I'm busy trying to repair a old 12" CRT from the early 80's - Yes, I'm aware of the electrical dangers
One of the components is a 56R resistor which is now reading 100R. Looking at the schematic it's a 56R RN1/4 which from what I can gather is a 0.25W Metal Film Resistor. Resistor looks a bit worse for wear and has overheated.
That's all good and easily replaceable. One thing that I've noticed is that there are a few resistors around the HV side that have one leg soldered to a post which I've not seen before.
Guessing it's to keep it off the PCB for cooling? But why one leg and why mount it to a post? (Or is the post also some sort of heat sink?)
Was this a standard for the CRT's in the 80's?
