Author Topic: 0-30V 0-10A Power Supply Project  (Read 2311 times)
Offline gevv
« on: December 25, 2020, 10:20:14 am »
A laboratory power supply offers an indispensable set for both the professional
and the amateur. This power supply is short-circuit protected and infinitely variable from 0 to 30V
and from 0 to 10A.
Velleman k7200  POWER SUPPLY TECHNICAL DATA
- Output voltage variable from Ov to 30V.
- Fine tuning over 1 V
- Output current limiting device infinitely variable from 0 to 1 OA.
-LED (l ight emitting diode)-indication of current limitation
- Output current: 8A. continuous/1 OA. peak
- Short-cicuit protected
-Ripple maximum: 0.5mV RMS
https://youtu.be/6wTsgXGJ5CY
Velleman k7200  PSU
source:  elforum.info (fixed error in pcb drawing and  re-edited pcb)
« Last Edit: December 25, 2020, 02:57:50 pm by gevv »
Online coromonadalix
Re: 0-30V 0-10A Power Supply Project
« Reply #1 on: December 25, 2020, 01:36:58 pm »
This design had many variants like this one (attached file) this one is a 30vdc 10 amps too.
BUT  if i recall  it doesn't drop all the way to zero volts,  you need to have an -1.2 volts supply added on the voltage potentiometer,  it's inherent to the 723 design
« Last Edit: December 25, 2020, 03:45:11 pm by coromonadalix »
