Author Topic: What is a good tsop 48 programmer? or universal?  (Read 1635 times)
Offline psxpetey1Topic starter
« on: October 28, 2020, 01:51:43 pm »
I've found the cheap boys on alibaba but they don't seem to do the MT29F128G08CFABBWP What are some good true universal programmers?
Offline Cocodo
  • Country: ir
Re: What is a good tsop 48 programmer? or universal?
« Reply #1 on: February 26, 2021, 01:47:55 pm »
Take a look at RT809H.
I have it and it does the job.
Offline Qw3rtzuiop
« Reply #2 on: February 26, 2021, 02:59:14 pm »
The xgecu T56 claims also to be able to do that.
http://www.xgecu.com/MiniPro/T56_List.txt
Im happy although it isnt as nice as the batronix programmers.
Offline srobik
  • Country: sg
« Reply #3 on: April 23, 2021, 04:34:55 pm »
HI,
Hello, I have a problem. I need to load and program: High-Density EE CMOS Programmable Logic
MACH110 MACH 1/2 Data Sheets The MACH110 is a member of our high-performance EE CMOS MACH 1 family. This device has approxi- mately three times the Logic macrocell capability of the popular PAL22V10 without loss of speed. The MACH110 consists of two PAL blocks intercon- nected by a programmable Switch matrix. The two PAL blocks are essentially PAL22V16 structures complete with product-term arrays and programmable macro- cells. The Switch matrix connects the PAL blocks to each other and to all input pins, providing a high degree of connectivity between the fully-connected PAL blocks. This allows designs to be placed and routed efficiently. n Pin-compatible with MACH111 MACH210 MACH211 MACH215 By Lattice Semiconductor Corp.
Can you help me?
Online coromonadalix
« Reply #4 on: May 21, 2021, 06:13:38 am »
Some Elnec programmers can do   MT29F128G08CFABBWP  too
The MACH series too
I have an Beeprog+  and they are supported, but the adapter can be costly ?
« Last Edit: May 21, 2021, 06:15:50 am by coromonadalix »
