton, temp_max * sizeof vbutton[0]);
if (!temp)
return ENOMEM;
vbuttons_max = temp_max;
vbutton = temp;
/* Initialize to never-matching values. */
vbutton[vbuttons].xmin = 256;
vbutton[vbuttons].xmax = -256;
vbutton[vbuttons].ymin = 256;
vbutton[vbuttons].ymax = -256;
vbutton[vbuttons].code = 0;
vbutton[vbuttons].state = 0;
/* Skip leading whitespace. */
src += strspn(src, "\t\n\v\f\r ");
/* Find length of key code. */
const size_t len = strcspn(src, "\t\n\v\f\r ,/:");
if (len < 1 || !src[len])
return EINVAL;
end = src + len;
/* Temporary copy of the name only. */
char *name = strndup(src, len);
if (!name)
return ENOMEM;
for (size_t k = 0; known_keys[k].name != NULL; k++)
if (!strcmp(name, known_keys[k].name)) {
vbutton[vbuttons].code = known_keys[k].code;
name = NULL;
break;
if (name) {
free(name);
return ENOENT;
for (size_t i = 0; i < 4; i++) {
src = end;
errno = 0;
value[i] = strtol(src, (char **)(&end), 0);
if (errno)
return errno;
if (src == end)
return EINVAL;
if (value[i] < INT32_MIN || value[i] > INT32_MAX)
return ERANGE;
if (*end)
return EINVAL;
if (value[0] > value[2] || value[1] > value[3])
return ERANGE;
vbutton[vbuttons].xmin = value[0];
vbutton[vbuttons].ymin = value[1];
vbutton[vbuttons].xmax = value[2];
vbutton[vbuttons].ymax = value[3];
vbuttons++;
return 0;
static int parse_axis(const char *src, struct input_absinfo *to)
const char *end;
long minval, maxval, fuzzval=0;
if (!src || !*src)
return EINVAL;
end = src;
errno = 0;
minval = strtol(src, (char **)(&end), 0);
if (errno)
return errno;
if (end == src)
return EINVAL;
if (minval < INT32_MIN || minval > INT32_MAX)
return ERANGE;
src = end;
errno = 0;
maxval = strtol(src, (char **)(&end), 0);
if (errno)
return errno;
if (end == src)
return EINVAL;
if (maxval < minval || maxval > INT32_MAX)
return ERANGE;
if (*end) {
src = end;
errno = 0;
fuzzval = strtol(src, (char **)(&end), 0);
if (errno)
return errno;
if (end == src)
return EINVAL;
if (fuzzval < 0 || fuzzval > INT32_MAX)
return ERANGE;
if (*end)
return ERANGE;
if (to) {
to->value = minval + (maxval - minval)/2;
to->minimum = minval;
to->maximum = maxval;
to->fuzz = fuzzval;
to->flat = 0;
return 0;
static int usage(const char *arg0)
printf("\n");
printf("Usage: %s -h | --help\n", arg0);
printf(" %s -L\n", arg0);
printf(" %s [ OPTIONS ] SOURCE-INPUT-EVENT-DEVICE-PATH\n", arg0);
printf("Options:\n");
printf(" -n NAME New event device description,\n");
printf(" default is %s\n", USB_NAME);
printf(" -u VVVV:PPPP New event device USB vendor and product,\n");
printf(" default %04X:%04X\n", USB_VENDOR, USB_PRODUCT);
printf(" -t XX:XY:X0:YX:YY:Y0 Coordinate transformation matrix,\n");
printf(" default 1:0:0:0:1:0 (no change)\n");
printf(" -k KEY:x0:y0:x1:y1 Specify a virtual button in untransformed coordinates,\n");
printf(" that when touched, generates keypress KEY.\n");
printf(" -x MIN:MAX[:FUZZ] Reported transformed X coordinate range,\n");
printf(" default %d:%d\n", X_MIN, X_MAX);
printf(" -y MIN:MAX[:FUZZ] Reported transformed Y coordinate range,\n");
printf(" default %d:%d\n", Y_MIN, Y_MAX);
printf(" -p MIN:MAX[:FUZZ] Reported pressure range,\n");
printf(" default %d:%d\n", P_MIN, P_MAX);
printf("\n");
printf("The -L option lists all known keycode names you can use for virtual buttons.\n");
printf("Fuzz is the amount of noise in the coordinates filtered out by the kernel.\n");
printf("\n");
printf("This is a daemon process, that grabs the specified touchpad input event device,\n");
printf("and provides transformed and filtered events as a new event device.\n");
printf("\n");
return EXIT_SUCCESS;
* Buffer of generated events
#ifndef MAX_EVENTS_OUT
#define MAX_EVENTS_OUT 32
#endif
static struct input_event outev[MAX_EVENTS_OUT+1];
static size_t outevs = 0;
static int outev_flush(const int outfd)
/* If nothing to flush, we're done. */
if (!outevs)
return 0;
/* Make sure we won't overflow our buffer. */
if (outevs > MAX_EVENTS_OUT)
outevs = MAX_EVENTS_OUT;
/* The final event is always a SYN report; we copy the initial event time. */
outev[outevs].time = outev[0].time;
outev[outevs].type = EV_SYN;
outev[outevs].code = SYN_REPORT;
outev[outevs].value = 0;
const char *const q = (const char *)(outev + outevs + 1);
const char *p = (const char *)(outev);
while (p < q) {
ssize_t n = write(outfd, p, (size_t)(q - p));
if (n > 0)
p += n;
else
if (n != -1)
return errno = EIO;
else
if (errno != EINTR)
return errno;
return 0;
static inline int emit(const int type, const int code, const int value)
if (outevs >= MAX_EVENTS_OUT)
return ENOMEM;
outev[outevs].type = type;
outev[outevs].code = code;
outev[outevs].value = value;
outevs++;
return 0;
/* When event() is called, it is time to emit updates.
