Author Topic: 1-50 MHz signal generation  (Read 4588 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: March 18, 2010, 02:50:44 pm »
I'm looking to generate a 1-50 MHz signal, I don't neccesarily need it to be variable ov that range, I may also need to got as far as 100-150 MHz. can anyone suggest a simple diagram ? possibly uasing 2N2222 transistors as I have them available.
I think I'd need it to be sinusoidal but really anything will do !
Offline KTP
  • Global Moderator
Re: 1-50 MHz signal generation
« Reply #2 on: March 18, 2010, 03:37:18 pm »
thanks, can i adapt the values for up to 150 MHz ? is it C1 or C2 that has an effect on the frequency ? or both ?
« Last Edit: March 18, 2010, 03:58:19 pm by Simon »
