Author Topic: x86 assembly, uart-16450, simple putch  (Read 2156 times)
Offline westfw
Re: x86 assembly, uart-16450, simple putch
« Reply #25 on: May 16, 2023, 05:52:45 am »
NASM is way better than gas if you actually write assembly yourself.
I have no doubt.  gas is mostly for use by the compiler, with perhaps its only advantage for a programmer being that you maintain a lot of pseudo-ops and cli properties across many different architectures.
Sometimes I think it's been made intentionally ugly to discourage assembly language programming.  "@" for a comment character (ARM)?  What were they thinking?
Online DiTBhoTopic starter
« Reply #26 on: May 16, 2023, 06:42:54 am »
LOL, crazy, see this trick
; console_out the EOS terminated string which follows the call
;    eg:
;            call say
;            db "hAllo", EOS
say:
                push    bp
                mov     bp,sp
                push    ds
                push    si
                push    ax
                mov     si, [bp+2]
                push    cs
                pop     ds
say_body:
                lodsb               ; Load byte at address DS:SI into AL.
                cmp al, EOS
                je      say_done
                call    ch_put
                jmp     say_body
say_done:
                mov     [bp+2], si
                pop     ax
                pop     si
                pop     ds
                pop     bp
                ret
unbelievable that you can easily mix code and data this wild way, but it actually works!!!  :o :o :o
ok, seriously it takes too many opcode, let's implement the classic print_string with a string pointer as argument
« Reply #27 on: May 16, 2023, 07:07:22 am »
you can't do anything like this with a MIPS
unless you force strict align=4 for the string (zero padding string_size mod 4)
and there are some implementations that physically separate data from code
x86 is a very primitive beast :o :o :o
Online Nominal Animal
« Reply #28 on: May 16, 2023, 01:01:53 pm »
At the time when 8086/80186/80286-class machines had less than 640kB of RAM, it was common for games to use self-modifying code.
Starflight (1986) used this heavily, including storing the modifications on-disk: to restart the game from scratch, you had to reinstall it (create new copies of the game disks)!
Well, this takes 33 bytes, noting that now the character to be sent is in AH (and not AL) register,
        [bits 16]
        EOS                     EQU     (0)
        SERIAL_BASE             EQU     (0x3F8)
        SERIAL_THR              EQU     (SERIAL_BASE+0)         ; Transmit Hold Register (w)
        SERIAL_RBR              EQU     (SERIAL_BASE+0)         ; Receive Buffer Register (r)
        SERIAL_LSR              EQU     (SERIAL_BASE+5)         ; Line Status Register (r)
        SERIAL_IS_DATA_READY    EQU     (0x01)
        SERIAL_IS_OVERRUN       EQU     (0x02)
        SERIAL_IS_PARITY_ERROR  EQU     (0x04)
        SERIAL_IS_FRAMING_ERROR EQU     (0x08)
        SERIAL_IS_BREAK         EQU     (0x10)
        SERIAL_IS_THR_EMPTY     EQU     (0x20)
        SERIAL_IS_EMPTY         EQU     (0x40)
        SERIAL_IS_FIFO_ERROR    EQU     (0x80)
        ; Character to be sent in AH
        ; Clobbers AL
serial_putc:
        push    dx
        mov     dx, SERIAL_LSR
.serial_putc_wait:
        in      al, dx
        test    al, SERIAL_IS_THR_EMPTY
        jz      .serial_putc_wait
        mov     dx, SERIAL_THR
        mov     al, ah
        out     dx, al
        pop     dx
        ret
        ; String to be sent in DS:SI
        ; SI will point to EOS
serial_puts:
        push    ax
.serial_puts_next:
        mov     ah, [si]
        cmp     ah, EOS
        je      .serial_puts_done
        call    serial_putc
        inc     si
        jmp     .serial_puts_next
.serial_puts_done:
        pop     ax
        ret
but if you don't need the single-character one, this takes only 28 bytes:
        [bits 16]
        EOS                     EQU     (0)
serial_puts:
        push    ax
        push    dx
.serial_puts_next:
        mov     ah, [si]
        cmp     ah, EOS
        jnz     .serial_puts_one
        pop     dx
        pop     ax
        ret
.serial_puts_one:
        inc     si
        mov     dx, SERIAL_LSR
.serial_puts_wait:
        in      al, dx
        jz      .serial_puts_wait
        mov     dx, SERIAL_THR
        mov     al, ah
        out     dx, al
Often, preserving AX isn't useful, so if you let it clobber that too, omit the push/pop AX, and it'll shrink to just 26 bytes.
The reason I didn't use lodsb in either, is because lodsb; mov ah, al and mov ah, [si] ; inc si are both 3 bytes, but the former depends on the direction flag (D), and the latter does not.
If you look at the compare-to-EOS parts, you'll find that adding other characters for true printf-like functionality (in a separate function!) isn't too difficult.  I just recommend that you make it caller-cleanup (i.e., you only look at the parameters on stack, not pop them off).  For integers, I recommend you use the slow DIV/IDIV-by-radix method (with value in DX*65536+AX), constructing it from right to left in a temporary buffer on stack (16 chars including EOS suffices for 32-bit integers in octal, decimal, and hexadecimal).
The following users thanked this post: SiliconWizard, DiTBho
