Author Topic: Huntron Tracker DIY – Can an MAX293 Elliptic Filter Chip be used?  (Read 334 times)
Offline Chris56000
Hi!
I was looking thro' the design of the Russian "GO" RLC–2 RCL Meter and noticed this uses a  MAX293 "8th Order Elliptic Filter" device to generate the two quadrature sinusoids for the test component, so this set me thinking – can the same approach be used in a D.I.Y. Huntron Design to generate the the 50Hz, 400Hz & 2kHz Component Test Voltage, then fed to a Power Amplifier and a small 100V Line Matching Transformer used in reverse then on to the rest of the Huntron Circuits that select the Test Voltage?
Chris Williams
« Last Edit: December 25, 2020, 04:57:20 pm by Chris56000 »
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
