Author Topic: Load sharing on a TP5400 (Lipo charger + Boost Converter)  (Read 8714 times)
Offline Peabody
Re: Load sharing on a TP5400 (Lipo charger + Boost Converter)
« Reply #25 on: October 13, 2022, 01:41:18 pm »
You don't need both R0 and R4.  And I would think 10K would work ok, but thinkfat is the expert on that.
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #26 on: October 15, 2022, 03:04:19 pm »
Yes, just drop R0 and make R4 5k. I've used 5k before, worked for me. You should be able to compute a value based on the leakage current of the diode on the power path.
The datasheet of the SS32 gives a reverse current between 10µA and 1mA for a temperature range between 25°C to roughly 100°C. Just dimension the resistor so that at 1mA current, the voltage never rises above the turn-on voltage of the TP5400. I think 5k is a good value, 10k might be too large already.
