Author Topic: Looking for QFN 48 pin 6x6mm layout dimensions  (Read 3444 times)
Offline YaroTopic starter
« on: August 13, 2016, 11:44:29 am »
As title I'm looking for QFN 48 pin 6x6mm layout dimensions, I've a chip that use this package but datasheet doesn't provide any PCB layout dimensions. I need to draw it but I've found only 48pin QFN 7x7mm layout dimensions. Does someone have correct standard dimensions for this package?
Thank you!
Offline Kalvin
  • Embedded SW/HW.
Re: Looking for QFN 48 pin 6x6mm layout dimensions
« Reply #1 on: August 13, 2016, 11:52:16 am »
Have you tried searching from the Google? It is pretty handy.
Offline Kalvin
  • Embedded SW/HW.
« Reply #2 on: August 13, 2016, 11:56:52 am »
Offline MagicSmoker
« Reply #3 on: August 13, 2016, 12:54:29 pm »
Thank you!
To search for footprints on Google try variations on the following queries:
QFN48 6x6 footprint
"QFN-48" 6x6 "land pattern"
etc.
Offline bobaruni
« Reply #4 on: August 13, 2016, 01:51:02 pm »
lol, the first search result returned is this thread.
Offline tycz
« Reply #5 on: August 14, 2016, 01:54:00 am »
Yaro,
I suggest you download the IPC Land Pattern Calculator.
http://www.ipc.org/ContentPage.aspx?pageid=Land-Pattern-Calculator
Enter the package's mechanical measurements from the data sheet and it will calculate a land pattern for you. You can view the attributes of the pattern easily and use this as a reference to recreate it in your PCB software of choice.
Online Alex Eisenhut
  • Place text here.
« Reply #6 on: August 14, 2016, 02:09:24 am »
It would really, really, really help if you told us the part number. Lots of companies put the mechanical and footprint data separately.
