Author Topic: 0603 Metric Imperial Confusion  (Read 3007 times)
Offline PentoadTopic starter
« on: October 31, 2019, 07:42:16 pm »
Hello everyone, having a bit of confusion here.
I'm now ready to order some resistors and realised that there's a metric and imperial 0603 size. I don't know whether the resistors I have placed in my design are metric or imperial.
This is what they look like, the grid is 1mm.
Offline MagicSmoker
Re: 0603 Metric Imperial Confusion
« Reply #1 on: October 31, 2019, 07:51:13 pm »
Center-to-center distance for Imperial 0603 is 1.6mm; yours looks like metric 0603. EDIT - err, maybe not. You just use much larger pads than I do.
The fact that there is both an Imperial and a metric 0603 in the first place is a rant all to itself.
The following users thanked this post: Pentoad
Offline jmw
« Reply #2 on: October 31, 2019, 07:51:27 pm »
0603 = metric 1608 (1.6 x .8 mm). The distance between center of pads looks like around 1.5 mm so that's got to be an imperial 0603. Metric 0603 is 0201 - that's tiny! The part would fit on one of those pads with room to spare.
Offline NivagSwerdna
« Reply #3 on: October 31, 2019, 08:05:19 pm »
Whenever I get confused... I remember that I used to use 0805 and now I use 0603... and then I check https://en.wikipedia.org/wiki/File:SMT_sizes,_based_on_original_by_Zureks.svg and conclude that even though it is the year 2019... it is likely to be imperial.
If you measure it... and compare... http://www.resistorguide.com/resistor-sizes-and-packages/
As expected imperial.
And when I search Farnell for "0603 smd 1k" you end up finding..  "SMD Chip Resistor, 0603 [1608 Metric]" so for all intents and purposes it's probably worth only thinking in imperial sizes...
I wonder if there are people who think in metric?
« Last Edit: October 31, 2019, 08:13:52 pm by NivagSwerdna »
« Reply #4 on: October 31, 2019, 08:51:41 pm »
I use metric for nearly everything but in this case I had no idea what standard the component footprint was using as easyeda never specified. It makes sense now though, resistors ordered.
Offline bson
« Reply #5 on: October 31, 2019, 08:56:36 pm »
I'd use imperial sizes down to 0201, then switch to metric and make sure to qualify it as such.  As far as I can tell this matches equipment manufacturers as well, at least based on what I've seen at Semicon West.
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #6 on: October 31, 2019, 09:56:07 pm »
I do (along with the rest of the PCB design unless doing pure through-hole for fun), and it's liberating. The metric sizes precisely encode the device size ... no conversion tables required. But when ordering passives, searching is more effective in imperial.
The following users thanked this post: NivagSwerdna
Offline Lunasix
« Reply #7 on: October 31, 2019, 10:05:21 pm »
Some years ago, I ordered capacitors in 0603 size, but didn't seen it was 0603 metric (didn't know...) and received 0603 metric, which means 0201 imperial. Very small ! I always have these capacitors, and will never use them !
Now, before ordering, I verify the unity.
« Reply #8 on: October 31, 2019, 10:30:52 pm »
Challenge yourself.  >:D
0603 soldered onto pads designed for 1608 (imperial 0603):
The following users thanked this post: GeorgeOfTheJungle, tooki, NivagSwerdna
Offline Gribo
« Reply #9 on: November 01, 2019, 07:50:57 pm »
Meh, try Imperial 0402 and metric 0402 for a challenge.
I am available for freelance work.
