Couple developments. The references from LabSpokane arrived back and I want to thank him again for all the hard work. It's unfortunate confusion over the circuits resulted in more effort than necessary. He was nice to include the same resistor used in his tests so maybe I can build a jig with that to garner useful info from the graphs.
In other news I am now the owner of one of those Ebay AD584 voltage standards. A friend of mine gave it to me because it did not come with precision readings so not of much use for his purpose. I did determine that the Ebay meter is at least 7ms accurate based on the AD584 initial voltage spec. We probably already guessed that from reviews published earlier in this thread. Probably a lot better in fact based on those. Of course I can't be sure unless I can get some reference readings from somebody who owns a precision meter. My buddy is considering getting his calibrated and got quotes from some standards labs but that may be some time off.
Meanwhile I'm logging a set of the DIY references using the Ebay meter with my 16 channel input expander. Hopefully once it's calibrated I can adjust the data and get useful info. Even if not at least a chance to check out my logger and oven hardware which hasn't been operational since last year.
Amazingly the high resolution version of the meter I ordered showed up in one week. Not a record but pretty good for China. So a set of cheap DIY voltage references were thrown together and surprisingly the readings were very close to what might be expected. This is a good sign. To really check this out I need to get more accurate readings for the references from a friend who has access to a lab grade voltmeter. Stay tuned.
May I chime in with the cheer ? Amazing accuracy !
I bought 2 five dollar voltmeters and one 4.3V/30V eight dollar voltmeter.
Out of the box they gave the same reading to the last few millivolts.
So I hooked up a 10K trim pot in series and made all readings exactly the same.
Then I was amazed by the result of the following experiments:
1. When I supplied different voltages anywhere from 5V to 30V.
the 3 readings were identical down to the last digit +-1 !!!
https://www.eevblog.com/forum/Smileys/default/scared.gif2. The cheap DC-DC converter I used as variable voltage supply happens to be very stable as shown by the next experiment:
Yesterday at 18:40, I connected this DC-DCconverter to these 3 voltmeters plus another 5 digit +-200 MV large size voltmeter(which costs about $15 on Ebay) and they have now been hooked up for the last ten hours
The reading on the 3 $5 voltmeters and the larger size $15 voltmeter were:
18:40 13.004 13.005 13.005 13.005V
18:48 4 5 5 3 (meaning millivolts over 13V)
19:45 4 5 5 13.000
20:55 5 5 6 0
2:54 AM 7 7 7 12.998
4:10 AM 7 7 7 12.996
I will use them to build my own private voltage standard.
There are cheap .1% resistors available on Ebay (nikkohm)
