Author Topic: Unit testing C embedded code - systems and frameworks  (Read 13803 times)
Offline bson
Re: Unit testing C embedded code - systems and frameworks
« Reply #25 on: November 18, 2021, 11:09:00 pm »
I create test programs that each contain a set of unit tests.  It gets flashed and run, and watched by a scripted GDB session which collects results and outputs a report. The harness that runs the tests is a simple python program that generates GDB scripts and runs them via openocd, then tallies up the reports for progress/pass-fail/etc.  All output is captured (openocd, GDB, SWO, and serial port) to help narrow down failures.
Also, and this is not limited to embedded/firmware, but also large software systems I've worked on: massive GDB invariant scans that can walk memory and check EVERYTHING.  Every heap allocation, pointer, data, values -- all state.  Since it's GDB and Unix it can also operate against a core dump, making it exceedingly handy in that it can tell you up front what state is corrupt so provides extremely useful clues on a segfault or bus error, or even hamfisted kills of stuck processes.  (Most likely deadlocked or they closed their listen port or something.)  At one place we had a hard rule: you're not done until you have a unit test, documentation, reviewed code, AND a GDB TCL script to invariant check your state (or updates to existing checkers) against a live system or core dump.
« Last Edit: November 18, 2021, 11:14:33 pm by bson »
Offline DiTBho
« Reply #26 on: November 19, 2021, 11:21:02 am »
any public example?
Offline ricko_ukTopic starter
« Reply #27 on: November 19, 2021, 03:40:13 pm »
Thank you all for all additional discussion and contributions! :)
any public example?
Yes, that would be nice to see, to get an idea of how others with more experience, do it. :)
Thank you
« Last Edit: November 19, 2021, 03:42:51 pm by ricko_uk »
