Hi
I’m a hobbyist who just finished making an electric cello, for reference I asked an earlier question about the project
here. It’s based on polymer film piezo pickups, which are known for flat frequency response, and susceptibility to noise, compared to ceramics. And noise I got. The noise is completely dominated by 50-cycle hum (I live in Europe), so much so that when I digitally remove the 50 Hz frequency from a recorded signal, there is no audible noise at all left. I get about 20 dB SNR with the hum, which is far too low.
Polymer film piezo sensors consist of two metal plates, in my case 1.5 square cm and 28 um apart, with piezoelectric material in between. They can be viewed as a voltage source in series with a 480 pF capacitor.
The preamp is in a cavity lined with copper shielding tape, and experiments show that almost all the noise is picked up by the sensor, which isn’t yet shielded. So, I reckon I have two paths forward:
1) Sandwich the sensor in copper tape,
2) Make a differential preamp
Number one is simple, but it might affect the audio quality as well. Besides, I thought this might be an opportunity to learn an understand EMI a little better. So, do you think this might be a good candidate for a differential preamp?
At first I had the clueless idea I would make a "humbucker", which we from the guitar community are familiar with, where two pickups receive signal in phase, and noise out of phase by 180 degrees. So, by wiring two piezo transducers with opposite polarity, I thought the noise would be cancelled out. Since they were placed on opposite sides of a bridge rocking back and forth, the signal would still be in phase. It looks like I was correct that the signal was in phase, as two sensors gave a signal about 6 dB stronger than one, but the noise didn’t cancel, and the sound was a bit more focused with only one sensor on one side of the bridge, so I went for a single sensor.
So it seems I must change my mental model about how this works. If the noise was a voltage generated across the two metal plates of a transducer, as I imagined it, then surely the polarity of the wiring would affect the polarity of the noise picked up. So maybe I should instead view the two plates as two independent antennas, capable of picking up potentially the same noise? If they pick up an identical, or near identical noise signal, then surely a differential preamp might be the way to go.
The current wire from sensor to preamp is a single shielded conductor, with ground connected to one plate, and hot connected to the other. I would then replace it with a twisted shielded pair, with each plate connected to a wire in the pair, and would have to make an instrumentation amplifier like the one at the bottom
here to keep input impedance high. Do you think that might be a good idea to try?