* If we received a new value for BTN_TOUCH/ABS_X/ABS_Y/ABS_PRESSURE,
* the corresponding ev_ will be nonzero, otherwise zero.
* The current source input event device properties are in curr_,
* and for convenience, the previous in prev_.
* These are all maintained automatically.
static int curr_touch = 0, prev_touch = 0, ev_touch = 0;
static int curr_x = 0, prev_x = 0, ev_x = 0;
static int curr_y = 0, prev_y = 0, ev_y = 0;
static int curr_pressure = 0, prev_pressure = 0, ev_pressure = 0;
static inline void event(void)
/* Virtual buttons are only checked when touch state changes. */
if (ev_touch) {
for (size_t i = 0; i < vbuttons; i++)
if (curr_x >= vbutton[i].xmin && curr_x <= vbutton[i].xmax &&
curr_y >= vbutton[i].ymin && curr_y <= vbutton[i].ymax) {
if (curr_touch && !vbutton[i].state) {
/* Key press event. */
emit(EV_KEY, vbutton[i].code, curr_touch);
vbutton[i].state = curr_touch;
/* We consumed this one, so it wasn't really a touch. */
curr_touch = 0;
/* Any movement of the stylus is a hover-finger, not a proper touch. */
emit(EV_KEY, BTN_TOUCH, 0);
return;
if (!curr_touch && vbutton[i].state) {
/* Key release event. */
return;
/* If touch removed, emit key release event. */
if (!curr_touch)
if (vbutton[i].state) {
emit(EV_KEY, vbutton[i].code, 0);
vbutton[i].state = 0;
/* If touch state has changed, we want to emit that first. */
if (ev_touch)
emit(EV_KEY, BTN_TOUCH, curr_touch);
/* If we have pressure, we emit that. */
if (ev_pressure)
emit(EV_ABS, ABS_PRESSURE, curr_pressure);
/* If we have new coordinates, we transform and emit those. */
if (ev_x || ev_y) {
emit(EV_ABS, ABS_X, transform_x(curr_x, curr_y));
emit(EV_ABS, ABS_Y, transform_y(curr_x, curr_y));
int main(int argc, char *argv[])
const char *arg0 = (argc > 0 && argv && argv[0] && argv[0][0]) ? argv[0] : "(this)";
const char *srcdev = NULL;
int opt, infd, outfd;
while ((opt = getopt(argc, argv, "hLn:u:t:k:x:y:-")) != -1) {
switch (opt) {
case 'h':
return usage(arg0);
case 'L':
for (int i = 0; known_keys[i].name != NULL; i++)
printf(" %s\n", known_keys[i].name);
case 'n':
if (parse_usb_name(optarg)) {
printf("%s: Invalid device name/description.\n", optarg);
break;
case 'u':
if (parse_usb_vendor_product(optarg)) {
printf("%s: Invalid USB vendor:product string.\n", optarg);
break;
case 't':
if (parse_transform(optarg)) {
printf("%s: Invalid transformation matrix.\n", optarg);
break;
case 'k':
if (parse_vbutton(optarg)) {
printf("%s: Invalid virtual button specification.\n", optarg);
break;
case 'x':
if (parse_axis(optarg, &x_axis)) {
printf("%s: Invalid X coordinate range.\n", optarg);
break;
case 'y':
if (parse_axis(optarg, &y_axis)) {
printf("%s: Invalid Y coordinate range.\n", optarg);
break;
case 'p':
if (parse_axis(optarg, &p_axis)) {
printf("%s: Invalid pressure coordinate range.\n", optarg);
break;
case '?':
/* getopt() has already printed an error message. */
for (int i = optind; i < argc; i++)
if (!strcmp(argv[i], "--help"))
return usage(arg0);
if (optind < argc - 1) {
printf("%s: Unknown argument.\n", argv[optind + 1]);
if (optind >= argc) {
printf("Source input event device path not specified.\n");
srcdev = argv[optind];
if (install_done(SIGINT) ||
install_done(SIGHUP) ||
install_done(SIGTERM)) {
printf("Cannot install signal handlers: %s.\n", strerror(errno));
