Author Topic: Need a IoT wifi module supporting EVM board  (Read 537 times)
Offline Md Mubdiul HasanTopic starter
  • Country: kr
  • Lets learn more to be more inspired in Electronics
« on: April 23, 2019, 02:28:56 am »
Hi There,
Does it possible to virtual simulation of a IoT wifi module?
Suggest me kindly.
I am working with a WIFI module from a different company.
It has JTAG interface with API, SPI protocol with main MCU and UART as well.
Take a look the image below.
Kindly find a suitable EVM to support it in case of IoT.
I will provide all information relating to this project.
Following facilities are required...
1. USB to serial driver.
2. Serial terminal utility.
3. Wifi Mode setup
4. Setup soft mode
5. Command line interface
6. Consol command
Hasan
