Author Topic: What to do with a huge-ass TRIAC?  (Read 1985 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« on: November 01, 2018, 01:04:40 pm »
When I went to my usual passive component supplier for some supplies, she gave me a used BTA41-800B 800V 41A TRIAC as a bonus out of blue.
What can I do with that?
« Last Edit: November 01, 2018, 01:13:21 pm by technix »
Offline NiHaoMike
    • Facebook Page
Re: What to do with a huge-ass TRIAC?
« Reply #1 on: November 01, 2018, 01:17:04 pm »
It would work great to control a large heating element. In fact, that's probably the biggest use case for large triacs.
  • Country: cn
    • My Untitled Blog
« Reply #2 on: November 01, 2018, 01:19:59 pm »
I cannot see me getting a 32kW heating element any time soon... That thing can switch 32kW of power.
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #3 on: November 01, 2018, 01:29:17 pm »
It could be used as a crowbar.  >:D
Offline capt bullshot
« Reply #4 on: November 01, 2018, 01:30:46 pm »
TO-243 - that's a neat small one  :)
Anyway, most probably at the upper end of your typical Triac rated current range.
SCRs can do more, and way better suited as a crowbar than a triac
Imagine discharging a 900V / 500uF cap through some innocent compents (such as your triac), this SCR does a good execution job here (use it as the discharge switch).
« Last Edit: November 01, 2018, 01:35:32 pm by capt bullshot »
Offline NiHaoMike
    • Facebook Page
« Reply #5 on: November 01, 2018, 01:34:47 pm »
The 800V rating gives plenty of margin for spikes on a 240V supply and after a 20% derating on the current, a more realistic max load would be about 7.5kW.
As for another use, maybe switching the primary of a large transformer used for spot welding?
Offline Messtechniker
« Reply #6 on: November 01, 2018, 01:37:59 pm »
I'd put it in my collection of trannies and alike for subsquent use at the old pensioners home when I grow old. There, to have some fun, explode a small tranny every weekday and on sundays a larger one. Will frighten the life out of the "wardens". Keep the large TRIAC for X-mas.....  8)
Don't forget to maintain a largish LION battrey fully charged for this purpose. :-+
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
The following users thanked this post: capt bullshot
« Reply #7 on: November 01, 2018, 01:40:41 pm »
Yes, one can find a triple of them in a typical three phase powered hot water boiler, rated at total 18 ... 24kW.
  • Country: cn
    • My Untitled Blog
« Reply #8 on: November 01, 2018, 01:41:10 pm »
I think I can get a few supercaps for relatively cheap, and this thing can tank 400A pulses no longer than 50ms... And I do have a few 19.5V 3A mains switch power supply (a genuine Dell laptop power brick and two bare board style power modules) for charging the caps through a switch mode constant current regulator.
What is the ratings on that one? Megawatt scale?
Brrr...
« Reply #9 on: November 01, 2018, 01:51:55 pm »
http://ixapps.ixys.com/datasheet/mcd200-16io1.pdf
216A DC continuous / 1600V, 8kA surge. More interesting for capacitor discharging is the I2t value, this gives you some hint how much energy this thing can absorb in a single pulse. Sometimes a limit for "explosive disintegration" is specified  8)
 At best a "medium size" for real power electronics ... Might be used for the line rectifier of a 300kW inverter / VFD.
Brrr...
Naah, not brrr, rather have fun, fun, fun ;)
« Last Edit: November 01, 2018, 02:04:43 pm by capt bullshot »
  • Country: cn
    • My Untitled Blog
« Reply #10 on: November 01, 2018, 01:57:32 pm »
How to understand that I2t value?
« Reply #11 on: November 01, 2018, 02:02:15 pm »
Same as for fuses. We call it "Schmelzintegral" in German, it's the integral of current² over time flowing through the device. If the specified value is exceeded in a single pulse / short enough time, the device fails / the fuse trips.
Usually the I²t for fuses is larger than for (comparable) semiconductors, so the semiconductor device protects the fuse. The fuse is still there, to limit collateral damage.