/* Open and grab the source input event device. */
do {
infd = open(srcdev, O_RDONLY | O_CLOEXEC);
} while (infd == -1 && errno == EINTR);
if (infd == -1) {
printf("%s: Cannot open input event device: %s.\n", srcdev, strerror(errno));
if (ioctl(infd, EVIOCGRAB, 1) == -1) {
printf("%s: Cannot grab input event device: %s.\n", srcdev, strerror(errno));
close(infd);
/* Construct the synthetic input event device. */
do {
outfd = open("/dev/uinput", O_RDWR | O_CLOEXEC);
} while (outfd == -1 && errno == EINTR);
if (outfd == -1) {
printf("Cannot open uinput device: %s.\n", strerror(errno));
/* Remember to release and close the input event device, too. */
ioctl(infd, EVIOCGRAB, 0);
close(infd);
/* Register possible events this device may generate. */
ioctl(outfd, UI_SET_EVBIT, EV_KEY);
ioctl(outfd, UI_SET_KEYBIT, BTN_TOUCH);
ioctl(outfd, UI_SET_EVBIT, EV_ABS);
ioctl(outfd, UI_SET_ABSBIT, ABS_X);
ioctl(outfd, UI_SET_ABSBIT, ABS_Y);
ioctl(outfd, UI_SET_ABSBIT, ABS_PRESSURE);
if (vbuttons > 0) {
ioctl(outfd, UI_SET_KEYBIT, vbutton[i].code);
/* Create the device. */
/* New uinput interface */
struct uinput_abs_setup axis_setup[3] = {
{ .code = ABS_X, .absinfo = x_axis },
{ .code = ABS_Y, .absinfo = y_axis },
{ .code = ABS_PRESSURE, .absinfo = p_axis }
const char *const axis_name[3] = { "X", "Y", "pressure" };
for (size_t i = 0; i < 3; i++) {
if (ioctl(outfd, UI_ABS_SETUP, axis_setup + i) == -1) {
printf("Failed to set up device %s axis: %s.\n",
axis_name[i], strerror(errno));
close(infd);
close(outfd);
if (ioctl(outfd, UI_DEV_SETUP, &device) == -1) {
printf("Cannot set up uinput device: %s.\n", strerror(errno));
close(infd);
close(outfd);
#else
/* Old uinput interface. */
ssize_t n;
do {
n = write(outfd, &device, sizeof device);
} while (n == -1 && errno == EINTR);
if (n == -1) {
close(infd);
close(outfd);
} else
if (n != (ssize_t)sizeof device) {
printf("I/O error setting up uinput device.\n");
close(infd);
close(outfd);
#endif
if (ioctl(outfd, UI_DEV_CREATE) == -1) {
printf("Cannot create uinput device: %s.\n", strerror(errno));
close(infd);
close(outfd);
while (!done) {
struct input_event evbuff[32];
ssize_t n = read(infd, evbuff, sizeof evbuff);
if (n > 0) {
struct input_event *const evend = evbuff + (size_t)n / sizeof evbuff[0];
for (struct input_event *ev = evbuff; ev < evend; ev++) {
if (ev->type == EV_SYN && (ev->code == SYN_REPORT || ev->code == SYN_DROPPED)) {
outev[0].time = ev->time;
outevs = 0;
event();
outev_flush(outfd);
prev_touch = curr_touch;
prev_x = curr_x;
prev_y = curr_y;
prev_pressure = curr_pressure;
ev_touch = 0;
ev_x = 0;
ev_y = 0;
ev_pressure = 0;
} else
if (ev->type == EV_KEY && ev->code == BTN_TOUCH) {
curr_touch = ev->value;
ev_touch = 1;
} else
if (ev->type == EV_ABS) {
if (ev->code == ABS_X) {
curr_x = ev->value;
ev_x = 1;
} else
if (ev->code == ABS_Y) {
curr_y = ev->value;
ev_y = 1;
} else
if (ev->code == ABS_PRESSURE) {
curr_pressure = ev->value;
ev_pressure = 1;
} else
if (n != (ssize_t)-1) {
printf("Warning: Read a partial event (%zd bytes) from %s.\n", n, srcdev);
} else
if (errno != EINTR) {
printf("Warning: Error reading events from %s: %s.\n", srcdev, strerror(errno));
/* Release the source input event device, and close it. */
close(infd);
/* Destroy our synthetic device. */
ioctl(outfd, UI_DEV_DESTROY);
close(outfd);
