Products => Computers => Programming => Topic started by: metertech58761 on December 01, 2021, 02:38:34 am
Title: Setting up Arduino I/O pins?
Post by: metertech58761 on December 01, 2021, 02:38:34 am
So, I'm trying to see if I can rewrite this block of 6801 assembly into C++ so as to use something like Arduino - the assumption being I'd go with something like the Mega 2560.
I'm now at the point where I have to define and add calls to the I/O lines to replace the PIA calls currently in the code.
Getting an idea as to how to set them up will help me immensely. Here are the lines I need to define (23 in all!):
I2C_Clk and I2C_Dat - obviously, this would be for the LCD (4 rows / 20 cols)
KB_R0...R3 and KB_C0...C3 are for the 4x4 matrix keyboard (8 lines total)
Init_En is an output to control one of the features (to drive a small signal relay)
Sig_PIA is a serial data input that is sampled via an interrupt
PAI is the corresponding serial data output (manipulated by the same interrupt process)
PAE (also controlled within the interrupt process) controls a relay that puts the unit in transmit or receive mode.
RlyA... RlyD are four lines that are read as a nybble to determine the status of a set of relay outputs
SW0 / SW1 are a pair of lines to determine the test switch setting (yielding a value between 0 and 3)
Likewise, Jmp0 / JMP1 are a pair of lines that check a pair of configuration jumpers (again, yielding a value between 0 and 3)
And if possible, a 'reference' crystal oscillator input.
Title: Re: Setting up Arduino I/O pins?
Post by: retiredfeline on December 01, 2021, 03:05:28 am
You have to set up pins in suitable modes, input, input with pullup/pulldown, output, open drain, etc. Some pins even have to be switched between modes on the fly, e.g. the I2C SDA.
Post by: metertech58761 on December 01, 2021, 01:16:11 pm
...and I accomplish this how?
All I've been able to find is a passing mention of the digitalWrite() command.
And I need to read several of the lines as bit pairs or a nybble.
Post by: retiredfeline on December 01, 2021, 02:17:12 pm
https://www.arduino.cc/reference/en/language/functions/digital-io/pinmode/ (https://www.arduino.cc/reference/en/language/functions/digital-io/pinmode/)
For greater control and to read more than one pin at a time, you need to go lower level:
https://www.arduino.cc/en/Reference/PortManipulation (https://www.arduino.cc/en/Reference/PortManipulation)
Post by: westfw on December 02, 2021, 09:42:31 am
Note that the popular Arduino Uno and Arduino Nano boards only have 20 IO pins...
Use the Arduino "Wire" library (and the hardware I2C pins)  Or perhaps just an existing LCD library.
Is this UART-compatible serial data, or something custom?  The Arduino chips all have a lot more peripherals built-in than a 6801, so it's hard to tell which features of your old board should be moved to hardware, and which you want to reproduce the old software-driven behavior.
Init_En is an output to control one of the features (to drive a small signal relay)KB_R0...R3 and KB_C0...C3 are for the 4x4 matrix keyboard (8 lines total)RlyA... RlyD are four lines that are read as a nybble to determine the status of a set of relay outputsSW0 / SW1 are a pair of lines to determine the test switch setting (yielding a value between 0 and 3)
pinMode(x, INPUT) or pinMode(x, OUTPUT)
There are also existing keypad libraries.
The Arduino API only defines functions for reading/writing single bits; to replace code that reads multiple bits, you'll need to either convert the logic, assemble the multiple-bit fields from single bits, or step out of the Arduino APIs.
Post by: Doctorandus_P on December 02, 2021, 10:16:20 am
Just forget that "arduino" rubbish and use normal I/O port register manipulation.
I/O registers are quite simple and just have three registers.
* A register to read from the inputs.
* A register to write to the outputs.
* A register for configuration.
If alternative functions are enabled (UsART, SPI, etc) then these override the the normal I/O functions.
Post by: metertech58761 on January 08, 2022, 01:33:47 am
Sorry for not responding sooner...
There are parts of the code that just will not translate cleanly to C++ (some math operations involving carry between successive bytes that are sent and received, as well as the process of rolling bits left or right as needed).
I also see the Arduino environment has certain failsafes built in that would play havoc with the timing (and I do agree, direct manipulation of the output lines would be the way to go, as the module would need to keep up with the ~2.4kHz input clock and 12.5kHz output clock).
All things considered, I don't really see that I have much choice but to stay with the original 68HC11 assembly code (at least I remember enough assembly language to be able to pick out all the sloppy code and do a proper rewrite).
Too big a gulf between my starting point and the various options available today.
I've invested enough time in this, and I have other non-technical projects waiting for attention. Time to get a move on.
