Author Topic: Any good MOSFET tester schematic?  (Read 2576 times)
Offline zaokaTopic starter
« on: October 17, 2011, 04:12:07 pm »
I am looking for a good MOSFET tester schematic that test simply GO-NOGO and leakage.
This is for good friend of mine who started learning electronics.
Offline johnwa
    • loopgain.net - a few of my projects
Re: Any good MOSFET tester schematic?
« Reply #1 on: October 18, 2011, 11:30:09 am »
For a simple go/no go test, I usually just hook the drain and source up to a bench power supply with a lamp in series. Touch the gate with one hand, and the positive terminal of the PSU with the other (assuming N-channel), and the lamp should go on, now touch the negative terminal and it should go off again. While this is a fairly crude test, in my experience MOSFETS usually either work or they don't - you don't really need to know any more.
Make sure that you take appropriate antistatic precautions with the above test.
Hope this helps,
John
