Author Topic: What's your favorite language feature?  (Read 3600 times)
Offline mrflibble
« on: March 05, 2020, 11:16:59 am »
Thought it would be fun to hear from other people what cool language features are out there. What feature in your programming language of choice do you like the most? Can be anything about any language.
My choice would have to be ... mmmhh, list comprehension in python. Maybe generators in general. Oh and itertools, and, and... But to keep it specific, yes, list comprehension.
So what's yours?
Online jfiresto
Re: What's your favorite language feature?
« Reply #1 on: March 05, 2020, 11:27:52 am »
Associative arrays (dictionaries), named arguments and coroutines
« Last Edit: March 05, 2020, 03:15:44 pm by jfiresto »
Offline tggzzz
« Reply #2 on: March 05, 2020, 11:37:09 am »
Hard realtime performance guaranteed by the IDE not measurement (combination of hardware and software), output to be executed at specified clock cycle, input received at a specified clock cycle. All found in xC running on xCORE processors
Built-in primitives (not libraries) for multiprocessor systems and inter-processor communication. Found in CSP, Occam, xC and to a lesser extent Rust and Go.
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: March 05, 2020, 11:51:12 am »
pointer, pointer to pointer, type casting, OOP, operator overloading. keen coder should already know what is this, only one language can provide this at humanly friendly language/syntax. the rest? list of <insert whatever here>, dictionary <insert your fav here> etc all can be made later on as a class or whatever (higher level function), but once the pointer feature is not available directly, it feels like sitting on a wheelchair losing both legs.
It's extremely difficult to start life.. one features of nature.. physical laws are mathematical theory of great beauty... You may wonder Why? our knowledge shows that nature is so constructed. We simply have to accept it. One could describe the situation by saying that... (Paul Dirac)
Online blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #4 on: March 05, 2020, 11:53:07 am »
Venerable universal scanf family.
Sounds simple, but interesting enough MSFT didn't have them included in .NET.
Offline AndyC_772
« Reply #5 on: March 05, 2020, 01:27:27 pm »
Conditional execution, especially as applied to branch instructions.
Offline SiliconWizard
« Reply #6 on: March 05, 2020, 05:27:26 pm »
Swearing and cursing.  ::)
Online jfiresto
« Reply #7 on: March 05, 2020, 05:40:32 pm »
Ah, but in what language?
Offline boffin
« Reply #8 on: March 05, 2020, 05:56:40 pm »
  • Associative Arrays/Dictionaries (most modern languages)
  • Sets (Pascal).  Just wait until you use a set to represent an output register.  It's a thing of beauty....
Offline dferyance
« Reply #9 on: March 05, 2020, 06:10:13 pm »
Separate compilation / linker.
So many "modern" programming languages don't bother with it (Java, .Net, Python, NodeJS). So you end up with Docker hell trying to manage all your dependencies.
A programming language ought to be able to produce a single executable without additional runtime libraries or installs. That isn't to say all applications should be a single executable, but they all ought to be able to use a linker to include dependencies (as well as exclude) at compile time.
« Reply #10 on: March 05, 2020, 06:37:47 pm »
Any that supports it. The OP said: "Can be anything about any language."
Offline ve7xen
    • VE7XEN Blog
« Reply #11 on: March 05, 2020, 08:01:04 pm »
I'm going to go with type inference as my favourite 'general' feature. It makes strongly typed languages so much nicer to use.
As for the 'coolest' feature, I'm going to go with Golang's goroutines and channels.
73 de VE7XEN
Offline tggzzz
« Reply #12 on: March 05, 2020, 08:51:11 pm »
Actually Communication Sequential Processes' channels and execution semantics. From 1976, from CAR Hoare. Look him up on wackypedia etc.
First implementation : Occam in the early 80s. Current variant: xC,  as per my previous post :)
Online Nominal Animal
« Reply #13 on: March 05, 2020, 10:03:55 pm »
Aggressive and words of power.
External language bindings in various programming languages, and extended inline assembly in GNU C and C++.
Offline bsudbrink
« Reply #14 on: March 05, 2020, 11:26:43 pm »
I like languages that allow direct access to hardware, including the CPU and its registers.  And the operations are represented by simple numeric codes in consecutive memory locations.
Offline David Hess
  • DavidH
« Reply #15 on: March 06, 2020, 12:59:09 am »
Sane casting of integer multiplies and divides would be my favorite language feature if it existed.
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #16 on: March 06, 2020, 03:17:42 am »
Offline golden_labels
« Reply #17 on: March 06, 2020, 04:02:01 am »
Prototype-based programming. Easy to abuse, but great for compatibility layers and modifying method behaviour. Unfortunately also quite inefficient. :(
Any type of sane multiline string literals, possibly coupled with indentation removal.
Template metaprogramming in C++. Too bad the error messages are unreadable.
Null coalescing and Elvis operators, in various shapes and forms.
Java has a separate compiler (javac) and “linker” (java).
Since Java has no executables, it also means the second paragraph would not apply. However: the closest it has to executables, JARs, allow you to pack anything you want — including all the dependencies. This is a horribly bad practice that will bite you just like any other failure at using modularity, but there is nothing that prevents you from doing so.
« Last Edit: March 06, 2020, 04:08:20 am by golden_labels »
Worth watching: Calling Bullshit — protect your friends and yourself from bullshit!
Offline ivaylo
« Reply #18 on: March 06, 2020, 05:56:14 am »
functions as first class citizens
in any language...
Offline emece67
« Reply #19 on: March 06, 2020, 08:37:24 am »
Dictionaries & regexps.
Information must flow.
Online jfiresto
« Reply #20 on: March 06, 2020, 01:45:18 pm »
Closures
Online blueskull
  • Country: cn
« Reply #21 on: March 06, 2020, 01:55:27 pm »
Or you just go the complete opposite, using containers.
« Reply #22 on: March 06, 2020, 04:02:02 pm »
I would cite metaprogramming in general as well. Unfortunately, this is so badly implemented in most languages I know of that I can't really associate this sanely with any.
C++ templates were a nice attempt at first, but they became horrible, and yes the diagnostic messages are usually unusable, so you better get it right first or you will cry.
Java itself is a horribly bad practice. >:D
Offline dferyance
« Reply #23 on: March 06, 2020, 07:46:55 pm »
Quote from: golden_labels link=topic=232434.msg2950470#msg2950470
I intended to mean static or compile-time linker. Most languages and operating systems have some sort of dynamic linker.
Yeah, JAR is essentially a work-around, similar to Docker. It still is dynamic linking, slows down program startup, can fail for things that ought to be caught at compile time, doesn't eliminate dead-code or do link-time optimizations. But it is better than having a ton of files all over the place.
Offline TerminalJack505
« Reply #24 on: March 06, 2020, 09:03:32 pm »
I would say that, in general, my favorite language feature is "being modern."  That is, a language that evolves to meet the demands of modern software engineering and doesn't rest on its laurels and live in the past.  A language that helps the developer apply best practices as they are understood here-and-now.  (I'm basically calling-out languages like 'C', here.)
Specifically, I'd say one of the most interesting language features to come (back) around recently is coroutines.
